2 or 3 questions please, need some wise advice
Looking forward to a return to model flying after a 50 year lay-off...
I left aeromodelling flying control line, hence these silly questions.
I'm building a Ben Buckle Standard Buccaneer wich is going really well, great to be with balsa again. While many scarf joints dry, a few questions come to mind:
Covering. I have only tissued and doped, but I think this plane (electric) would be best done in something modern and easy for me to get a good result, preferably self coloured and robust enough for a few hard-landings.
Advice please.
2
Tailplane fixing
The plan shows the classic rubber bands to attach the rear tail/rudder assembly, but in the internet here is a fabulous buccaneer with the tail built onto the fuselage.
Advice on this change to the plan please.
3
Prop size
Motor is an Overland ThumperT4249/10 and the motor sticker states a prop from 13" which seems huge to me but also no pitch stated.
Advice please. I want this plane to be a lazy slow cruiser.
That's it for now, no doubt a few more to come.
Thanks in advance, Graham.
The film covering from HobbyKing is very good and therefore popular ( that is some colours are often out of stock) and cheap. Recommended, but not very vintage though. A proper covering iron is good but you could manage with a domestic iron - test with a sample as per the old Solarfilm instructions. Make sure no residue is left on domestic iron to ruin your shirts! Try to find the online Solarfilm video by Derek Hardman himself ( genius Solarfilm etc inventor) - probably on YouTube.
Tailplane, if it's RC then fixed is better so the elevator trim is not affected.  However its a big tailplane and it depends on the size of your car.  Maybe bolted on is possible.
I don't know enough about that motor to be certain - but my guess is it may be too powerful. Get more advice. For a basic idea vintage models seem to be fine on 50 watts per pound weight.
Edited By kc on 16/02/2020 12:24:12
Hobbyking covering is good...if you canfin some.
Solarfilm is excellent and they still have stocks of many types and colours.
**LINK**
Glue your tailplane on. This makes sure that it doesn't move..I do this with all my vintage types.After all,you have elevators for any trim correction needed.
While I am far from expert on electric power my much bigger Super Scorpion flies on a far small motor turning a 12"prop
**LINK**
This is the spec of my Super Scorpion at 4-Max.It flies like a dream
Thank you all, great info.
I have an unfinished Super Scorpion which this motor was bought for, but as this is the one being readied for 2020 learning, thought I would use it.
Bought the kit from Servo and they thought the motor ok.
I don't have to use full throttle!
Is doped nylon not on the covering list? (weight, too tricky etc?)
I have an unflown vintage Stol that was covered by the builder back in the 80's and the yellow colour and weight seems great.
I cannot find an Overlander 4249/10 listed but there is a 4240/10 which is 500 watt or so. much too powerful for a 4 or 5 pound vintage model I reckon.
Peter's Super Scorpion setup would surely work for the Buccaneer 66 inch too. ( is the Super Scorpion much bigger ?) Of course the trick is to use the weight of the Lipo to achieve CG without lead, so getting the Lipo well forward is probably the thing.
I have a 2200 Mah battery right under the motor with the rearend flush with the front of the nose.
I would say that the Super Scorpion may look bigger but is probably lighter.
Doped nylon is a possiblity but horribly expensive...have you seen the price of dope? It also asks for warps etc.
I have been modelling for an awful long time (1953!!)and the greatest blessing that we have ever had is iron on films.
Edited By Peter Miller on 16/02/2020 13:57:29
911hillclimber
"I don't have to use full throttle".
Yes that is true but retaining a big prop can give torque issues even if you don't use full throttle. At say 300 W a 13" prop will require more torque than a 12".
Torque is not usually an issue when flying normally but it can be in those tricky low slow situations near to the ground when there is a temptation to apply 'plenty' of power to get out of trouble.
Best to use an appropriate size motor and prop that is fit for purpose.
Ok:
then which motor/prop would be good for this plane? The plan says a weight of 5Lbs maximum.
Now is the time to change things.
What iron-on covering would give a vintage look? Not sure I want the 'see-through' bright colours.
