GrumpyGnome Posted March 21, 2021 Share Posted March 21, 2021 Great work there Nigel. GG Quote Link to comment Share on other sites More sharing options...
Nigel Sharp Posted March 21, 2021 Author Share Posted March 21, 2021 Thanks for the comments. Had to resist further attempts at smoothing the epoxy this was done before lunch but is still not quite fully hard. Tomorrow it will sand down nicely ? so the rest of the afternoon was spent rubbing the highbuild applied yesterday back off the wing, control surfaces and cowling. I packed in at about 5 and I'm sat here feeling quite exhaused. Starting to think hard about the colour scheme to apply. I am torn between the Game Bird style (swap green for Red) I have a Green CCM Hypnosis and that disappears against a blue sky! Or the original Terry Westrop Red/White. Except it would be black red orange and white as that is bright and contrasts well with the sky. Quote Link to comment Share on other sites More sharing options...
Nigel Sharp Posted March 24, 2021 Author Share Posted March 24, 2021 Filleted and smoothed since the week end. Re-masked and as the early evening today was light and dry the High Build primer applied to the fuselage. There are some obligatory blemishes that require some remedial work and touch up surface filler but on the whole good progress has been made. Adding the primer uncovers those hidden in the grain sub optimal snags. Wont be ready for release from lockdown there is still a lot of work to do but early spring is still looking promising. 2 Quote Link to comment Share on other sites More sharing options...
Andy Stephenson Posted March 25, 2021 Share Posted March 25, 2021 On 14/03/2021 at 18:43, Nigel Sharp said: It was in Chris Mcg6969 Bella Ballerina build log here page 35. But I made mine from Ronseal "Diamond Hard" clear acrylic varnish, Polyfiller "Advanced" light weight filler, Talcum powder ( cheap supermarket stuff) and a drop of white acrylic paint to be able to see where I'd brushed. Basically "Heaped Teaspoon" of the lightweight filler, slightly more talc, Mixed with the Ronseal and the paint. Add water until it is like single cream. I mixed about 50 ml by the time I had thiined it to the cream consitancy and that easily did the wings with quite a lot to spare. - Acouple of days later I mixed a second lot to do the fus/tail again lots left over. Then its simply a case of brushing on, wait a couple of hours and sand it all off ? leaving the fine talc/filler in the weave. Sands down very easily. Nigel, I tried your formula for weave filler, I mixed it fairly thick which made for some hard work sanding it back but it was worth it because it leaves a very nice flat smooth surface. Previously I have gone straight in with the high build primer but it doesn't have the same power to fill the larger divots and if there is an area of sparse epoxy it just leaves the surface porous no matter how many times you spray over it. Thanks, Andy. 1 Quote Link to comment Share on other sites More sharing options...
Nigel Sharp Posted March 25, 2021 Author Share Posted March 25, 2021 I can't take credit for the sauce I got it from here ? but it does work nicely. Quote Link to comment Share on other sites More sharing options...
Nigel Sharp Posted May 3, 2021 Author Share Posted May 3, 2021 Bank Holiday weekend and rain stopped play... its an ill wind! The good thing about rain is you need to do something else instead of going flying ? The Dice has been on a hiatus as April has been excellent for flying and not so for building and I sometines just can't face doing building after work. Anyway here is a little update after a pleasent day making/masking the lines for the colour coats. As you can see it's getting a nod to the "Terry Westrop" schemeal be it a little simpler. Just need a few sunny evenings now to add those last coats I feel the build mojo returning. 1 Quote Link to comment Share on other sites More sharing options...
Nigel Sharp Posted May 10, 2021 Author Share Posted May 10, 2021 Here is an in progress update... paint scheme applied alas it doesn't quite pass my scrutineering so I have some further finishing work to do ? it was the bleeding masking tape wot done it guv! However I am very chuffed with the way the colours work ? hope you like it. I feel the end of the build is near just the electrics to wire up ( wiring loom for wing, and soldering connectors to ESC ) and to balance etc. 2 Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted May 10, 2021 Share Posted May 10, 2021 I do, can't spot where it bled through but will take your word for it. Very nice. Quote Link to comment Share on other sites More sharing options...
Nigel Sharp Posted May 10, 2021 Author Share Posted May 10, 2021 Out of focus pictures help ? but I have a plan... at first careful T cutting worked wonders on the Fuselage/wing but the flappy bits alas are a bit of a lost cause. I was soooo annoyed with myself all it would have taken is a quick blast over with white on that tape. Still we learn by our mistakes plus the extra work it makes re-inforces the memory. It's years since I sprayed a model having used film for years and years. 1 Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted May 10, 2021 Share Posted May 10, 2021 Flappy bits can be a problem, they're well known for it. ? 1 Quote Link to comment Share on other sites More sharing options...
WayneB Posted May 11, 2021 Share Posted May 11, 2021 Nicely built and finished, be proud of it. Quote Link to comment Share on other sites More sharing options...
Nigel Sharp Posted May 29, 2021 Author Share Posted May 29, 2021 Final pictures - maidened this afternoon - very nice flyer (as expected ? ) just need to spend lots of time on the sticks to learn pattern... the Wayfarer in the background is also mine and also a splendid flyer especially in hooligan mode. Twins Bill and Ben the pilot men each eagerly waiting their turn. 1930 watts on my meter 87Amps drawn at full chat. 15 x 7 APCE prop Landed at 7 min Zippy Compact 6S 6200 mAh pack with 30% remaining Very happy indeed. 2 Quote Link to comment Share on other sites More sharing options...
Masher Posted May 29, 2021 Share Posted May 29, 2021 Well done, looks great - that must be ballistic! What's the AUW? Quote Link to comment Share on other sites More sharing options...
Nigel Sharp Posted May 29, 2021 Author Share Posted May 29, 2021 Masher, It came out at a slightly lardy 9 1/2 lb so I have just over 200 watts per lb. The Lipo weight is 1.9 Ibs which is a fair old lump I think having to put on three coats of white to overcome the grey primer was the culpret. It took me an age to finally decide to do the westrop style scheme. However it does go straight up and does huge loops plus flys like it is on rails but I have only had two flights today so early in the tuning process. Was very pleased as I only required 1/2 oz of weight on the motor box to balance right on the plan c of g. Which given the pedigree is spot on when flying as is the 4 deg of right thrust. I will add a single washer to each top mounting bolt which will equate to 1/2 to 1 deg down thrust as I believe it does need it ( on the plan but omitted by me in error ) that will better suit the spinner since it is very slightly proud of the top deck by about the same amount... ?. Quote Link to comment Share on other sites More sharing options...
Masher Posted May 29, 2021 Share Posted May 29, 2021 Nice to compare. Mine is the LDIIs (the long one) weighs in at 8lb all up with 6s 5000mA. I'm on 16x10, 1200W and 60A max use 50% at 6 mins. Not ballistic but big loops and 'enough' power. 2 Quote Link to comment Share on other sites More sharing options...
Nigel Sharp Posted May 29, 2021 Author Share Posted May 29, 2021 I like that. My wings came from Bill Kits they were cut for LDII (68") so I had to remove a 1" from each of the wing roots & 1/2" of the tail roots too to make the 66" version . I had already ordered the balsa etc and made the Fus sides when I realised the difference. I did print the plan for the LDII fuse and yes it is mucho longer - but as I'd already decided on the first Loaded Dice I continued with it. A Very nice if extended build. Great to being building in balsa again especially with plans from outerzone. Now I'm going to do a lot of flying. N. Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted May 30, 2021 Share Posted May 30, 2021 Very nice! 1 Quote Link to comment Share on other sites More sharing options...
