Supermarine Spiteful and Seafang
8 hours ago, Simon Chaddock said:
Thanks Robin. Very interesting.
I note that the big plane in front of the Martin Baker MB5 is a Vickers Windsor. A 4 engine geodetic construction pressurized bomber. Only 3 built.
To my eyes the Windsor was one of the ugliest planes made and at the time it looked out of date.
Eric
Agreed but its construction was interesting.
Both the Wellington and Warwick had wing spars to take the bending loads. The geodetic structure provided the torsional stiffness.
For the Windsor Barns Wallace increased the geodetic structure to provide all the strength so no spar was needed increasing the volume in the wing for fuel. Further it was not linen covered like the earlier designs but with a very fine woven steel mesh sealed with a form of brush on plastic.
Wallace was concerned that with 4 engines in a hard landing the downward forces from the outboard ones would overstress the wing. His solution was to add landing gear to all four of the engine nacelles.
All together not one of his 'neatest' designs,
Hi Simon, the fin looked like an after thought but the bomb load was apparently well in excess of a Lancaster another reason for the 4 main undercarriage units. The design on my book credits a Mr Rex Pierson with the design using the Barnes Wallace structure.
Another interesting aeroplane in the picture is the Fairey Spearfish a massive 60ft span single engine FAA torpedo bomber
Robin, thanks for sharing your photos,  reminds me of an exhibition after the war on Newcastle Town Moor where there was a Lancaster,  Halifax and Stirling along with a Blenhiem, a Spitfire and Hurricane also a Meteor and Vampire. All of which had full access, I was 10 at the time, of course all the boys were  rushing to sit in the jets. I spent the whole day getting into everything and impressed the recruitment officer by identifying the silhouettes on the identification machine. Happy days
  • 11 months later...
Hello
Introducing the new Supermarine Spiteful
Scale 1/5
Span 2133 mm
length 2000 mm
Fiala 70 4T engine with starter
Weight in flight order 13.5 kg
Wing area 186 gdm2
the 1st flight will be scheduled in spring 2025 following the pilot’s motivation 😀
  • Like 9
