Greg Minden Posted March 26, 2018 Share Posted March 26, 2018 Well - i don't have a wing yet - so no. I'm hoping that there is enough room in the landing gear bay so i can install a screw and nut plate arrangement that i can access through the wheel well. That is what i did on my big Tigercat and it worked out quite well. Quote Link to comment Share on other sites More sharing options...
Greg Minden Posted April 5, 2018 Share Posted April 5, 2018 Working on the top battery hatch , I discovered the fit was terrible and so I finally decided to just scrap it and make a new one. While that is in workup, I was able (thanks to Craig for his help) to get the dreaded F-16 top aft former fitted. Work continues slowly. Sorry for the double pic Edited By Greg Minden on 05/04/2018 00:31:38 Quote Link to comment Share on other sites More sharing options...
Greg Minden Posted April 15, 2018 Share Posted April 15, 2018 it's beginning to look like a Vulcan Quote Link to comment Share on other sites More sharing options...
Greg Minden Posted May 10, 2018 Share Posted May 10, 2018 some updates. First wing glued on. Detachable panel secured with 10/24 bolt and T nut accessed through the wheel well. 3D printed crewmembers. Gyro mounted under the removable canopy. Quote Link to comment Share on other sites More sharing options...
Chris Walby Posted May 10, 2018 Share Posted May 10, 2018 Hi, I could be wrong and I am sure more knowledgeable members will chip in, but I thought giros worked best located at the C of G as that's the position the aircraft rotates around...Just a thought to save you time later on if it needs to be relocated. Hope this helps and last but not no way least great look builds there. PS Darn...just read my post (else where) and I stand corrected , anywhere will do Edited By Chris Walby on 10/05/2018 06:35:09 Quote Link to comment Share on other sites More sharing options...
KiwiKid Posted May 10, 2018 Share Posted May 10, 2018 Really been enjoying your build Greg. I have just finished a slap together semi scale powered sloper as a bit of a practice for building a bigger Vulcan when I can fit it in the build queue. You have probably seen this presentation, but it has some really nice pics included: **LINK** Quote Link to comment Share on other sites More sharing options...
Greg Minden Posted May 10, 2018 Share Posted May 10, 2018 Thanks for your observation Chris. For most gyros it would be correct to place it on or near the CG but i chose this one because it will work away from the CG. Critical that it be located on the centerline though. Just plan on using the rudder function - and nws. Quote Link to comment Share on other sites More sharing options...
Greg Minden Posted May 10, 2018 Share Posted May 10, 2018 KiwiKid - thanks. I didn't know anyone was watching. Thanks too for the link. Great pictures. I had a chance to sit in the left seat of the Vulcan back in the 70s. I was struck by how small the cockpit was for the pilots. G. Quote Link to comment Share on other sites More sharing options...
Scott Edwards 2 Posted May 10, 2018 Share Posted May 10, 2018 Watching very closely Greg! I've built one for PSS. I would have loved to have built a full EDF one, but expense and lack of a decent runway killed that. Very interesed in watching yours grow 👍 Quote Link to comment Share on other sites More sharing options...
Greg Minden Posted May 24, 2018 Share Posted May 24, 2018 A little progress made: A couple servos installed. Tailpipes painted and tried out the color on some hatches. Canopy painted - crew installed too. Quote Link to comment Share on other sites More sharing options...
Greg Minden Posted June 18, 2018 Share Posted June 18, 2018 Leading edges and wingtips added. I decided to do a wingspan measurement and had a big surprise. This "78 inch" wingspan aircraft actually measures 83 inches. Wow - free inches! It was built right on the plans too. Nobody tell TN or he will want to charge more for it Ha Ha. Quote Link to comment Share on other sites More sharing options...
Greg Minden Posted June 24, 2018 Share Posted June 24, 2018 so the inlet and spinal work proved a bit challenging. Worked out ok though. Now for some serious glassing Quote Link to comment Share on other sites More sharing options...
Scott Edwards 2 Posted June 24, 2018 Share Posted June 24, 2018 You're definitely on the home straight now ! I will measure mine tomorrow and see if it's grown 😃 It's not an easy build is it ! Quote Link to comment Share on other sites More sharing options...
Greg Minden Posted June 25, 2018 Share Posted June 25, 2018 Scott - this is the hardest build i have ever done - especially with the warped ply pieces and all. Craig Cox is also building one and his also measured out at 83". It will be interesting to see how yours is. Greg Quote Link to comment Share on other sites More sharing options...
KiwiKid Posted June 25, 2018 Share Posted June 25, 2018 Very nice work Greg - really starting to look Vulcanish now. I have been enjoying a very detailed account of the development of the Vulcan in this book by Tony Blackman. So much (like powered control surfaces etc) was new to them at the time and seeing how they overcame problems is very engaging. For example, the cranked wing l/e was introduced to combat buffeting at high mach numbers which threatened to scupper the whole programme. Quote Link to comment Share on other sites More sharing options...
Greg Minden Posted August 30, 2018 Share Posted August 30, 2018 This is the spackling , filling and sanding stages before glassing. Got my graphics from Callie. Yay! Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted August 30, 2018 Share Posted August 30, 2018 Wonderful ! Quote Link to comment Share on other sites More sharing options...
KiwiKid Posted August 30, 2018 Share Posted August 30, 2018 You are making a splendid job of my favourite plane Greg - really looking great. Quote Link to comment Share on other sites More sharing options...
Greg Minden Posted November 12, 2018 Share Posted November 12, 2018 Painting is done! Quote Link to comment Share on other sites More sharing options...
KiwiKid Posted November 13, 2018 Share Posted November 13, 2018 Woot woot! Awesome job Greg. Now comes the fun part - putting on the decals. I have been having endless fun with my parky pusher Vulcan. Quote Link to comment Share on other sites More sharing options...
Craig Carr Posted November 13, 2018 Share Posted November 13, 2018 Looks great Greg... very well done. Mines waiting for it’s white coat (just done the tail as a tester)... I’m probably going to have to wait till the spring to get back into my spray booth (aka the back garden ) Wish I had the same Nevada climate that you have Quote Link to comment Share on other sites More sharing options...
Callsign Tarnish Posted November 13, 2018 Share Posted November 13, 2018 Hi Greg, is the build as per the plan? I only ask as the nose profile looks too long and slender for scale. Quote Link to comment Share on other sites More sharing options...
Craig Carr Posted November 13, 2018 Share Posted November 13, 2018 Mine is to plan and I’m sure Greg said he’s followed the plan exactly...on my photo I think the image is squashed/distorted Here’s another taken after planking the nose Quote Link to comment Share on other sites More sharing options...
Greg Minden Posted November 13, 2018 Share Posted November 13, 2018 Yup. Built right on the plan. The nose looks different in every picture i guess due to camera effects. LV weather today was low 38 , high 60. Quote Link to comment Share on other sites More sharing options...
Greg Minden Posted December 2, 2018 Share Posted December 2, 2018 Just adding a couple new pics to keep things alive - and a taxi test! **LINK** Quote Link to comment Share on other sites More sharing options...
