Ray Wood 4 Posted January 4, 2021 Share Posted January 4, 2021 Hi Peter, What a fabulous model, such an interesting tail, and the color scheme is one of my favourites, You have hit the spot with this one Regards Ray Edited By Ray Wood 4 on 04/01/2021 15:29:18 Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted January 4, 2021 Author Share Posted January 4, 2021 Hi Ray, THanks for that. Yes, when I saw that colour scheme I just HAD to build it. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted March 12, 2021 Author Share Posted March 12, 2021 Roll on March 29th and I can fly it again Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted April 19, 2021 Author Share Posted April 19, 2021 Well yesterday we had the best day for a year. I got my flying shots of the Minimax and then went to full rates. This model is fantastic. I flew square loops, square horizontal eights. Avalanches, Flick rolls and then Lomcevacs with ease. In fact I did about 5 with no effort at all and it never tried to bite once. The very low wing loading helps of course. 2 Quote Link to comment Share on other sites More sharing options...
Graham Davies 3 Posted April 19, 2021 Share Posted April 19, 2021 Great pictures Peter. I can attest to it's wide envelope. The climb out was so gentle, it was like a very benign trainer. Until you unleashed the full rates. I can see this being the sort of model that is 1st on the list when planning a day's flying. Graham Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted April 19, 2021 Author Share Posted April 19, 2021 Thanks Graham Yes, low rates a pussy cat that will turn into a wildcat at the flick of three switches. but one that never bites. Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted January 18, 2022 Share Posted January 18, 2022 It's in March RCM&E so we can all join in the fun. ? 1 Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted January 18, 2022 Share Posted January 18, 2022 We've got this one to complete, next club room project. Looking at a 35cc petrol. 1 Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted January 18, 2022 Author Share Posted January 18, 2022 That is very impressive Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted January 19, 2022 Share Posted January 19, 2022 You have a club room ? We have a leaky old caravan, and only enter it to get the safety fence and windsock out. I suspect you have more members than us..... That looks like a lovely build. Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted January 20, 2022 Share Posted January 20, 2022 On 19/04/2021 at 12:44, Graham Davies 3 said: I can attest to it's wide envelope. The climb out was so gentle, it was like a very benign trainer. Until you unleashed the full rates. I can see this being the sort of model that is 1st on the list when planning a day's flying. Sounds like an ideal second model as a follow on after a high wing trainer and an easy build for a novice. I have been searching the web and this looks like a 1500 Sport, the 1100 looks easier to build but very utilitarian. Peter where is the battery hatch? Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted January 21, 2022 Author Share Posted January 21, 2022 14 hours ago, EarlyBird said: . Peter where is the battery hatch? The battery hatch is under the nose from the cowl joint back 1 Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted January 21, 2022 Share Posted January 21, 2022 1 minute ago, Peter Miller said: The battery hatch is under the nose from the cowl joint back I have started the build, by thinking and planning about it.? Looks like it will be my first plan build as I can't find a laser cut plan pack. Looking at the full size I could build one in my garage. ? I wonder if I could scale it up for a Saito FG21? No not again you have learned not to mess with the design. ? My curious nature compels me to experiment. Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted January 21, 2022 Author Share Posted January 21, 2022 As build without a pre-cut pack it is pretty simple. All the ribs are basically the same. The formers are pretty simple .Tail surfaces are built up from strip. Get a copy of the plans printed off, cut out the formers and glue them to the wood and cut them out. A fret saw or better,a power scroll saw Will make light work of that. Ribs, make a ply template with a strip of 1/4" sq wood as a grip with a a couple of map pins to make sure it can't slide ad cut out all the ribs You will be amazed at how much money cutting your own parts out will save. Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted January 21, 2022 Share Posted January 21, 2022 Peter, Ideal for a novice plan builder then. Ideal for me then. Thanks Quote Link to comment Share on other sites More sharing options...
Clive Posted February 2, 2023 Share Posted February 2, 2023 Peter, how did you make the connection between esc and motor? The leads from the 4 Max motor only go into the closed cowling where the esc is located. There is o access to get your fingers into the space to make the connection. Maybe I’m reading something wrong? Thanks Clive Devey Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted February 3, 2023 Author Share Posted February 3, 2023 Well I don't know about your plan but on my drawing just under the motor mount location on F-1 there is a large oval hole. On my model this hole is large enough to insert the ESC. I connect the ESC to the motor and slide the ESC through this hole. The connection through to the receiver while to connection to the battery goes up between the fuselage side and the battery platform. I am pretty sure that there are not many ESCs of the size needed for this model that will not go through this hole I have attached the PDF of my plan just in case the one in the magazine doesn't show this although I did proof the plan but I may have missed this pointMinimax Fus.pdf Quote Link to comment Share on other sites More sharing options...
Clive Posted February 12, 2023 Share Posted February 12, 2023 On 03/02/2023 at 08:18, Peter Miller said: Well I don't know about your plan but on my drawing just under the motor mount location on F-1 there is a large oval hole. On my model this hole is large enough to insert the ESC. I connect the ESC to the motor and slide the ESC through this hole. The connection through to the receiver while to connection to the battery goes up between the fuselage side and the battery platform. I am pretty sure that there are not many ESCs of the size needed for this model that will not go through this hole I have attached the PDF of my plan just in case the one in the magazine doesn't show this although I did proof the plan but I may have missed this pointMinimax Fus.pdf Thanks for the pdf file Peter. I think my confusion is based on the photo in RCM&E where your motor wires are fed from the motor through the top small hole in F1, not the large oval hole. I don't think that an ESC would go through that hole? The installation description also refers to the ESC being "fed through from the cockpit and sits on top of the battery platform". Sorry to be persistent but this may confuse others too? Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted February 12, 2023 Author Share Posted February 12, 2023 I am confused now. The photos etc are on another computer so I will look tomorrow and see what I did wrong. Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted August 31, 2023 Share Posted August 31, 2023 Managed to maiden the 1/3rd scale one photo'd above, here's the video proof. 1 Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted August 31, 2023 Author Share Posted August 31, 2023 That looks impressive. If it is anything like mine it will be highly aerobatic. Possibly non scale but very exciting to fly. 1 Quote Link to comment Share on other sites More sharing options...
Outrunner Posted August 31, 2023 Share Posted August 31, 2023 26 minutes ago, Frank Skilbeck said: Managed to maiden the 1/3rd scale one photo'd above, here's the video proof. Very nice. Engine makes an awful lot of noise though. Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted August 31, 2023 Share Posted August 31, 2023 17 minutes ago, Outrunner said: Very nice. Engine makes an awful lot of noise though. Needs leaning out a bit, but have you heard a fullsize 🤪 Quote Link to comment Share on other sites More sharing options...
Peter Miller Posted August 31, 2023 Author Share Posted August 31, 2023 14 minutes ago, Frank Skilbeck said: Needs leaning out a bit, but have you heard a fullsize 🤪 I was thinking that it would not be allowed on our field unless quietened down a lot Quote Link to comment Share on other sites More sharing options...
