William Macleod Posted October 2, 2021 Share Posted October 2, 2021 are there any 2 stoke petrol motor that are quietish? Quote Link to comment Share on other sites More sharing options...
Peter Jenkins Posted October 2, 2021 Share Posted October 2, 2021 Any 2 stroke petrol can be made to be quiet. You just need to spend money, and have the space to accommodate, suitable silencers. Expect to pay between £60-£90 for such silencers. You won't get a lovely 4 stroke sound but the noise is quite acceptable once you properly silence them. Quote Link to comment Share on other sites More sharing options...
cymaz Posted October 2, 2021 Author Share Posted October 2, 2021 17 minutes ago, Peter Jenkins said: Any 2 stroke petrol can be made to be quiet. You just need to spend money, and have the space to accommodate, suitable silencers. Expect to pay between £60-£90 for such silencers. You won't get a lovely 4 stroke sound but the noise is quite acceptable once you properly silence them. This might suit https://www.tjdmodels.com/product/muffler-silencer-for-dle-30dle-35ra/ You may may have to experiment. A Pitts muffler may stop the canister appearing out of the cowl Quote Link to comment Share on other sites More sharing options...
Peter Jenkins Posted October 2, 2021 Share Posted October 2, 2021 You might also want to see this (https://www.propguy.co.uk/silencers-and-canisters) although you would need to build in room for the canister in the fuselage and it might prove difficult to do so. These types of silencers are far superior to Pitts types in how the engine sounds and its ability to pass the noise test. Avoid the cheap canisters as they don't work anything like as well. Quote Link to comment Share on other sites More sharing options...
William Macleod Posted October 2, 2021 Share Posted October 2, 2021 Sorry to keep going off thread but any comments regarding the OS GT22 petrol engine? Bill Quote Link to comment Share on other sites More sharing options...
cymaz Posted October 2, 2021 Author Share Posted October 2, 2021 Very similar in performance to the dle20.....except the OS will cost an extra £150 ish Quote Link to comment Share on other sites More sharing options...
William Macleod Posted October 7, 2021 Share Posted October 7, 2021 Currently have a dle 30. Dal 32 and a ngh 25 to look at. Also an evolution 20, but the unpumped version,,,,,, ,comments welcomed on all the engines?♂️ The dla 32 is the only one that says 40 or 50:1 for oil content which would suit aspen 2 fuel and would run at reduced throttle to assist in noise issues Thanks Bill Quote Link to comment Share on other sites More sharing options...
Nick Somerville Posted October 8, 2021 Share Posted October 8, 2021 I may have missed an earlier comment William, but why so keen on a petrol engine. I have a Laser 180 in my Stampe and it is a perfect match. 25 years ago My first Stampe had a Laser 150. That model was 2 lbs lighter and the match was equally as good. People at our patch love the quiet scale like sound. Look at the second hand values of Chinese petrol engines and compare it to a British made Laser. If you are worried about glow fuel goop on your model it doesn’t happen with the new Laser Pro fuel. One wipe with a cloth after flying and it’s clean as. 2 Quote Link to comment Share on other sites More sharing options...
martin collins 1 Posted October 8, 2021 Share Posted October 8, 2021 (edited) Flew my Stampe for the first time today, boy it is a great flyer, so scale like in the air on coupled rudder, the electric conversion is spot on, 2 x 3700mah packs in parallel on a 20x12 Turnigy wood prop. First flight i set the timer at 5 min, actually flew it for 5 1/2, battery capacity check showed 26% used. Second flight set the timer for 6 min, on landing i still had 46% left. So three 6 min flights from the one paralleled pack would still leave plenty to spare. I already had the motor/esc and batteries so in the end it was a no brainer for me, With a full recharge time of 1 hour if parallel charged that is 6 flights, i always take more than one plane so whilst charging i can have three flights on something else...........a good days flying, second picture shows the battery hatch on the underside of the cowling. Edited October 8, 2021 by martin collins 1 2 Quote Link to comment Share on other sites More sharing options...
martin collins 1 Posted October 8, 2021 Share Posted October 8, 2021 Quote Link to comment Share on other sites More sharing options...
cymaz Posted October 8, 2021 Author Share Posted October 8, 2021 Congratulations! I have got into the habit now of using ailerons and rudder together on the sticks and not in a radio mix. Just my personal preference 2 Quote Link to comment Share on other sites More sharing options...
