Jim Burton 1 Posted August 26, 2011 Share Posted August 26, 2011 OK, My trusty Ready 2 was in need of more grunt, and so I've replaced my OS 2-stroke with a heavier Thunder Tiger 4-stroke. I need to check and re-set the centre of gravity. Trouble is, I've lost/thrown away the original instructions/plans showing where the C of G should be. If anyone still has the plans could they please take a look and tell me the C of G measurement from front edge of wing. The TT website is un-cooperative otherwise I'd try a download for the manual for the Ready 3 which is identical, I think, apart from the new decals Thanks in advance. Quote Link to comment Share on other sites More sharing options...
GONZO Posted August 26, 2011 Share Posted August 26, 2011 CG range is between 8cm - 10cm back from the leading edge. HTH Quote Link to comment Share on other sites More sharing options...
Jim Burton 1 Posted August 26, 2011 Author Share Posted August 26, 2011 Thanks for that - it's a wee bit nose-heavy at 7cms, then but not as bad as I thought. I'll shift the battery pack back - should fix it. cheers for your info. Quote Link to comment Share on other sites More sharing options...
kc Posted August 26, 2011 Share Posted August 26, 2011 Well 8 to 10 cm seemed wrong to me even though I have never owned a Ready and not seen one for years! Sure enough when I eventually managed to download the Ready 40 / Ready 3 manual it says 80 to 85 mm. So 10cm /100 mm is way out!It took ages to download the manual but it's possible. Quote Link to comment Share on other sites More sharing options...
GONZO Posted August 26, 2011 Share Posted August 26, 2011 kc, I've got one with an MDS 48 (good one) up front, it all dates from 2004. Good tough sport plane unaffected by damp/wet conditions. I placed the provided CG stickers on the wing. I measured the distances from the actual wing I use. I fly it with the rear most CG (10cm). My 5 cell battery is to the rear of the servos and my 35mHz Rx just in front of the servos. I used Futaba 3001 servos with two in the wing. Perhaps I prefer a little more elevator response as I got my 'A' back in 1980. But, yes, start with the more forward CG and be prepared to move it back. The nosewheel plastic mount was prone to break if landed too hard on the nosewheel ('wheelbarrow' landing). HTH Quote Link to comment Share on other sites More sharing options...
kc Posted August 26, 2011 Share Posted August 26, 2011 Well if you have tried it it's probably OK for an experienced flier, maybe others too. I didnt want someone to lose a plane because of a rearward CG so I looked it up Some planes are very tricky with even a little rearward CG, others are manageable. You don't know until someone tries it and then it might be too late! Quote Link to comment Share on other sites More sharing options...
GONZO Posted August 26, 2011 Share Posted August 26, 2011 kc, My bad. I should have qualified my statement on the CG range. At 10cm back it can suffer from high speed stalls, especially inverted - interesting doing outside loops or bunts. As to losing it through a crash, they sure are tough. At a past flying site there was a 33k power line across the landing approach and guess what. Yes, it ripped the wing off(single plastic bolt retention), the fus stoped dead and fell verticle a considerable distance. A very slight crease in the wing leading edge and sundry scuffs - nothing else. Quote Link to comment Share on other sites More sharing options...
kc Posted August 26, 2011 Share Posted August 26, 2011 So you are saying the makers are correct at 80 to 85 mm unless you want a tricky beast? Quote Link to comment Share on other sites More sharing options...
Jim Burton 1 Posted August 26, 2011 Author Share Posted August 26, 2011 kc - thanks for the heads-up: the TT website is co-operating now and I've d/l'd the plans which confirm your former post. I'll be going for 80-85mm alright. I can't speak for Gonzo but the last thing I want is a tricky beast - just keeping the thing in the sky is hard enough (for me, I'm a crap pilot). I can, however confirm what G says about the legendary toughness of this model - even with me at the controls, it's still in one piece (vintage 2006). Edited By David Ashby - RCME Administrator on 30/08/2011 09:30:37 Quote Link to comment Share on other sites More sharing options...
David Ashby - Moderator Posted August 30, 2011 Share Posted August 30, 2011 Jim, please check out the forum guidelines, thanks. Edited By David Ashby - RCME Administrator on 30/08/2011 09:31:44 Quote Link to comment Share on other sites More sharing options...
Shearer Posted November 18, 2013 Share Posted November 18, 2013 Where can I get instructions for the ready 2 from Quote Link to comment Share on other sites More sharing options...
adam gordon-duff Posted May 26, 2020 Share Posted May 26, 2020 Hello Folks- does anyone have any abs arc modelfly thunder tiger planes for sale?!...Thanks Quote Link to comment Share on other sites More sharing options...
Jim Burton 1 Posted May 26, 2020 Author Share Posted May 26, 2020 Well, you've posted under discussion of the ARC Ready 2 PLANS, but you are asking to buy Thunder Tiger PLANES. If this is a typo, then no, I do not have any plans, but I do have a plane for sale! Let me know. Quote Link to comment Share on other sites More sharing options...
adam gordon-duff Posted May 26, 2020 Share Posted May 26, 2020 Oops- stupidity. Was poking about Internet in a daze. Looking for an ABS my ?thunder tiger carousel met its demise. What do you have in the ABS/similar range? Thanks Quote Link to comment Share on other sites More sharing options...
