Warnings won't let the transmitter start DX7
Yorkman
Well, I've managed to lock myself out of my DX7. Trying to set a warning for the gear switch position, so I don't switch the model on with u/c selected down. I did it no problem before-gear switch position 0, warning. However, this time I fiddled about and also set a warning, on the gear channel, for 'servo position over 0%'
So now, if the switch is selected 'down' I get the 'warning, gear down', and if l select 'up' l get 'warning, servo position over zero percent' and I can't get past the warnings into the menu to sort it out.....
HELP!! Or I'll have to rebind and reprogram all the mixes....
