Basil Posted February 16, 2020 Share Posted February 16, 2020 I am having trouble sourceing some reasonably priced the main wheels. can any body have any suggestions? Thank you in advance Barry Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted February 16, 2020 Author Share Posted February 16, 2020 J.Perkins stockists should be able to get white hub wheels at about £8. J.Perkins lists them on their website Quote Link to comment Share on other sites More sharing options...
Steven S Posted February 16, 2020 Share Posted February 16, 2020 I bought some replacement wheels for the E-flite Timber. E-flite: EFL5258 They are made of a nice firm foam, 4 1/4 dia and 1 1/2 wide with a 0.13 hole that can be drilled larger. I haven't installed them yet so no picture in my album. Edited By Steven Shaw on 16/02/2020 15:08:07 Quote Link to comment Share on other sites More sharing options...
Basil Posted February 18, 2020 Share Posted February 18, 2020 Thank you Peter & Steven for your feed back. I will follow these up. Regards Barry Quote Link to comment Share on other sites More sharing options...
Basil Posted February 22, 2020 Share Posted February 22, 2020 Peter , on the plan it quotes '4max PP-rack 4260 mount' for the motor. I cant find this item anywhere. Could you please give me some guidance on a motor mount. ( Sorry to be such a pain). Many thanks Barry Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted February 22, 2020 Author Share Posted February 22, 2020 This is the type of mount but longer. **LINK** Seems the only size that they have in stock. J.Perkins do a plywood kit that can be cut to suits as adjustment **LINK** Hope this helps Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted February 22, 2020 Author Share Posted February 22, 2020 You could just build a plywood box onto F-1 as a mount. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted February 22, 2020 Author Share Posted February 22, 2020 Of course!!! The simple answer. Stand off tubes. **LINK** Note that you will need to buy screws etc from the same scource. Buy on line now and you should have them by Tuesday. Just measure from the rear of the motor to the F-1 to get the length you need. A bit of variation is not a problem Edited By Peter Miller on 22/02/2020 14:47:36 Quote Link to comment Share on other sites More sharing options...
Steven S Posted February 22, 2020 Share Posted February 22, 2020 I am making a plywood mount for mine. I've just cut out the parts and still have a lot of clean-up to do. Quote Link to comment Share on other sites More sharing options...
Basil Posted February 23, 2020 Share Posted February 23, 2020 Many thanks to both Peter and Steven for your comments. Peter I thought I was loosing the plot when I failed to find that originally quoted. I will have to consider both , Once again many thanks to you both. Barry Quote Link to comment Share on other sites More sharing options...
Basil Posted March 1, 2020 Share Posted March 1, 2020 With Peter's permission I have sent a plan to SELC with a view to cutting parts and or supplying a kit.. I am currently awiating to hear back from them regarding this matter. Barry Quote Link to comment Share on other sites More sharing options...
Old Geezer Posted March 1, 2020 Share Posted March 1, 2020 Steven, are the glue joints unsupported, or do you add triangular balsa strip to reinforce them? Quote Link to comment Share on other sites More sharing options...
Steven S Posted March 1, 2020 Share Posted March 1, 2020 The top and bottom pieces fit into the plate that mounts to the firewall and I am adding triangular pieces behind the motor mounting plate. Quote Link to comment Share on other sites More sharing options...
Tim C Posted March 3, 2020 Share Posted March 3, 2020 Nearly done, final tweets, struts, UC and glazing to finish. AUW 44oz with 2200 Lipo, power 290 - 300 watts on 11x 6. pilot 20gms, mix of 3 d print and blue foam. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted March 3, 2020 Author Share Posted March 3, 2020 That looks great. Ilike your engine, looks far better than mine!! Quote Link to comment Share on other sites More sharing options...
Steven S Posted March 3, 2020 Share Posted March 3, 2020 Posted by Tim C on 03/05/2019 16:44:36: I will post up a link to download the STL files for the parts I use, so far it’s the end rib and flap hinge. Tim - were you still planning on adding more 3D files. I wouldn't mind making a set of your motor parts and also your pilot for my Li'l Cub. Your finished model is looking very nice by the way. Quote Link to comment Share on other sites More sharing options...
