Laser Engines - Technical questions
Jon H
Posted by bert baker on 23/12/2017 09:36:57:
Is this the one reputed to give more power
yes this is 9mm vs the old Irvine at 8.5. All 150, 155 and 180 engines since 2006 have had this fitted as standard and 120's have had it since 2012
Percy has it pretty much covered there.
The 61 was relatively long stroke and almost the same size as our current 80 in terms of its external dimensions. It was a powerhouse though and even now gives 60 4 strokes a run for their money. Its power to weight is not comparable to a modern engine however due to its large physical size. My restored 61 is a beast though and even though the wear on the rockers means its impossible to keep the valve clearances where they should be it goes like a train.
The 62 was developed from the 50 which was in turn developed from the 45. The 45 used the same bore as the 61, the 50 an intermediate size and the 62 the same bore as the 75 and 90. When the range was bored again in 92 we ended up with 70, 80 and 100 which remain in production today.
Trebor, rings are an interesting one as we had real trouble with them in 2016. The issue was not our fault but to resolve it we had to come up with a new method of production and the ring I sent you is of the current type. As you probably saw it has a very high tension and forms an excellent seal with the bore. This is particularly noticeable in engines that have many hours on them and the bore is somewhat worn. In any event the current rings, in combination with some other tweaks, have really improved the performance of the engines and I'm really pleased with how they are performing. I just need to make more of them.
Once I get back after new year I hope to really make some progress.
if the liner looked clean then its not really a big issue. also the chrome/nikasil liners don't tend to glaze up like a steel liner. a little go with some went n dry or scotchbright wouldn't hurt it but its also not vital.
at the end of the day it comes down to the condition of the liner. if its grubby and slightly scratched then its worth a little treatment, if its pretty clean then its not super important.
I think I was lucky, there was no play or scratches in the bearing surfaces. All I had was 2 small marks as the valves touched the piston top on one engine. They were the kind of marks you'd get by tapping a teaspoon handle on alloy and I couldn't see a problem with the valve seating as it was clean all the way round.
Steve D,
Do you have experience with your chicken hopper system with laser V engines. I am presuming that one needs four tanks for two cylinders, or can the system work properly with one large tank feeding two small ones? (or even one tank feeding one small tank?) I was going experiment with all of these, but thought it would be simpler to seek expert advice first!
This topic is now closed to further replies.
