EarlyBird Posted June 4, 2021 Share Posted June 4, 2021 I am puzzled by the instructions in the manual for Camber. The aileron setting is what I don't understand. Is it saying that the ailerons have 10mm up? I would have expected the ailerons to be the same as the flaps +3mm/-3.5mm and that seems to be what others have done. Any suggestions or explanations? Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted June 4, 2021 Share Posted June 4, 2021 Yep, this is the aileron to flap mix for a more sprightly roll, you set it up so the flaps only move up with aileron input, so right aileron moves the right aileron up and the right flap up, the left aileron moves down but the left flap doesn't move down, and vice versa for opposite aileron. Ailerons used as flaps, thermic and speed are +/- 2mm. I have flight phases set up on mine with an ACRO flight phase were the flaps move up with their corresponding aileron. 1 Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted June 5, 2021 Author Share Posted June 5, 2021 Thanks Frank that explains it. ? Quote Link to comment Share on other sites More sharing options...
