Phil Donnison Posted March 28, 2013 Share Posted March 28, 2013 Hello all you FW190 builders - I am still slowly getting there! Concentrating on the wings at the moment and trying to work out the best way to cut the retracts shape from the lower wing skins. I think I need to cut them out before attaching the skin as I can't see how I can do it afterwards and get them in the right place! Maybe a card template of some sort? What have you experts done? Also Tony suggests sticking the wings together before skinning - I think this would make it harder to hold the wings steady and avoid warping. Is there a reason I shouldn't skin them individually? I am also looking for a suitable steerable tailwheel. It took me 3 purchases to get main wheels that were thin enough to tuck inside the wing, so any advice for the rear wheel would be welcomed. Thanks Quote Link to comment Share on other sites More sharing options...
lightning 759 Posted January 10, 2014 Share Posted January 10, 2014 looking at the cowl / gun hood fit i see its off & i thought it was just mine AndyEdited By lightning 759 on 10/01/2014 08:02:54 Quote Link to comment Share on other sites More sharing options...
Lobo Twelve Posted July 14, 2015 Share Posted July 14, 2015 Hello Tony / all I'm looking for a suitable power system for the 190. Unfortunately, the 4-max motor is now unavailable. Can anyone recommend an alternative motor/mount / ESC / prop combination? I tried TN Designs but they weren't too helpful I'm afraid. Thanks L Quote Link to comment Share on other sites More sharing options...
Tony Nijhuis Posted July 15, 2015 Share Posted July 15, 2015 If you speak to 4-max, they will have another suitable set up!!.......They are the experts and know what is required to power the FW190 Quote Link to comment Share on other sites More sharing options...
i12fly Posted April 14, 2020 Share Posted April 14, 2020 I'm looking to have a go at Tony's FW190, this thread seems to have ended quite abruptly and so does one on rc groups. I wonder if people lost interest or were disappointed with the result? I've had one or two 'disappointing' plan builds in the past (but not Peter Millers!) and don't want to spend half a year making another What I'm interested in are any errors in the plan (besides the LH/RH fus the wrong way on the free plan), does it need much lead in the nose, and how well does it fly. Or would anyone recommend some other similar size warbird? Quote Link to comment Share on other sites More sharing options...
Bucksboy Posted April 15, 2020 Share Posted April 15, 2020 My entry from August 2012 above shows that it can be built into a good looking plane. It flew very well and it was my sons inexperience that caused the final crash. One thing has changed though, he's now flying airliners! I'm even contemplating building another one in the lockdown, the part count is low, it's a great looking plane and it flew very well. I can't remember about any lead in the nose. I made sure that my chosen battery would fit through the ply engine bulkhead. Quote Link to comment Share on other sites More sharing options...
i12fly Posted April 19, 2020 Share Posted April 19, 2020 Thanks Bucksboy for the encouraging remarks. I wonder if anyone else has any comments/ suggested modifications to add? Is additional nose weight required and approximately how much? Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted April 20, 2020 Share Posted April 20, 2020 Not built Tonys, did Brian Taylors and enjoyed that, mods ? Well you could set to and do a blog, any bits you feel aren't right, a post will get you plenty help. Adding lead ? It's a short nose, so proceed thinking you'll need lead, build carefully at the rear and plan to put gear as far forwards as possible, you'll maybe still need some lead, but with planning it'll reduce the amount, get it built. Quote Link to comment Share on other sites More sharing options...
i12fly Posted April 20, 2020 Share Posted April 20, 2020 I'll bear in mind your comments John. I've got plenty of balsa sheet in stock that I 'bought for a rainy day' that will complete the build but for the wing spars I'll have to do a bit of substitution, using spruce and perhaps some lamination. I'll make sure they are strong enough though, I'm quite a seasoned builder. Any advice/ pointers are appreciated Quote Link to comment Share on other sites More sharing options...
Andy Gates Posted February 12, 2023 Share Posted February 12, 2023 Help! Anyone built one of these from the free plan out of the magazine and not from purchasing a replacement plan? I have a 3/4 built wing and was about to start the fuselage to find a huge error that does not seem to be mentioned anywhere. I am not referring to the Left / Right sides being labelled incorrectly. I am referring to the fact that the W1 rib and wood sections for the leading edge measure 338mm from le to te. The rib on the fuselage section, shows the rib and the gap between F2 & F4 as measuring 320mm! It does measure 338mm from te to the front of the wing fairing. How did any of you resolve this? Quote Link to comment Share on other sites More sharing options...
