MPX Heron Camber Settings
I am puzzled by the instructions in the manual for Camber.
The aileron setting is what I don't understand. Is it saying that the ailerons have 10mm up?
I would have expected the ailerons to be the same as the flaps +3mm/-3.5mm and that seems to be what others have done.
Any suggestions or explanations?
Yep, this is the aileron to flap mix for a more sprightly roll, you set it up so the flaps only move up with aileron input, so right aileron moves the right aileron up and the right flap up, the left aileron moves down but the left flap doesn't move down, and vice versa for opposite aileron.
Ailerons used as flaps, thermic and speed are +/- 2mm.
I have flight phases set up on mine with an ACRO flight phase were the flaps move up with their corresponding aileron.
  • Thanks 1
