Nick Cripps Posted November 3, 2020 Share Posted November 3, 2020 Excellent project by the way, John. You and Brian have done a great job. Quote Link to comment Share on other sites More sharing options...
cymaz Posted November 3, 2020 Share Posted November 3, 2020 Yep...choke Quote Link to comment Share on other sites More sharing options...
cymaz Posted November 8, 2020 Share Posted November 8, 2020 She’s off the healing bench and on her own legs Edited By cymaz on 08/11/2020 17:49:39 Quote Link to comment Share on other sites More sharing options...
cymaz Posted November 8, 2020 Share Posted November 8, 2020 One more. I hope you can just make out the fuel fill overflow under the starboard rocker cover. The pictures aren’t very clear as the light was bad Quote Link to comment Share on other sites More sharing options...
cymaz Posted November 22, 2020 Share Posted November 22, 2020 Her ladyship now resides in my garage. The weather is too dark when getting back from work to assemble it in the evenings. Next weekend it will all be put together if the weather holds. We’ll then run the engine up again. That’s a 26x10 Aerostar prop on the bench Edited By cymaz on 22/11/2020 14:20:33 Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted November 22, 2020 Share Posted November 22, 2020 Looking great Cymaz. What are those aerostar props like then ?, I always use Falcon Props on the bigger stuff. Mind you, having just checked, the Aerostars come in under half the price. D.D. Quote Link to comment Share on other sites More sharing options...
cymaz Posted November 22, 2020 Share Posted November 22, 2020 Aerostar prop are good. Very little if any balancing needed and a lovely varnish finish. Several club mates have started using them. Quote Link to comment Share on other sites More sharing options...
flight1 Posted November 22, 2020 Share Posted November 22, 2020 looking good there Pete, Brian has done a great job looking forward to see it aloft and I concur that those aerostar props are good too, nice and efficient profiles. Quote Link to comment Share on other sites More sharing options...
cymaz Posted November 28, 2020 Share Posted November 28, 2020 Thank goodness Mrs C has a large kitchen. Finalised the rigging and doing the cg Quote Link to comment Share on other sites More sharing options...
cymaz Posted November 28, 2020 Share Posted November 28, 2020 Checked CG, sits level at plan @ 143mm. RCPlanes cg calculator says 160mm Total weight : 12.8kg / 452oz Total wing area of two wings : 3008”sq wing cubic loading of 4.7 ( trainer loading) or 22oz/ sq ft ( 1 1/2 lbs per sq ft) Have I got the maths correct! Edited By cymaz on 28/11/2020 15:22:33 Quote Link to comment Share on other sites More sharing options...
Geoff S Posted November 28, 2020 Share Posted November 28, 2020 Actually, I think it's slightly better than that. 3008" sq = 21' squ (actually slightly less at 20.88) and weight = 452/16 = 28.25 lbs so wing loading = 28.5/20.88 = 1.36 lbs/squ ft But not a small model - in fact officially a large one Looks good - let's hope it looks even better in the air. Geoff Edited By Geoff S on 28/11/2020 15:59:36 Quote Link to comment Share on other sites More sharing options...
jrman Posted November 28, 2020 Share Posted November 28, 2020 Edited By jrman on 28/11/2020 16:05:11 Quote Link to comment Share on other sites More sharing options...
cymaz Posted November 28, 2020 Share Posted November 28, 2020 Now going to finalise the paint masks from Flightline Graphics. Nigel W has been a great help. jrman....the tail is level at the current 143mm cg. Edited By cymaz on 28/11/2020 16:54:57 Quote Link to comment Share on other sites More sharing options...
cymaz Posted December 5, 2020 Share Posted December 5, 2020 Got a video HERE which may interest Quote Link to comment Share on other sites More sharing options...
Dad_flyer Posted December 5, 2020 Share Posted December 5, 2020 Nice job. I particularly like the exhausts. Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted December 5, 2020 Share Posted December 5, 2020 Nice job, a nice satisfying start too Cymaz. D.D. Quote Link to comment Share on other sites More sharing options...
cymaz Posted December 5, 2020 Share Posted December 5, 2020 The exhaust pipes are workable. The engine was warm and had been started before hand. I can’t abide watching videos of people trying to start cold engines for minutes on end Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted December 5, 2020 Share Posted December 5, 2020 I was teasing Cymaz , but it doesn't come across in print LOL Either way it's a Cosmic effort Mate. Can't wait to see this baby in the air. D.D. Quote Link to comment Share on other sites More sharing options...
extra slim Posted December 5, 2020 Share Posted December 5, 2020 Is it me or does the pilot seem to take a sharp intake of breath at full chat??.. lovely model, just need to settle the pilot down for the maiden, give him a brandy!! Quote Link to comment Share on other sites More sharing options...
cymaz Posted April 19, 2021 Share Posted April 19, 2021 (edited) Not posted a while. We’ve had issues with the reduction drive. On checking it out after the ground run it was noticed that the toothed belt was not quite the correct profile for the pulleys. Changed the pulleys to poly vee belts. This didn’t work as the drive pulley was too small a radius causing belt slip. Went back to the toothed belt with correct profile...these have snapped on starting? Anyhow, this has all happened while the plane is sitting safe on the ground. After a meeting we’ve decided to place the engine further forward on a mounting plate between the original engine bearers. It involves just filling in the exit holes for the sparking plug and exhaust pipes. The pipes will now exit under the middle of the rocker covers, slightly more scale..ish. The biggest prop I should be able to use is a 20x 6 for the Evo 33gx, not a great change from the original. This will provide much more robust and reliable power train. The aluminum plate in the photo is just a template. The real one will cover the whole of the bearer and provide a useful shelf for some ballast Edited April 19, 2021 by cymaz Quote Link to comment Share on other sites More sharing options...
cymaz Posted June 6, 2021 Share Posted June 6, 2021 Just come back from flying her for the first time. Everything was great. I had to mix in throttle / rudder to help with keeping it a bit straighter on take off. The plan cg of 5 5/8” (143mm) was dead right The Evolution 33gx and 20x6 Aerostar prop is just the right combination for slow, scaled controlled flight. Needs a tiny amount of power on landing and a blip of throttle to flare out. 4 Quote Link to comment Share on other sites More sharing options...
cymaz Posted June 7, 2021 Share Posted June 7, 2021 1 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted June 7, 2021 Share Posted June 7, 2021 Nice flight, certainly scared the sheep! Quote Link to comment Share on other sites More sharing options...
Andy Gates Posted June 7, 2021 Share Posted June 7, 2021 I noticed that too Ron. I was watching some vidoes yesterday of some flying with sheep in the next field. I wonder if a service could be offered to round sheep up with planes? I used to fly in a public park many years ago and quite often dogs would take a liking to the plane and chase it round the field, which was great until landing time! Great result there Cymaz. I was worried when I saw the length was only 4m 45s and there was no take off until 2m30s but I am glad it went well for you. Quote Link to comment Share on other sites More sharing options...
cymaz Posted June 7, 2021 Share Posted June 7, 2021 Many thanks ☺️....The second flight was better. Dialled in some throttle/rudder mix. Took out all the trim and put it in the Futaba servo Sub trim menu. I know that’s a cheat but it won’t do any harm with this plane. Also this landing , I’d forgotten to turn off the high idle switch. Greased the second landing ? Quote Link to comment Share on other sites More sharing options...