Tim C Posted March 4, 2020 Share Posted March 4, 2020 Steven, I will post up the files for the dummy motor, there are 33 separate parts, the exhausts use a hack technique where they are bent using hot water , PLA becomes malleable aft low temps so can effectively be moulded, I had to make up a jig to hold the 4 into 1 , while I glued it. Note that it is for a 28mm dia motor and X mount 40mm dia from recollection, a 35mm motor will fit in the crankcase, but you would need to be inventive with the motor mounting to get it to fit. The pilot is a rehash of this https://www.thingiverse.com/thing:3648714 on thingiverse, chopped it around a reangled to fit the cub, and used a lump of blue foam as the rear body half, used thin wall on print settings and minimal fill, resulted in 20gm weight, not bad for quite a large figure, the sunglasses were laser cut from a piece of shampoo bottle Quote Link to comment Share on other sites More sharing options...
Basil Posted March 5, 2020 Share Posted March 5, 2020 Gentlemen , I see from the posts that at least 2 of you are using 2d cutting!!!!!!!!!!. I might be wrong about that but some are using 3d printing. I have had an offer regarding such equipment and would like to discuss this with those of you that know,. rather than cloud the forum would you contact me using a PM witha view to disscussion ? . There are many things that I would like to clarify. Thanks in advance. Barry Edited By Basil on 05/03/2020 09:35:13 Quote Link to comment Share on other sites More sharing options...
Steven S Posted March 5, 2020 Share Posted March 5, 2020 Thanks Tim - I bought an E-Flite "Power 15" motor for mine, which is 35mm dia so I will see how inventive I can be and make it fit. I found an "Ken" doll at a boot sale, but he weighs 195 grams before surgery so I don't think i will be using him. My nephew has a 3D printer and doesn't mind making me parts. I see you are inserting your battery from inside the cabin. I'm thinking of doing the same, but until I join and cover my wing which is still in 3 main pieces, and mount my motor I'm not sure where my C of G will end up. Hi Barry - I cut out my motor mount box with my Dremal scroll saw. Quote Link to comment Share on other sites More sharing options...
Tim C Posted March 5, 2020 Share Posted March 5, 2020 Hi Steven, I was not sure where my cg would end up, but with a 2200 Lipo is just a few mm in front of the plan location, which is good news, I am using ultralight fun Cub wheels and the motor only 70gm, so I am guessing your going to be pretty near with your setup. There still a few bits and bobs to go but most of it is on or in front of the cg line so should not cause an issue. I have a hatch in the underside and the battery locates easily in the hole and through the former. i will post up the rest of the styles next week, I am away till then, you could print the motor parts at 110% which would give you 44mm dia internally and not look out of place, I think mine in retrospect was a tad small in any event, but fitted my motor dimensions. Quote Link to comment Share on other sites More sharing options...
Tim C Posted March 5, 2020 Share Posted March 5, 2020 Basis feel free to pm me with any questions, there are some excellent threads on the forum on both 3d printing and laser/cnc cutters. my build is totally hand cut, I have deviated in a number of areas from Peters plan. 3d printing was a way of adding details for a more scale experience and custom building fittings such as flap hinges and snake supports. I have a ANET A8 3d printer, it’s a low cost entry level machine with no mods, more than adequate for anything I have produced so far Quote Link to comment Share on other sites More sharing options...
Basil Posted March 9, 2020 Share Posted March 9, 2020 I have heard back from SELC regarding cutting parts for Li'l Cub.They are going to proccess the Pdf that I sent them and cut some parts. It seems that this has been precipitated by a request from an additional person. They are now saying that a kit will be available . If you want one please contact them as this may reduce the price by spreading the cost of turning the plan into cutting data. According to Peter Sarik do not produce a plan so they will may supply that as well!! Please spread the word and help to cut the initail cost Barry Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted March 9, 2020 Author Share Posted March 9, 2020 Once they have done that they will put the plan etc up on their website. I will send them pictures frommy files for that. Quote Link to comment Share on other sites More sharing options...
