What to order
Peter's article covers the subject well. I have a couple of tricks that I use when estimating.....
Draw a rectangle to represent a balsa sheet and mark off how the various smaller parts might fit, for example the tailplane parts and how much spare there might be for other parts like formers etc. Juggling the shapes around to fit might reduce the material needed ( especially the tapered fin & elevators) , but make sure the grain direction is correct.
Decide whether 3 inch or 4 inch sheets are the most economical for any particular item. Also whether 48 inch sheets might be better ( a 50 inch span wing might use 48 inch sheets best - two 24 inch pieces from a sheet and two spars from each length -remembering that tips are added! )
Double check to see if there is anything you missed - it.s very easy to overlook that the LE & TE are both on top and underside. Easy to order only half as much as needed! Same with spars. Also ply doublers and balsa doublers can be hard to spot. Spar webbing can be easily overlooked but it takes a fair bit of balsa. Underside sheeting is often unnoticed too.
Look to see how much 'scrap' will occur - for example the tapered rear fuselage sides might have lots of scrap that can be usefully employed to avoid buying an extra sheet. Maybe the few 1/8 ribs required can be made from this.
Trying to get a nice lightweight sheet for the tailplane parts will help build a light model.
For anyone new to building make sure you cut the larger parts first. If you make a mistake it's easy to re-use the duff parts to make smaller items. For things like LE sheeting just allocating certain sheets for this by masking tape labels and cutting a little oversize leaving the excess for other areas like centre section sheeting.
