chris meek 1 Posted January 27, 2017 Share Posted January 27, 2017 Hi Robert, would it work to reduce the length of the pin so that the horizontal bar sits flush against the bottom of the retract unit - then lengthen the legs to get it back to original overall length. Difficult to explain but by doing that would you stop bending forces going through the 4mm pin? Or shim it up with an aluminium block drilled through for the pin to fit through - either way would increase the thickness of material that the bending forces are transmitted through and hopefully make it stronger. Hope the rough sketches explain what I'm thinking! Quote Link to comment Share on other sites More sharing options...
chris meek 1 Posted January 27, 2017 Share Posted January 27, 2017 Quote Link to comment Share on other sites More sharing options...
Robert Parker Posted January 27, 2017 Author Share Posted January 27, 2017 Hi Chris, The option "A", reducing the pin length cannot be done as the 12mm bar will hit the retract body sides, this would be an ideal option as all of the bending forces going through the pin. Option "B", inserting a shim / collar could be worth considering when I'm up to it. Regards Robert Quote Link to comment Share on other sites More sharing options...
chris meek 1 Posted January 27, 2017 Share Posted January 27, 2017 Hokey dokey, hope you're feeling better soon. Hopefully it will work ok. Chris Quote Link to comment Share on other sites More sharing options...
chris meek 1 Posted January 27, 2017 Share Posted January 27, 2017 Now Robert if you ever fancy designing a vickers Warwick for 2 x. 40 two strokes it would give me the full set, used as Air sea rescue for the strikes to Norway. Chris Quote Link to comment Share on other sites More sharing options...
Robert Parker Posted May 25, 2020 Author Share Posted May 25, 2020 Hi All, I have listed some details and articles from the build after a message I received. This has also reminded me that I still have not modified the u/c or flown her yet. Part 1. Quote Link to comment Share on other sites More sharing options...
Robert Parker Posted May 25, 2020 Author Share Posted May 25, 2020 Part 2 As I am almost finished my TF P40 build, I will revisit the undercarriage situation as here in Wales we are still in lockdown I still cannot fly. I hope this info is of help Doug Regards Robert Quote Link to comment Share on other sites More sharing options...
