Maurice Dyer Posted December 14, 2020 Share Posted December 14, 2020 Building a new one, after thirty years. Not a crazy stunt, hovering flyer, just your average club hack. What's the team suggested engine I/C , must be four stroke. Got an O.S.52, but hamlet after a Laser. What's your suggestion ??? Maurice Quote Link to comment Share on other sites More sharing options...
Andrew Calcutt Posted December 14, 2020 Share Posted December 14, 2020 Just finished mine,not yet flown.Done mine electric on 5 cells.Hope the weather improves and gets a bit drier! Quote Link to comment Share on other sites More sharing options...
Maurice Dyer Posted December 14, 2020 Author Share Posted December 14, 2020 Andrew did it build alright ? Quote Link to comment Share on other sites More sharing options...
Brian Hammond Posted December 14, 2020 Share Posted December 14, 2020 Mine runs on 6 cells but years ago I fitted a Saito 80 , I prefer the electric one as the performance is about the same and I don,t get moaned at about oilyclothes etc. Quote Link to comment Share on other sites More sharing options...
Andrew Calcutt Posted December 14, 2020 Share Posted December 14, 2020 Built ok,missing the 1.5 mm wing sheeting,built mine with a steerable tail wheel.Might try and fly it tomorrow. Quote Link to comment Share on other sites More sharing options...
Paul Marsh Posted December 14, 2020 Share Posted December 14, 2020 OS61 SF Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted December 14, 2020 Share Posted December 14, 2020 I'm probably a bit biased - mine has a 91FX - but I think a .52 FS is going to make it too soggy to have fun. A bit like a Puppeteer in a shell suit! How about a Laser 70 or 80? Quote Link to comment Share on other sites More sharing options...
Former Member Posted December 14, 2020 Share Posted December 14, 2020 [This posting has been removed] Quote Link to comment Share on other sites More sharing options...
Caveman Posted December 14, 2020 Share Posted December 14, 2020 I'm just nearing the end of building a JP Panic. I bought an SC61 two stroke at our club 'bring and buy' sale last year for a tenner, and needed a plane for it. The Panic seemed like a good match. I decided on a Panic but only as a fun plane to fly rather than for out and out madness! I'll post on the 'New models let's see 'em' thread when it's complete and ready to fly. No real problems with the build but despite the full colour 'build manual' it does leave plenty for the individual builder to design. GDB Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted December 14, 2020 Share Posted December 14, 2020 My previous Panic made a nice club sport model on a 52 2 stroke so I'd say a 70 4 stroke would be a nice fit. Quote Link to comment Share on other sites More sharing options...
Andy Stephenson Posted December 14, 2020 Share Posted December 14, 2020 It really depends on how light you can build it. The JP kit Panic has a very similar construction to the ARTF one available a while ago and is a relatively light weight construction so it should fly well on a 52 2 stroke. The original Avicraft foam wing, slab side balsa Panic usually came out heaver and required a bigger engine due to weighing anything up to 8Lb. My collection of panics all have Irvine 72s and will perform pretty much anything I ask of them but I do think a 90 2 stroke can be a bit much as I heard of one with a 90 which ripped the cabane struts right out in a positive G manoeuvre, there wasn't much left as a result. A. Edited By Andy Stephenson on 14/12/2020 22:31:33 Quote Link to comment Share on other sites More sharing options...
Maurice Dyer Posted December 15, 2020 Author Share Posted December 15, 2020 Thanks people. I love that 'puputeer in a shell who'd qoute ! A Laser it is, probably a 70, I'm not power crazy. Maurice Quote Link to comment Share on other sites More sharing options...
Andrew Calcutt Posted December 15, 2020 Share Posted December 15, 2020 Flew the panic today,no problems plenty of power on 5 cells.Very lively need a few more flights then should be great. Quote Link to comment Share on other sites More sharing options...
bees Posted February 28, 2021 Share Posted February 28, 2021 Hi, Just about finished my Panic but was wondering what kind of connection you use to join bottom aileron to the top aileron bearing in mind that it will have to be disconnected after each flying session. I was going to use a clevise at one end but don't think after plenty of use it will stand up to constantly being unclipped. Thank you Quote Link to comment Share on other sites More sharing options...
