Andy48 Posted May 7, 2021 Share Posted May 7, 2021 (edited) I've been updating all my planes with the latest FrSky firmware. Its not been an easy job, as it resets all the telemetry, and I have to reprogramme all the telemetry setting. I have three planes with S6R receivers. The first updated normally and the telemetry logs are just as I expected. However 2 more have some really odd glitches that I can't explain. Here is the first, my Wot 4. Funfly 80amp receiver in this one. Before updating, perfectly normal flight pattern, after updating 3 huge current spikes shown in red 90,000,000amps on every flight!!! RSSI (in green) perfectly normal. These spikes did not affect the ESC. Here is the second, a Gypsy Moth, a new plane with a Neuron 60S controller. In this case the spikes are going up to over 100 amps, yet I have current limiting set to 50 amps. Similarly the BEC voltage is reading very oddly, with spikes up to 20v. Again I've shown the RSSI to highlight nothing abnormal is going on at those points with regards to telemetry. Clearly there are no such spikes actually happening otherwise I'd have spent an hour filling a bin bag with bits as the servos and receiver would have all failed. However, the spikes have been enough with the Neuron to shut the ESC down. Any geniuses out there with an idea of what is going on. My own thoughts are 1. Telemetry seems to be working OK, as RSSI looks quite normal. 2. Spikes affecting Neuron, so telemetry reading is feeding back directly to Neuron control system. 3. With the Funfly, these spikes have only occurred after updating firmware in receiver. Never a problem before. However, if the spikes are due to the firmware update and it somehow affecting the telemetry, how come the Neuron is affected? Edited May 7, 2021 by Andy48 Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted May 7, 2021 Share Posted May 7, 2021 Just some thoughts Have not a clue about FrSky or updating But are there any clues that the graph registers 0 amps for most of the flight And 5 volts, for most of the flight and at some points in the record, these go to minus volts It almost as is the software maths are calibrated wrongly, and the peak multiplier magnifying by 10 or 100 So Is this a faulty download, that I think the boys would be aware of, Or is it your computer's handling of the download Quote Link to comment Share on other sites More sharing options...
Andy48 Posted May 7, 2021 Author Share Posted May 7, 2021 55 minutes ago, Denis Watkins said: Just some thoughts Have not a clue about FrSky or updating But are there any clues that the graph registers 0 amps for most of the flight And 5 volts, for most of the flight and at some points in the record, these go to minus volts It almost as is the software maths are calibrated wrongly, and the peak multiplier magnifying by 10 or 100 So Is this a faulty download, that I think the boys would be aware of, Or is it your computer's handling of the download This is the BEC voltage, which should be 5v throughout the flight. Then there are the + and - spikes which I cannot explain. The first graph doesn't register 0 volts, its just that the graph is scaled to include the peaks, and as such the normal current drawn 20-40amps is insignificant compared to the 90,000,000 amp spikes. Definitely not my computer handling the download, never seen this problem before, and downloading older files do not show this spike effect. Similarly the same firmware does not give problems except with these two receivers, and yet a third similar one behaves perfectly. Quote Link to comment Share on other sites More sharing options...
conrad taggart Posted May 7, 2021 Share Posted May 7, 2021 (edited) Think I would be tempted re-install old firmware on one of the faulty receivers and check readings, if okay reinstall the latest software and check again - might tell you whether you are doing something wrong re the update process and / or definitely confirm a fault in the software .... Where all the receivers from the same batch - especially the 2 faulty ones ? Edited May 7, 2021 by conrad taggart Quote Link to comment Share on other sites More sharing options...
Andy48 Posted May 7, 2021 Author Share Posted May 7, 2021 I cannot install the old software again as this requires uninstalling that software on the transmitter too. No the receivers are a different batch. I really don't understand it at all, but probably similar to your thinking I will try one of my new Access stabilised receivers instead, and possibly replace the ESC and run the plane up and check the telemetry each time. Job for tomorrow as it is due to rain all day. Quote Link to comment Share on other sites More sharing options...
