Colin’s Spanish Fury
Thanks Danny. It would be worth finding out more about that. Diagonal joints are normally associated with bias cutting, I’ve seen it done where the cloth is pulled continuously across a knife at 45 degrees in rotation and the cut edges continually stitched into a tube, or a continuous “bag”.
Looking at the photos in your build thread, you seem to have short, intermediate “nose ribs” between each pair of full ribs, which made me think I’d missed something out in the build. However, I’ve taken another look at the plan and I can’t see anything I have missed. Any ideas?
The photo shows where I am, are the diagonal tapes repeated underneath? I assume they should be. I’m running out of tape, need to order some more.
Also, these tapes have a slightly “pinked” edge, you can just about see it.IMG_0048.thumb.jpeg.8cab712173ff4028b0180aa89b4f51f2.jpegIMG_0045.thumb.jpeg.2b8b2cfc0a0d81923b9194eca19e3a85.jpeg
  • 1 month later...
After being away for two weeks and taking more than a week to catch up with everything, I finally got back in the shed and continued with the tedious job of sticking on rib-tapes. Three wing panels done. I want to get on with the painting as soon as possible. There's still a question though, but I can't get the photos to load. I'll try another post.
IMG_0529.thumb.jpeg.e49b868004dfcd2bc738cd6c2a78c4f2.jpegIMG_0527.thumb.jpeg.d751f81bc584c3aaefccf4de2f621614.jpegIMG_0524.thumb.jpeg.2bebf2d9532ad220c282aad18ded532a.jpegIMG_0515.thumb.jpeg.2db1a9185f9b36badded085f9810909a.jpegIMG_0528.thumb.jpeg.6214d88ca798ccad672c3759e68efb34.jpeg
There are many different interpretations of the camouflage patterns on the Spanish Hawker Furies in Republican service, further complicated by one of them that was captured by the Nationalists and repainted in their scheme. These pictures taken from the FB  Spanish Civil War modellers group are just an indication, there are other references that I also have. There is no way of being certain about scale accuracy, it will be a case of choosing one and going for it. While thinking about that, the remaining jobs are the dummy reproduction of the elevator linkage and the curved fairings at the bottom of the Dowty undercarriage legs. I wasn't going to bother about the latter, but in for a penny - - - as they say.
Edited by Colin Leighfield
  • Like 2
Thank you Martian and Bas! Today I have sorted out the dummy "scale" elevator linkage. I was puzzling how to create the tiny dummy pulley wheel for the elevator cables, only about 4mm diameter. I used some plastic tube and filled it with 5 minute epoxy. When it was set, I cut a length off and hey presto! The colour is unfortunate, but easily corrected! Then onto the bottom fairings for the undercarriage legs. I thought that would be tricky, but using soft 10mm. balsa, it wasn't. Just some sanding and then covering with tissue and dope to finish off. When that is done, the painting can start. IMG_0542.thumb.jpeg.35ce49cabc55d6f21400fe24732e8a94.jpegIMG_0543.thumb.jpeg.998574198dbd29c0317c3966e11b48cf.jpegIMG_0544.thumb.jpeg.3d51ed0f6a43160fb552e548346e0f94.jpegIMG_0546.thumb.jpeg.2d99cd7571fd952b3dbb468b426c416e.jpeg
  • Like 2