There is a blue/cream Buccaneer on google that looks so right, looks like tissue of old.
Hillclimber sir, give George at 4max a ring ( sorry can't do links) but he will give you good advice, you really don't need a lot of power with vintage types.
As to covering, don't use film, totally out of keeping in my mind, my local model shop (addlestone models) has a roll of vintage cream tex in stock, saw it my self only this morning, that would look lovely with maybe some blue trim ( humbrol enamel?).
Agree with all the advice above - re the motor you mentioned - I had a similar motor on the front of an early Ripmax artf Wot4 which would pull it into the air in about 10 feet, so your open frame vintage plane would be vastly overpowered. Your 70 watts per pound will fly a vintage 3 function very comfortably and in character - and as recommended by Paul d - give George a ring, he'll put you right,
Posted by Steve Nash 1 on 16/02/2020 18:27:33:
The best covering for a lovely big vintage model like that is Solartex iron on fabric if you can find some. Its hard to find now but very good. I stockpiled a hoard of it after they ceased production. It does come up on ebay now and then or at swap meets.
I agree with Steve. Solartex will be much stronger than film and it's much easier to apply, just make sure that you don't over-shrink it and introduce warps. Solarfilm, the business which made Solartex, closed down last year but there are still a limited number of colours is still available her: **LINK**
Picture of my Junior 60 covered in Solartex Orange.
Picture of my double-sized Tomboy finished in yellow nylon and Vintage Red Solartex and my much younger self!
My Senior Telemaster finished in Vintage Orange, Vintage Blue and Natural Solartex. The Vintage colour range is supposed to look like doped silk and is transluscent.
Senior Telemaster
Super Sixty finished in Vintage Red Solartex.
If you want to use nylon, a lot of people these days use mica film or Doculam under the nyon first. That stops the nylon absorbing too much much dope and adding excess weight. Others use tissue over mica film or doculam. this produces an authentic vintage finish which is virtually puncture proof. I haven't tried it myself but I plan to do so on a Sharkface.
Finally have you thought of joining a local club Hillclimber?
Edited By David Davis on 17/02/2020 08:29:08
Thanks to everyone as ever, very helpful indeed.
Will be ordering the motor after a chat and the film from Addlestone this afternoon, the 'cream' colour was the colour I wanted for the plane.
Having never used these modern (to me) coverings, I need to choose the easiest one!
Ref a local club? Yes, I plan to join the local group in the spring who have their own facilities and hopefully a few with a sympathy for an absolute beginner who can guide my controls a touch....
The pre sanded wing is now on the fully sanded fuselage, tail surfaces to be built and glued to the rear yet, but the plane looks great, really nice size.
This is not my usual hobby, I race cars and do motorsport a lot, but this is so different and will be great mid-week.
Looking forward to light blue skies and a gentle sun in the middle of Shropshire soon!
Posted by 911hillclimber on 17/02/2020 08:28:08:
Thanks to everyone as ever, very helpful indeed...
... This is not my usual hobby, I race cars and do motorsport a lot, but this is so different and will be great mid-week.Looking forward to light blue skies and a gentle sun in the middle of Shropshire soon!
Until I retired to central France in 2015 I was a member of the Shropshire Model Flying Club which flew off Forton Aerodrome near Montfrord Bridge, just off the Shrewsbury-Oswestry road. Nice bunch of lads. They even had three trainers which beginners could use on buddy boxes and both Mode 1 and Mode 2 radios and instructors.
I still think a tex finish is better than film for a vintage model and if you can't find an appropriate colour in the limited Solartex range, there is a similar product produced by the German company Oracover. It's called Oratex **LINK**
That said, film would be lighter and the model would fly more slowly.
The Club I'm thinking about is by Alverley Country Park close to Bridgnorth.
Not sure exactly where it is as location is 'secret' until you join.
Cream solartex covering now ordered from Addlestone, 3 meters which should wrap the lot.
Awaiting a reply from 4Max.
Does engine power have a relationship with wingspan or simply weight/flying style?