MattyB Posted May 7, 2021 Share Posted May 7, 2021 (edited) There have been quite a few reports of unstable telemetry on ACCESS RXs over on RCGroups, but obviously the S6R is ACCST... I would ask there in the radios forum, that is where the biggest gurus of all things Frsky firmware hang out. Edited May 7, 2021 by MattyB Quote Link to comment Share on other sites More sharing options...
MattyB Posted May 8, 2021 Share Posted May 8, 2021 This is the thread you want. On this page there is a guy with S6R telemetry issues, but they sound a bit different to yours. https://www.rcgroups.com/forums/showthread.php?3507071-Important-Firmware-Update--ACCST-D16-2-1-x/page296 Quote Link to comment Share on other sites More sharing options...
Andy48 Posted May 8, 2021 Author Share Posted May 8, 2021 10 hours ago, MattyB said: There have been quite a few reports of unstable telemetry on ACCESS RXs over on RCGroups, but obviously the S6R is ACCST... I would ask there in the radios forum, that is where the biggest gurus of all things Frsky firmware hang out. Cheers Matty, this is what I am going to do, along with swapping out and testing. The puzzling part is the same instability in the Neuron ESC, that must originate in the ESC as far as I can see, for the ESC to go into reduced power mode. Quote Link to comment Share on other sites More sharing options...
Peter Jay Posted September 8 Share Posted September 8 Hi issues with Frysky S6R receivers been driving me nuts. On one Range warning at 50 metres . On other the elevator only goes down. Will not give an up throw. On another lost use of channels 5 or 6 for flaps. An S8R just died. Any suggestions for the flaps or elev issue..yes tried altering throw on radio. Quote Link to comment Share on other sites More sharing options...
Martin Harris - Moderator Posted September 9 Share Posted September 9 Hi Peter and welcome to the forum. I’m not a user of these products but I know that many are and while all radio systems may suffer an occasional problem, I haven’t heard that FRSky is significantly more unreliable than any other common system so it seems odd that you have had so many issues. It’s not unknown for RC products to be counterfeited - have you been buying from dubious sources perhaps? Are there power supply problems? What are you powering them with…ESC BECs or separate batteries? Perhaps you could give some details of where/how they are installed (photos preferably)? Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted September 9 Share Posted September 9 Is the stabilisation active or switched off? If active try again with it switched off. Quote Link to comment Share on other sites More sharing options...
Mike Blandford Posted September 9 Share Posted September 9 We need some more information. 1. Have you successfully used S6R or S8R receivers before? 2. Have you recently updated the firmware on the receivers? 3. Have you carried out the "Self Check" procedure on each receiver. 4. Have you set all the parameters available, e.g. gains, setting ch5 and 6 to AUX? 5. What Tx and firmware are you using? Mike Quote Link to comment Share on other sites More sharing options...
Peter Jay Posted October 31 Share Posted October 31 Thanks for comments and suggestions re Frysky receivers with stabilisation. Sourced receivers from reliable suppliers. Hobby King and two uk online stores.One S8r died completely. One s6r has range issues. Fitted to plane went to field ready for takeoff rssi warning. Had two s6r that work fine including flaps on channel 5. Used same settings on others no flaps either on channel 5 or 6. One s6r the elevator only moves one way.Upgraded to Edge on Radiomaster tx16 no difference. Same problem with Taranis on open tx.Tried new Lemon rx with stabilisation no issues.Suggestions pls. . Quote Link to comment Share on other sites More sharing options...
Mike Blandford Posted October 31 Share Posted October 31 Please answer questions 3 and 4 from my previous post. If you don't do the "self check" you will not have "taught" the receiver how far the servos are allowed to move. This could explain the elevator only moving one way. If you don't set channel 5 and channel 6 to AUX, then these will act as second aileron and elevator outputs. Mike Quote Link to comment Share on other sites More sharing options...