Geoff S Posted February 28, 2021 Share Posted February 28, 2021 It's a common method on biplanes, though mine are all scalish types. There shouldn't be a problem if you use a stainless steel clevis. A Z bend or ball-joint at one end and a s/s clevis at the other. Geoff Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted February 28, 2021 Share Posted February 28, 2021 Mine uses servo wire. (It has separate servos in the top wing) I made links from threaded pushrods with lightweight aluminium "streamline" tubing covering for my Pitts Special but balsa fairings could be used to provide added stiffness. Quote Link to comment Share on other sites More sharing options...
Andy Stephenson Posted February 28, 2021 Share Posted February 28, 2021 Bees, This is the way I do it on my fleet of panics. I drill a 1/8" hole in the TE of each aileron at an angle which matches the offset between the wings. I CA in a short length of plastic snake inner. Then a 2mm helmet style ball-link is screwed into the snake. The joiner rod has a piece of 2mm threaded rod CAed into a dowel with the plastic cup end mounted onto the threaded rod. Using this system it's easy and quick to rig and de-rig the wings. Don't inset the metal ball part into the aileron parallel with the surface because at full throw the ball will knuckle out of the cup. Quote Link to comment Share on other sites More sharing options...
bees Posted March 1, 2021 Share Posted March 1, 2021 Thank you guys for all of your comments, just waiting for the ball joints to arrive. Quote Link to comment Share on other sites More sharing options...
Maurice Dyer Posted April 13, 2021 Author Share Posted April 13, 2021 Thanks all. Has anybody glass joined the wings with Bucks composite glass kit ?. Will one kit do both sets of Wight he ??. The glass cloth is qouted as being 1 metre long. So I suppose that's just enough.??. Anybody used this ? Cheers Maurice Quote Link to comment Share on other sites More sharing options...
Don Fry Posted April 13, 2021 Share Posted April 13, 2021 I used 3 layers of 25 g per square meter glass skinning cloth, 2, 4, and 6 inches wide. one wing was done with skinning resin, applied with a radiator roller. the other done with Superphatic wicking water based resin, also rolled on. It was an experiment, compare and contrast the difference. Both are neat, the joint is invisible under the film covering. Both passed a 10 g stress test. If I’m being picky, I prefer the epoxy system, but I am used to using the stuff, have very accurate 0.1 gram scales, and in a previous existence had to do potentially messy stuff, without causing a mess. Quote Link to comment Share on other sites More sharing options...
Andy Stephenson Posted April 16, 2021 Share Posted April 16, 2021 I've heard it said by a very experienced modeller that just epoxying two foam cored wing panels and not reinforcing it with anything would be perfectly sound. I have never been tempted to try this myself. I think the most important point about glassing the centre section is that it is more about stopping the fuselage sides digging into the veneer and particularly on the Panic the cabane struts on a heavy landing. I have used the feather method Don describes when glassing and it makes it much easier to hide the join, that said I wouldn't bother on a Panic as it's a flier's model and not for concourse. Quote Link to comment Share on other sites More sharing options...
Don Fry Posted April 16, 2021 Share Posted April 16, 2021 The laws of physics say otherwise. This wing is an inch thick. Glue the foam together, it bends, and parts. The skins will be better. How much do you expect a stress skin of .5 mm to take, bear in mind, how good are you at lining up the skins, assuming the cutter is that accurate to allow you the luxury of an accurate coming together. And if you don’t want hooligan flying, why do a Panic. Ugly joins are an affront to beauty. Why settle for less. Evan a Panic has a certain (pugnacious) beauty. My example is currently under repair. The ground came up and hit it. The wings sustained no centre section damage. Other bits broke. The glass skins have girt big surfaces to glue to, and so, when stressed, the shear forces are small. Quote Link to comment Share on other sites More sharing options...