Nick Somerville Posted October 9, 2021 Share Posted October 9, 2021 Agree that mixing rudder and aileron manually gives more options. On slower long turns it can be helpful to use opposite rudder to hold the tail down a little and maintain a better line. Also the transmitter mixing doesn’t really help with roll shape. Quote Link to comment Share on other sites More sharing options...
William Macleod Posted October 9, 2021 Share Posted October 9, 2021 Ok Nick. You have convinced me to forget another petrol engine. I currently have a dig 84 inch spacewalker 2 ,as a testbed/running in hack for my laser 180 petrol. The stampe being the airframe of choice. My hannibal has a Zenoah 26 both run on aspen 2. I have a jabberwok with a st2000 which was for the 2 stroke petrol. However, you have now stopped me being drawn,completly, to the "dark side". My secondhand laser 150 should arrive at the end of the week. It may end up in the stampe !! Bill 1 Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted October 9, 2021 Share Posted October 9, 2021 I have never coupled the rudder with ailerons on my Stampe because it does not need it. Different story with my Laser 70 powered DB Tiger Moth and my little Mercury one. Neither rolls well with or without coupling but they both yaw rather than turn with aileron alone. By changing to high rate rudder in flight I can switch off the coupling. Quote Link to comment Share on other sites More sharing options...
martin collins 1 Posted October 9, 2021 Share Posted October 9, 2021 I have the coupled rudder on a switch so i have the option in flight of both, will be trying it without on the next flight, as said rolls will be much better without it. Quote Link to comment Share on other sites More sharing options...
martin collins 1 Posted October 9, 2021 Share Posted October 9, 2021 Get yours engined up Bill, you will have a lot of fun with it! Quote Link to comment Share on other sites More sharing options...
William Macleod Posted October 10, 2021 Share Posted October 10, 2021 20 hours ago, martin collins 1 said: Get yours engined up Bill, you will have a lot of fun with it! You must be very pleased with yours Martin. Some video would be nice? Quote Link to comment Share on other sites More sharing options...
William Macleod Posted October 10, 2021 Share Posted October 10, 2021 What does it weigh ready to go martin? Quote Link to comment Share on other sites More sharing options...
martin collins 1 Posted October 10, 2021 Share Posted October 10, 2021 A tad over 16lbs ready to fly, needed a small amount of lead to make sure it was balanced but i believe it probably would be alright without it, i was just making sure i was on the right side! I will see if someone can take a short video of it next time i fly it. Quote Link to comment Share on other sites More sharing options...
Nick Somerville Posted November 11, 2021 Share Posted November 11, 2021 Stampe kit for sale today on BMFA classified for a unbelievable bargain price. With the price of balsa these days you would be hard pushed to find a better deal for a decent sized builders model. Now if I didn’t have one already ?. 1 Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted November 11, 2021 Share Posted November 11, 2021 1 hour ago, Nick Somerville said: Stampe kit for sale today on BMFA classified for a unbelievable bargain price. With the price of balsa these days you would be hard pushed to find a better deal for a decent sized builders model. Now if I didn’t have one already ?. Simon Lawson is the seller great modeller, and all round good egg..... Precedent Stampe Kit Cheers Danny Quote Link to comment Share on other sites More sharing options...
bert baker Posted December 4, 2021 Share Posted December 4, 2021 Ive been sent the forms from Wobbly wheels for the 2022 Wings and Wheels show, any one else up for joining in for some fun Bert Quote Link to comment Share on other sites More sharing options...
bert baker Posted December 4, 2021 Share Posted December 4, 2021 Quote Link to comment Share on other sites More sharing options...
cymaz Posted December 4, 2021 Author Share Posted December 4, 2021 Son I should getting married next year...postponed from this year. Otherwise would make a holiday of it. Enjoy! Quote Link to comment Share on other sites More sharing options...
Martin McIntosh Posted December 4, 2021 Share Posted December 4, 2021 Very unlikely as I can scarcely walk at the moment. Awaiting spinal treatment. Quote Link to comment Share on other sites More sharing options...
