gillyg1 Posted August 1, 2022 Share Posted August 1, 2022 I've used neoprene rubber, from a wet suit, x2 layers job done, or a mouse mat, incidently these suggestions came from the man himself RW, and i got my wet suit neoprene from a helmet someome left on the beach 👍 Quote Link to comment Share on other sites More sharing options...
RICHARD WILLS Posted August 1, 2022 Author Share Posted August 1, 2022 2 hours ago, Bruce Collinson said: Can’t resist asking; source of suitable tried and tested 6mm silicone rubber sheet? BTC Bruce is back ! Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted August 2, 2022 Share Posted August 2, 2022 Nice to see you, to see you…….. Quote Link to comment Share on other sites More sharing options...
Paul Johnson 4 Posted August 2, 2022 Share Posted August 2, 2022 I tried neoprene and found it too soft. The original issue was with my Hellcat (8lbs) which has twistnturn retracts fitted and has damaged countless die-cast trunnions until I used the 6mm silicone sheet. I have since used it on all my models, obviously it won't help a 90° landing approach 😉 Quote Link to comment Share on other sites More sharing options...
David Hazell 1 Posted August 2, 2022 Share Posted August 2, 2022 1 hour ago, Paul Johnson 4 said: I tried neoprene and found it too soft. The original issue was with my Hellcat (8lbs) which has twistnturn retracts fitted and has damaged countless die-cast trunnions until I used the 6mm silicone sheet. I have since used it on all my models, obviously it won't help a 90° landing approach 😉 So you stick it between the U/C itself and the mounting plate? Did you use 6mm longer self tappers to compensate? Quote Link to comment Share on other sites More sharing options...
Paul Johnson 4 Posted August 2, 2022 Share Posted August 2, 2022 Yup 1 Quote Link to comment Share on other sites More sharing options...
Bruce Collinson Posted August 2, 2022 Share Posted August 2, 2022 Can’t resist asking; source of suitable tried and tested 6mm silicone rubber sheet? BTC never went away, followed with interest but a long way from the finishing line! Paul, thanks for the link. Good tip that. BTC Quote Link to comment Share on other sites More sharing options...
Jonathan S Posted August 3, 2022 Share Posted August 3, 2022 Mine just arrived will fit before next flight Quote Link to comment Share on other sites More sharing options...
Paul Johnson 4 Posted August 3, 2022 Share Posted August 3, 2022 I hope we haven't started a rubber fetish.... 1 Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted August 3, 2022 Share Posted August 3, 2022 Looks like it's rubbing off. 1 2 Quote Link to comment Share on other sites More sharing options...
Paul Johnson 4 Posted August 5, 2022 Share Posted August 5, 2022 Morning All, As some of you are aware (Spitfire Thread) I have been working on 3D printed wheels and tyres. No doubt as most of you have found what is available commercially is always a make do and mend or 'Meehh that's close enough'. With all the effort I put into making my models look as good as I can, I have always not been happy with the wheels. The Spitfire wheels have turned out well, anyway I think they're good, so... After some discussion with Richard we are looking to try a range of wheels/tyres specifically for his models and will be available from his website. These will be made to order once all the designs are complete, Please be aware that 3D printing, especially the tyres, is a long process due to the printing requirements of the material used. To give you an idea a set of hubs 5 hrs, but a 2.75" tyre takes 9 1/2 hrs and a 3" tyre 12 1/2 hrs.... each! And that is if there is no print problems. I will try my best to get the design as close to the real item but will have to allow for the strength and integrity of the printed hub and wheel. The hubs will have oil-lite bearing inserts. To start with we discussed a set for the following of his kits, Spitfire 2.75" (complete), Mustang 2.75" and Hurricane 3" Once all is ready I'll let you know when it's on his website. An example of why I started this. I have a VQ models Hellcat 61" Which I like but wheels... see for yourself. Original supplied tyre and wheel. Not happy with them so tried the Hobby*ing 3" 'scale' wheels. Better but still Meehhh. So Roll out (excuse the pun) my design taken from drawings of the Hellcat. 2 Quote Link to comment Share on other sites More sharing options...
