Robin Mosedale 1 Posted November 30, 2020 Share Posted November 30, 2020 I have a Durafly Stuka, where the motor has shorted internally (and blown the ESC , but that's by-the-by) Bought secondhand but never flown, good job. Seems to have been the stock motor in most 1100mm Durafly's. Now defunct. How likely is it that I can source a form fit function replacement for the motor. I'm not familiar with terminology, but I think that the 3536 is motor can dimensions. It's here (discontinued):- Brushless Outrunner 3536 850Kv With Propeller Adapter (hobbyking.com) Listed as 5mm shaft with prop adapter (which I've measured to be 5.8mm dia and fits the scale spinner) which also has a hex base. Would i find a stock 3536 motore with the same spacing holes for the prop adapter and rear mounting plate? Quote Link to comment Share on other sites More sharing options...
SIMON CRAGG Posted November 30, 2020 Share Posted November 30, 2020 Hi Try Banggood 3548 / 900 @ $18.00. I have got a few of them, and they are great little motors. Quote Link to comment Share on other sites More sharing options...
Shaun Walsh Posted November 30, 2020 Share Posted November 30, 2020 Try 4-Max 3535-870 motor Edited By Shaun Walsh on 30/11/2020 14:24:46 Edited By Shaun Walsh on 30/11/2020 14:26:46 Quote Link to comment Share on other sites More sharing options...
Robin Mosedale 1 Posted November 30, 2020 Author Share Posted November 30, 2020 Thank you chaps. Still looking Quote Link to comment Share on other sites More sharing options...
