Julian Murch Posted May 2, 2020 Share Posted May 2, 2020 Having followed the thread here about simulators recently I obtained one of the simulators from Flying Tech. Unfortunately as I seem to have an old Futaba r/c setup this has the large size din trainer socket whereas the kit includes only a mini din plug. I was advised how to wire up the din to jackplug lead and which contacts to use but I now have a problem. The pins on the din plug are very small and close together and my skill with soldering does not extend to this level of accuracy. My soldering iron has a large tip and although I could of course buy a thin version - that will not resolve my lack of skill. Does anyone know of a company that could make a bespoke lead. This is my first foray into r/c flying (good timing I know !) so I was hoping to use lock down to get at least some indication of what to do. Hopefully this could be done by email and by post. Quote Link to comment Share on other sites More sharing options...
David Hall 9 Posted May 2, 2020 Share Posted May 2, 2020 Lots of adapters available... start with a search like this.... Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted May 2, 2020 Share Posted May 2, 2020 The Component Shop Are worth a try Julian **LINK** I have been looking at the wiring diagram with a view to doing this for you But I see there are two alternatives and you can bet that we select the wrong one If you can be certain of your diagram I will solder this up for you Edited By Denis Watkins on 02/05/2020 10:02:30 Edited By Denis Watkins on 02/05/2020 10:03:39 Quote Link to comment Share on other sites More sharing options...
