Brian Dorricott 1 Posted February 3, 2021 Share Posted February 3, 2021 Does anyone know what keeps the pins in these hinges when fitted as there is no extra length in the pin to bend or solder . I fancied using them but am worried about retaining them because if you use glue then they lose the removal capability . Any thoughts on them ? Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted February 3, 2021 Share Posted February 3, 2021 Picture, link? Better to be sure that the answers you get are appropriate to the particular hinges... Quote Link to comment Share on other sites More sharing options...
BackinBlack Posted February 3, 2021 Share Posted February 3, 2021 Those that I have used have a slight crimp or flattened area on the end of the pin that goes through the plastic hinge. It does require a little force to push them through when installing. This does quite effectively stop the pin coming out. Quote Link to comment Share on other sites More sharing options...
Bob Cotsford Posted February 3, 2021 Share Posted February 3, 2021 Are these the ones with an L shaped pin? When I used to use them I buried the bent end into the wing alongside the leaf so they were definitely not coming out. If you want them removable replace the individual wires with a single length inserted from one end and passing through all the hinges on that surface. Retain the wire with a screw or just a flap of covering at the end. Quote Link to comment Share on other sites More sharing options...
Brian Dorricott 1 Posted February 3, 2021 Author Share Posted February 3, 2021 Thanks never thought of pushing the bent end into the balsa , that should keep the little blighters in place . Ta Quote Link to comment Share on other sites More sharing options...
bert baker Posted February 3, 2021 Share Posted February 3, 2021 Quote Link to comment Share on other sites More sharing options...
bert baker Posted February 3, 2021 Share Posted February 3, 2021 Is that the ones Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted February 3, 2021 Share Posted February 3, 2021 Posted by Brian Dorricott 1 on 03/02/2021 15:13:57: Does anyone know what keeps the pins in these hinges when fitted as there is no extra length in the pin to bend or solder . I fancied using them but am worried about retaining them because if you use glue then they lose the removal capability . Any thoughts on them ? There is usually a plastic flap clip at one end of the hinge for the angle to clip into, but if not that type, then you can assemble the hinge such that the angle pin goes into the wood when pushed in. Edited By Denis Watkins on 03/02/2021 16:18:19 Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted February 3, 2021 Share Posted February 3, 2021 + 1 for pushing the bent part of the pin into the hinge slot Quote Link to comment Share on other sites More sharing options...
ASH. Posted February 3, 2021 Share Posted February 3, 2021 Which hinge type is best for rudder on 60 size, 4kg+ aerobatic sports model.. Mylar or nylon/plastic? Thanks. Quote Link to comment Share on other sites More sharing options...
cymaz Posted February 3, 2021 Share Posted February 3, 2021 I’ve never had any issues with the furry hinges that are glued in with CA. Maybe I’m ham fisted but I find the plastic hinges above a pain and fiddle Edited By cymaz on 03/02/2021 18:40:19 Quote Link to comment Share on other sites More sharing options...
John Stainforth Posted February 3, 2021 Share Posted February 3, 2021 There are fibre hinges and fibre hinges. Some of the poorer ones break up pretty quickly, and even the better ones eventually have to be replaced - by pinned hinges. The latter are certainly more work, but I think it is worth it, so that I now tend to fit pinned hinges when I put a model together - as I am doing right now. Quote Link to comment Share on other sites More sharing options...
ASH. Posted February 3, 2021 Share Posted February 3, 2021 The Mylar fibre hinges I normally use are quality ones - made by Great Planes. And I can get a tighter gap than with the other type. Quote Link to comment Share on other sites More sharing options...
