GrumpyGnome Posted August 18, 2022 Share Posted August 18, 2022 Leccy starter for me....... 2 Quote Link to comment Share on other sites More sharing options...
David Ovenden Posted August 18, 2022 Share Posted August 18, 2022 3 hours ago, GrumpyGnome said: Leccy starter for me....... Me too! Quote Link to comment Share on other sites More sharing options...
Simon Chaddock Posted August 18, 2022 Share Posted August 18, 2022 Chicken stick? I have started the Gipsy Major in a Tiger Moth a good few times. No electric start. When a 93 cu in (1530 cc) cylinder fires and the other blade of the 78" mahogany prop comes round you have to make sure every part of you is out of the way. It helps to have no imagination. 😉 1 Quote Link to comment Share on other sites More sharing options...
Colin Leighfield Posted August 18, 2022 Share Posted August 18, 2022 I confess that I always use a starter! Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted August 18, 2022 Author Share Posted August 18, 2022 I have read that the kindest way to treat the engine is to start it by hand and bounce the prop blade backwards against compression, so that's what I do. No idea if that's correct. But makes sense. Cheers Danny Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted August 19, 2022 Share Posted August 19, 2022 8 hours ago, Danny Fenton said: I have read that the kindest way to treat the engine is to start it by hand and bounce the prop blade backwards against compression, so that's what I do. No idea if that's correct. But makes sense. Cheers Danny It makes good sense, I confess to using the starter too much but what you are doing now is a lot better for the engine and the airframe. 1 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted August 19, 2022 Share Posted August 19, 2022 Reverse flicking a prop is great, even better if there’s a spinner that you can just flick with your fingers (obviously not in the case of the Chippy). However as long as there’s no hydraulic lock the use of a starter is fine and should not be detrimental to an engine. 2 Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted August 27, 2022 Author Share Posted August 27, 2022 Finally managed to get my ducks in a row, and maiden my Auster, what a pussycat, apart from the stress of waiting for the engine to stop! Needless to say all went okay. No photographer with me so no in flight pics, will have to sort those out on another day. Vibrations were not a problem and apart from losing one cowl screw nothing else came loose. The flap linkage failed on the taxi back when I was demonstrating full flap which I fortunately didn't use them in flight. Need to beef up that area. This model floats like you wouldn't believe, and likes a breeze to fly into. Thanks for the words of wisdom along the way, what next.......... Cheers Danny 9 Quote Link to comment Share on other sites More sharing options...
Manish Chandrayan Posted August 27, 2022 Share Posted August 27, 2022 Congratulations on a successful build and maiden. Will await a video from when you fly her next time 1 Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted August 27, 2022 Author Share Posted August 27, 2022 Funnily enough.... Thanks for the kind words Cheers Danny 8 Quote Link to comment Share on other sites More sharing options...
RottenRow Posted August 27, 2022 Share Posted August 27, 2022 That looks great Danny, well done. Having had the opportunity to see your model ‘in the flesh’ a couple of weeks ago at Buckminster, I must say that it looks even better than in the photos. I’m glad that you are persevering with the four stroke. Brian. 1 Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted August 27, 2022 Author Share Posted August 27, 2022 Thanks Brian, 😊 It was quite sattisfying when it burst into life, and continued bursting into life. Once I know I can trust it I will try some chandelles and wingovers. I was amazed at how little power it needed. Cheers Danny Quote Link to comment Share on other sites More sharing options...
alan p Posted August 27, 2022 Share Posted August 27, 2022 Congratulations Danny👏 Didn't need the food parcel after all, great result 1 Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted August 27, 2022 Author Share Posted August 27, 2022 No I took the advice to only put 10oz in that 16 oz tank. and off that 10 ozs this came out of the tank afterwards......... I reckon I burned just 3.5 ozs Cheers Danny 1 Quote Link to comment Share on other sites More sharing options...
David Davis 2 Posted August 28, 2022 Share Posted August 28, 2022 Well done Danny, a very fitting reward for all of the time and effort you put into the build. 1 Quote Link to comment Share on other sites More sharing options...
cymaz Posted August 28, 2022 Share Posted August 28, 2022 Great result...well done 1 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted August 28, 2022 Share Posted August 28, 2022 10 hours ago, Danny Fenton said: I reckon I burned just 3.5 ozs And the added bonus of a great sound too! 1 Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted August 28, 2022 Share Posted August 28, 2022 Great result! 4 strokes make a lovely noise.... and Saitos are real gems. 1 Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted August 28, 2022 Author Share Posted August 28, 2022 Had a play on the lathe/mill The alloy cone goes over the original nut. Not enough room to fit the little Saito locking nut, but this helps. Cheers Danny 3 Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted August 29, 2022 Share Posted August 29, 2022 Very nice Danny, slow running a tad rich, give it a tweak n you should be able to slow tickover some. 1 Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted September 4, 2022 Share Posted September 4, 2022 Excellent Matey, Well Done. Nice scale tail up take off and landing. D.D. 1 Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted September 5, 2022 Author Share Posted September 5, 2022 Nice to hear from you Dwain, and thanks for the kind words. It was after all your Auster that inspired me to do one myself. Cheers Danny Quote Link to comment Share on other sites More sharing options...
Danny Fenton Posted March 6, 2023 Author Share Posted March 6, 2023 9 2 Quote Link to comment Share on other sites More sharing options...
