cymaz Posted April 13, 2019 Share Posted April 13, 2019 Hope I’m not hijacking the thread. Three of us have been hard at work building a Giant Mannock Myself and the other builders have been busy. Work has continued on the wings and tail surfaces. The engine and it’s reduction gear has been built and tested. HERE Quote Link to comment Share on other sites More sharing options...
Chris Freeman 3 Posted April 16, 2019 Share Posted April 16, 2019 I had a Giant for many years until I sold it, had a quadra 32cc that gave it a very realistic performance. Bodo was a true master at model design as his designs are always good flying aircraft and easy to build. Quote Link to comment Share on other sites More sharing options...
cymaz Posted April 28, 2019 Share Posted April 28, 2019 Brian ( builder) has redrawn the front to accommodate the reduction drive. The cowl sides will be working doors to get to the engine, cooling and ducting will be designed. Needing to spend some money for the Giant Mannock build now. I’ve opted for twin Rxs , batteries and switches. Each Rx will control one half of the plane. It may seem like overkill to some, but the effort Brian is going to I’m not going to skimp on my part. He also found a 1/3 scale Vickers and Foster mount he had kept in a draw or years....great! Still need to get wheels, rigging wire and fixings, cockpit panel, etc. A work colleague said he would 3D print up a pilot bust. Does the OP ( Paul )mind if I use this thread to log the build ? Edited By cymaz on 28/04/2019 07:56:00 Quote Link to comment Share on other sites More sharing options...
cymaz Posted May 8, 2019 Share Posted May 8, 2019 More goodies arrived today, added to the rest of the collection Quote Link to comment Share on other sites More sharing options...
stu knowles Posted May 8, 2019 Share Posted May 8, 2019 just a suggestion, change your batteries for the larger 'C' size. Unless you have been extremely creative, the all up weight will not be an issue so the extra weight is insignificant. On a model with a high servo count and long leads don't believe that AA size cells have enough spare capacity. My Futaba servo tester using just a 1 amp load condemned all of my AA size Eneloop batteries. I thought that it was a duff tester to begin with but now believe that batteries of this type while having a high capacity do not have the ability to liberate power quickly enough under high demand. Quote Link to comment Share on other sites More sharing options...
J D 8 Posted May 8, 2019 Share Posted May 8, 2019 Looking forward to seeing more on this project. Quote Link to comment Share on other sites More sharing options...
Paul james 8 Posted May 8, 2019 Author Share Posted May 8, 2019 Sorry I haven't responded, not got round to sorting mine yet, got so many models now I'm not sure which to get in the air first!! Will be interesting to see what you put on yours!! Quote Link to comment Share on other sites More sharing options...
cymaz Posted June 16, 2019 Share Posted June 16, 2019 First of the fuselage formers are being set. The front one that is an odd shape to use as one of the bearers for the reduction drive Quote Link to comment Share on other sites More sharing options...
cymaz Posted July 31, 2019 Share Posted July 31, 2019 Work continues on the engine bay. Brian is a legend in his building prowess. As well as the engine being bolted to the main firewall, two bearers come through from the rest of the front formers and sit on cross rails to take the strain off the engine bolts.... Quote Link to comment Share on other sites More sharing options...
cymaz Posted August 4, 2019 Share Posted August 4, 2019 Front formers near completion ( I’ve no idea why it’s suddenly gone sideways ) Quote Link to comment Share on other sites More sharing options...
cymaz Posted September 1, 2019 Share Posted September 1, 2019 Update.... 1/3 scale pilot from Jim Reeves has been ordered. Also Brian has started on the switch hatch, servo mounting and tail. Quote Link to comment Share on other sites More sharing options...
David Davis Posted September 1, 2019 Share Posted September 1, 2019 Posted by cymaz on 04/08/2019 17:58:57: Front formers near completion ( I’ve no idea why it’s suddenly gone sideways ) I've had that problem too. Don't know how to revolve them either. Quote Link to comment Share on other sites More sharing options...
Pete Collins Posted September 1, 2019 Share Posted September 1, 2019 Going back to the original post. If you find that you're still lacking aileron response, one thing worth trying is to add lots of differential. I know it's usually used on high aspect ratio gliders but It sometimes helps on bipes and High wing scale types. Quote Link to comment Share on other sites More sharing options...
cymaz Posted October 20, 2019 Share Posted October 20, 2019 Build moves on. Mick- the pilot approves of his cockpit, although , I haven’t the heart to tell him he will soon lose his legs below the knees Quote Link to comment Share on other sites More sharing options...
J D 8 Posted October 20, 2019 Share Posted October 20, 2019 Going to be a bit of a beast. Quote Link to comment Share on other sites More sharing options...
cymaz Posted October 20, 2019 Share Posted October 20, 2019 Posted by J D 8 on 20/10/2019 21:03:53: Going to be a bit of a beast. Hopefully! Should be almost done by March. Quote Link to comment Share on other sites More sharing options...
cymaz Posted November 8, 2019 Share Posted November 8, 2019 Servos for elevators and rudder are in and the twin Rxs Quote Link to comment Share on other sites More sharing options...
cymaz Posted November 14, 2019 Share Posted November 14, 2019 More tail work done Quote Link to comment Share on other sites More sharing options...
Paul james 8 Posted November 22, 2019 Author Share Posted November 22, 2019 Never did get round to converting my electric one to IC, which is handy as I've just found an excellent local field that drains well that I can fly electric models from. Will post a couple of photos once I dig it out of the shed and sort some batteries for it.👍🙁 Quote Link to comment Share on other sites More sharing options...
Geoff S Posted November 22, 2019 Share Posted November 22, 2019 This is very impressive and will be great in the air. That fin shape is very familiar - there's a (much) smaller version staring me in the face as I type. Geoff Quote Link to comment Share on other sites More sharing options...
Cliff 1959 Posted January 21, 2020 Share Posted January 21, 2020 Hi Geoff, guess what I've just acquired? It's three quarters finished so a bit to do but you mentioned your keeping yours electric after all. I was wondering what your setup is? Any details would be helpful Edited By Cliff 1959 on 21/01/2020 10:02:14 Quote Link to comment Share on other sites More sharing options...
cymaz Posted January 27, 2020 Share Posted January 27, 2020 Update...tail has now been covered! That’s Brian, Master Builder. I just get to fly it Edited By cymaz on 27/01/2020 22:18:51 Quote Link to comment Share on other sites More sharing options...
cymaz Posted March 16, 2020 Share Posted March 16, 2020 Working on the exhaust pipes and Brian has been busy on the U/C Quote Link to comment Share on other sites More sharing options...
Cliff 1959 Posted March 16, 2020 Share Posted March 16, 2020 That's looking really impressive, makes my standard Mannock look a bit of a tiddler, can't wait to see the finished model, are you fitting ailerons on both wings? Quote Link to comment Share on other sites More sharing options...
cymaz Posted March 17, 2020 Share Posted March 17, 2020 Cheers Cliff, yes I believe the builder is. Quote Link to comment Share on other sites More sharing options...