Paul Johnson 4 Posted August 7, 2022 Share Posted August 7, 2022 Just a quick update on the wheels, specifically the Mustang, one step back.... Birds nest soup anyone? (I wouldn't it's a bit rubbery) The print had come off the bed so it did it's own thing! I was trying a print to get a diamond pattern for the tyre but even on the piece that had printed wasn't very good. So... back to the CAD and after a lot of thought and re-design tried again. Now THAT'S looking better. Also solved the print release issue as well so now it stays put. The finished print and fit on the hubs. Also managed to find out how to add the text to the surface. These wheels are going on my P51 and decided to use up the last of the bearings as my wire legs are definitely 4mm exact. All the future wheels will have Oilite bearings in. As My model is the Berlin Express I just had to paint the white walls and red hubs. Fitted to my Mustang. I am currently working on the Hurricane wheels and Tyres will keep you informed, if your interested of course? 3 Quote Link to comment Share on other sites More sharing options...
Paul Johnson 4 Posted August 7, 2022 Share Posted August 7, 2022 Although this is the tyre for the Hurricane I've nailed the way to get tread patterns, I've used a block pattern this time. This has been printing for 6hrs and is at 50% 1 Quote Link to comment Share on other sites More sharing options...
Paul Johnson 4 Posted August 8, 2022 Share Posted August 8, 2022 Just waiting for the oilite bearings to turn up. 1 Quote Link to comment Share on other sites More sharing options...
Peter Jenkins Posted August 8, 2022 Share Posted August 8, 2022 They look so good Paul, I'm tempted to ask what tyre pressure you are using!🤣 1 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted August 9, 2022 Share Posted August 9, 2022 Excellent job Paul but shouldn’t the lettering be round ‘tother way, or are they for an Aussie version? 1 Quote Link to comment Share on other sites More sharing options...
Paul Johnson 4 Posted August 9, 2022 Share Posted August 9, 2022 There's a reason for that..... how many times when trying to read pressures etc on your car tyres have you had to swivel your head 180° to read it? Quote Link to comment Share on other sites More sharing options...
Paul Johnson 4 Posted August 9, 2022 Share Posted August 9, 2022 Ron, the picture you posted is interesting as it's an early 5 spoke wheel with a later ribbed tread. The best bit I found when trying to find out what pattern was used with what hub it turned out there were quite a few Spitfires with odd tyres fitted. Depending on what was available at the time of replacement. Quote Link to comment Share on other sites More sharing options...
Paul Johnson 4 Posted August 9, 2022 Share Posted August 9, 2022 Oh and as I spent 7 years in Aus as a kid it give me a little artistic license 🙃 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted August 9, 2022 Share Posted August 9, 2022 5 hours ago, Paul Johnson 4 said: There's a reason for that..... how many times when trying to read pressures etc on your car tyres have you had to swivel your head 180° to read it? Never, I get the wife to do that! 2 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted August 9, 2022 Share Posted August 9, 2022 As a matter of interest Paul, are you using TPE or TPU for the tyres? Quote Link to comment Share on other sites More sharing options...
Paul Johnson 4 Posted August 10, 2022 Share Posted August 10, 2022 The bearings have arrived the wheels will be going onto Richards Website in about a week.. These are going to Richard for someone who has the Hurricane kit. These have a 5mm axle. 2 Quote Link to comment Share on other sites More sharing options...
Jonathan S Posted September 2, 2022 Share Posted September 2, 2022 I have had a quick go on Fusion360 after all the good stuff going on here and tried to design a new version of Glens fancy prop bits. I see a number of FMS Mustang users put a cable tie in the prop holder to give them more pitch. My model seems to be using very little battery I wondered if a bit more pitch might give it a bit more punch. I have a Resin printer rather than FDM but its been a fun first design project. I will print them out and see what happens.... Would love to work with some guys to help design some bits and pieces Quote Link to comment Share on other sites More sharing options...
Paul Johnson 4 Posted September 2, 2022 Share Posted September 2, 2022 Jonathan The zip tie mod was designed for the standard 540KV motor. You shouldn't need it for the 580kv preditor motor. I get a 6.5min flight times with a 4AHR battery. If you have a watt meter see what amps you are pulling stationary. The Preditor has a max of 56A but you certainly don't want to be pulling that for more than a couple of seconds. Look into this before trying to mod it. I have the zip tie mod on my fms p51 540kv and my flight times have dropped from 9 mins to 5.5 mins. If you want to look into part design you need a good source of accurate drawings which you need to scale to the size of your model. Quote Link to comment Share on other sites More sharing options...
Jonathan S Posted September 3, 2022 Share Posted September 3, 2022 Paul, It was just one of the scale guys at my club thought the prop looked and sounded like it was going round but not doing much.... also 5 min flight I am using 40% batt. I might see if I can get it on my watt meter and maybe a luggage scale to see what's happening. From a design perspective i am new to cad and design but it really interests me so trying to thing of ideas of things to model. Quote Link to comment Share on other sites More sharing options...