​​​​​​ the 'cream' colour was the colour I wanted for the plane.
Good choice of colour for a vintage model. The plane in my profile picture is covered in cream and blue solartex. The cream can be combined with a good variety of contrasting colours if required. My plane should be in the April RCM&E in the ‘All Write’ column, so you can see it there too.
With regards to your motor, I'd consider two aspects:
1. You may need weight up front to help balance the model, so getting a smaller one may not be the best thing.
2. The motor which you have may seem massively over specified, but remember, it will only turn at a fixed(ish) speed. The power being absorbed (and thrust created) is entirely a function of the prop you fit, so just find a prop that will give you your required 350w at whatever the speed is at which the motor will turn. This is calculated by multiplying the kV number of the motor by the voltage of the battery that you're using.
Sorry if I've duplicated anything mentioned above by others but it seems to me a bigish motor hung out at the front may be a good thing in this instance.
Kim
Edited By Kim Taylor on 17/02/2020 11:37:44
Posted by 911hillclimber on 17/02/2020 09:46:22:..
... Does engine power have a relationship with wingspan or simply weight/flying style?
You need to have a motor, battery and propeller combination which is capable producing sufficient power to reach a speed in excess of minimum flying speed. If you want to take off from the ground you need a combination which will overcome the drag of the wheels on the ground. As a general rule of thumb, 50-75Watts per pound is adequate for a vintage model. As your model is about the same size as a Junior 60 or Super 60 but likely to be lighter, you could do worse than to take 4-Max's recommendations for these models in your Bucaneer. **LINK**
My dad has done a couple of vintage slow fliers. All of them have -
relocated ply firewall with motor screwed direct to it
vertical battery immediately behind the motor
access hatch on top of nose above the battery.
speed controller right behind battery
servos right behind speed controller
motor mounted using a long screwdriver, screwed straight into ply firewall, with a fixed wood block cowling around it
about 50w/lb AUW (including battery) - these things don't need much juice to stay aloft, they're essentially a powered glider with wheels.
I'm fairly sure he used 3S 2200mAh lipo on a Southerner of similar dimensions. Don't know exactly what motor or prop or ESC, sorry.
There is nothing stopping you using the motor you have and just putting a smaller diameter prop on to reduce the thrust and power consumption as long as the motor fits and the plane balances. With an electric motor the revs will not increase much unlike IC if that is where your experience lies. An 11x6 prop would reduce the power to around 275W and a 12x6 to around 350W on a 3 cell battery.
As Peter says, your 4240/10 would be fine for this model, at around 890kv even a 13*6 on 3S would only be giving you around 370W according to e-calc.
As for covering - am I the only one who used to get a gloss finish when using tissue or nylon back in the 60/70s? I would be happy using film on a vintage model. Tex would be tougher, comparable to doped nylon, but for this size of model film covering should be strong enough.
To answer in order:
Yes, I used to hillclimb my old 911 Porsche, my 'name' came from that a very long time ago!
Still have the car, still hill climb, but in a very different car now.
The BIG motor I have: v interesting thoughts on weight and power and prop size. I have had a nice simple reply from George.
He says:
4-Max PO-3541-920 motor
4M-ESC40A35
Prop 12 x 6 or 13 x 6
Batt: PPL-40C3S-2200
Refreshing to have a specialist reply with all the questions answered!
If I keep the Big Motor (I've modelled the cowl etc to install it) what Esc/battery spec do I need please?
I find this a bit of a mine-field.....
Edited By 911hillclimber on 17/02/2020 14:09:12
You could still use George's recommended esc, his 920kv motor will actually draw a shade more current on those props than your 870-890kv motor will. That looks to be a 40A esc which in theory would be good for 440W on 3S. Battery size will be a case of what size will fit. That 2200mAh could be taken as a minimum, it's a pretty common size as used in a lot of foam ARTFs. If there's room in the nose you could go bigger but both my Junior 60 and Black Magic give good enough flight times on 2200 3S packs though they both need a bit of lead too in order to balance correctly.
