Hi-viz Wind SockhH
Nobody in their right mind would pinch one of THESE.
Ours is on top of a high scaffolding post bolted to a metal bracket - undo the top bolt to lower the post. You just need to fasten the sock via a swivel to an arm about 18 inches long on a suitable bearing to allow it to swing in the wind.
Edit - just noticed that this new model comes with an adapter to drop straight onto a 7mm diameter pole.
Edited By Gary Manuel on 04/12/2016 21:02:09
