Alex Ferguson 2 Posted April 19, 2021 Share Posted April 19, 2021 I had a problem only slightly different, hard to start, OK sometimes loss of power after a while. The coil, change it and at least that is one item of a reasonable age out of the way. That's what fixed my problem. Quote Link to comment Share on other sites More sharing options...
Cuban8 Posted April 20, 2021 Share Posted April 20, 2021 (edited) Fuel vapourisation or vapour lock when hot? Missing or wrong isolator betwixt carb and engine hence heat transfer? Have seen this before with similar symptoms. Edited April 20, 2021 by Cuban8 Quote Link to comment Share on other sites More sharing options...
Rich Griff Posted April 20, 2021 Share Posted April 20, 2021 (edited) This is the beauty of these inexpensive and quick to use red neon plug caps that flash as HT passed thru. I use them for checking HT in real world engine running actual conditions. The ignition system may work for starting but what happens when engine is working hard meaning the ignition system has to work hard . Bike, self contained CDI ignition system, non battery dependant, a modern take on a magneto if you will. Great starter and runs well for a few miles, then seems to have either a fuel problem or a coil breaking down at about 5 k revs, surging, just will not rev over 5 k revs. Struggle bike home, fit red neons, start and rev...flashes disappear when misfire starts, revs drop, flashes reappear, engine revs to 5k, misfire...repeat. So loss of ignition at revs. Dmm shows acv output of generator to CDI fall with revs ? And at about 5 k revs, acv output goes below about 28v AC. So, Geny coils breaking down under load and heat. Rate of change, acv rises, insulation break down.... Or clean carbs many many many many times as it's an ignition fault. These neons save your hair and stop you getting dizzy...well worth the money. A good bit of kit and very easy to use. I also use them on petrol cars.....if needed. Edited April 20, 2021 by Martin Harris - Moderator Unacceptable language and defamatory statement removed. 1 Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted April 20, 2021 Share Posted April 20, 2021 (edited) Vaporisation is a thought. If the petrol is a winter grade and has high ethanol content, it may have pushed the simple technology carburation too far. You could try some fresh premium E5 (or E0 if you can find it) fuel from a “named” garage rather than supermarket cheap stuff if that is what you’re using. Easy to prove if you can pour some cold water onto the carb without shock cooling the engine. The fact that it revs on choke tends to discredit the ignition theories. Edited April 20, 2021 by Martin Harris - Moderator Quote Link to comment Share on other sites More sharing options...
Rich Griff Posted April 20, 2021 Share Posted April 20, 2021 Sorry, ment to say that modern Citroen cars are absolutely wonderfully, not. Older ones, ie pre ECU one are very very good compared to the modern ones. Quote Link to comment Share on other sites More sharing options...
Ace Posted April 20, 2021 Author Share Posted April 20, 2021 Thanks, lots to go at. Neon/compression testers later this week. Will also try cold water on the carb body for vapor lock Higher octane petrol. Although runs fine for first 20 min. One test/change at a time. Just to clarify, once fault occurs it still starts and ticks over but won't rev even with partial choke and full choke kills it. Quote Link to comment Share on other sites More sharing options...
Ace Posted April 23, 2021 Author Share Posted April 23, 2021 Well yesterday didn't go exactly as planed The compression tester wasn't available but we still went armed with the new neon HT checker, 5l of water/towel and fresh 98 octane fuel. Plan was to run until fault arose, check HT with neon, if ok then cool carb with towel soaked in cold water. If still no joy replace fuel with fresh 98 oct. So only checking or changing 1 thing at a time. Started 2nd pull worked fine for 20 minutes and were just waiting for the fault to develop - then bang and the cutting cylinder stopped rotating. Removing the side cover revealed that the drive chain had snapped - long string of expletive's. The bolt holding the sprocket had come undone allowing it to come off which in turn meant the chain then got wedged on the drive roller mechanism and something had to let go. You can see the very bottom link is splayed open. Finished off with our self-propelled rotary and will now need to source a new chain and are still no closer to identifying the fault. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted April 23, 2021 Share Posted April 23, 2021 Oh dear - and I'm sure you didn't use those words when it happened! Quote Link to comment Share on other sites More sharing options...
Rich Griff Posted April 23, 2021 Share Posted April 23, 2021 The engine will run without that chain ? Quote Link to comment Share on other sites More sharing options...
Ace Posted April 24, 2021 Author Share Posted April 24, 2021 True Rich. However once we identified the broken chain it was driven off the patch and back to its container storage a couple of hundred meters away still without the fault raising its head and anyone considered it could be still driven without actually cutting the grass. Mind set was - broken - fix it then continue another day and get on with some flying. Quote Link to comment Share on other sites More sharing options...
Brian Lambert Posted April 24, 2021 Share Posted April 24, 2021 Could it be carburettor icing? As for the chain bearingboys.co.uk carry lots of chains. Quote Link to comment Share on other sites More sharing options...
Ace Posted April 24, 2021 Author Share Posted April 24, 2021 (edited) Brian, doubt icing as carb/silencer are on the same side and with the motor running for 20 min+ B4 fault carb is warm but not hot. Could try the wet towel heated on silencer then wrapped around carb if cold towel to test vapor locking failed. Will look at bearingboys if we struggle locally Edited April 24, 2021 by Ace suggested site Quote Link to comment Share on other sites More sharing options...
J D 8 Posted April 24, 2021 Share Posted April 24, 2021 Hi Ace, Do not know your location but most Agri spare parts places will be able to repair your chain. Quote Link to comment Share on other sites More sharing options...
Basil Posted April 24, 2021 Share Posted April 24, 2021 Hi, must say this; I used a number of sit on mowers some years ago.I had problems similar, was the safety switches that exist to make sure that you are seated, and other things re grass box etc. they may be simple but can malfunction. Does not seem applicable in this case but always a possibilty. Most faults usually came down to simple things Bas Quote Link to comment Share on other sites More sharing options...
Ace Posted April 24, 2021 Author Share Posted April 24, 2021 No safety switches to worry about. "Most faults usually came down to simple things" - hopefully but can we identify the blighter. Quote Link to comment Share on other sites More sharing options...
Rich Griff Posted April 24, 2021 Share Posted April 24, 2021 Neon plug cap to rule in or out loss of HT, or reduced strength then final disappearance ... Quote Link to comment Share on other sites More sharing options...
