dave windymiller Posted August 23, 2021 Share Posted August 23, 2021 For years ive used the white lightweight filler from various diy stores. Recently ive noticed this filler doesnt sand and acts as if its got pva mixed in (rubbery a bit). Bought a second pot (different make) and its the same . Anyone else found this or have any good suggestions for the easy to sand version? Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted August 23, 2021 Share Posted August 23, 2021 (edited) Red Devil - really lightweight and really easy to sand. Edited August 23, 2021 by Ron Gray Quote Link to comment Share on other sites More sharing options...
Simon Chaddock Posted August 23, 2021 Share Posted August 23, 2021 I use the One Strike. Easy to apply and given a few hours it dried hard and is easy to sand. Quote Link to comment Share on other sites More sharing options...
adrian garnham Posted August 24, 2021 Share Posted August 24, 2021 Dave funny you should mention that. I've had a similar problem recently. I purchased some One strike filler but had to get the gun version as they had no tubs in stock. Filled and sanded perfectly. I purchased another couple of tubes 2 weeks later and the consistency seemed more creamy. It hasn't dried as well as the first batch and when sanding seems to produce rolls of filler under the block ... as if it had PVA in it. Just going to pick up some Red devil from toolstation and give that a go. Quote Link to comment Share on other sites More sharing options...
SIMON CRAGG Posted August 24, 2021 Share Posted August 24, 2021 Same here. Looks like Red Devil is the way to go! Quote Link to comment Share on other sites More sharing options...
Bruce Collinson Posted August 24, 2021 Share Posted August 24, 2021 Pollyfilla Advanced. Pre-mixed, light, goes on easily and finishes quickly, fast drying, sands very easily, takes next coating/film/glass readily. Expensive, not just as readily available as some other Polycell products, not needed to buy for 2 yrs so cannot swear that the gremlins haven't "improved" the recipie. Infinitely superior to specific lightweight model filler. BTC 1 Quote Link to comment Share on other sites More sharing options...
Mike T Posted August 24, 2021 Share Posted August 24, 2021 Polyfilla Advanced is the one where you pick up the pot and think its empty! Ideal for minor imperfections which can be sanded in about 20 mins. Quote Link to comment Share on other sites More sharing options...
Alan Hilton Posted August 24, 2021 Share Posted August 24, 2021 Micro balloons and white emulsion paint works well but doesn’t keep Quote Link to comment Share on other sites More sharing options...
Mike Chantler Posted August 24, 2021 Share Posted August 24, 2021 Did an experiment and tried these lightweight ones a month ago. All fine, but No Nonsense is a bit heavier and possibly smoother that the others. Quote Link to comment Share on other sites More sharing options...
dave windymiller Posted August 24, 2021 Author Share Posted August 24, 2021 Thanks for the suggestions guys. Avoid these! Quote Link to comment Share on other sites More sharing options...
SIMON CRAGG Posted August 24, 2021 Share Posted August 24, 2021 "Sanding not required", is always a bit worrying. Usually means it cannot be sanded well, because it pulls and goes bobbly like my pandenic track suit bottoms!. Quote Link to comment Share on other sites More sharing options...
Mike Chantler Posted August 25, 2021 Share Posted August 25, 2021 I've had problems making up a reliable 'sauce' mix (filler, wbp, talc). Sometimes it goes bobbly, and I wonder if it's because I didn't mix it well. I've also had problems with air bubbles when rejuvenating an hour old mix with some water. wondered about sticking the mix in a vacuum pot, although this seems a bit extreme. Quote Link to comment Share on other sites More sharing options...
IDD15 Posted August 25, 2021 Share Posted August 25, 2021 Whilst we are talking about fillers (very useful recommendations thanks all) has anyone tried colouring these lightweight fillers to match balsa/ply and if so what did you use? I want a natural varnish finish on a current project but need to use a bit of filler in one or two places and white would just look horrible. MTIA idd Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted August 25, 2021 Share Posted August 25, 2021 For most jobs I now use Ronseal WooFill. It's a two pack ,sets very quickly, sands easily , is strong,a comes in white or biege colours. A little heavier but good for small quick filling jobs enabling you tocrack on and not wait ages for filler to set. Works well on most foams but not polystyrene foam . Stores OK provided lid is properly fitted will keep a couple of years. Only mix what you can use as working time varies from 5 to 10 min depending on temperature. 1 Quote Link to comment Share on other sites More sharing options...
cymaz Posted September 2, 2021 Share Posted September 2, 2021 Anyone tried dope and talcum powder mix? Quote Link to comment Share on other sites More sharing options...
Trevor Posted September 2, 2021 Share Posted September 2, 2021 My dim and distant recollection is that that was a recipe for sanding sealer rather than filler. But maybe if you mixed it thick enough. . . ? Quote Link to comment Share on other sites More sharing options...
IDD15 Posted September 2, 2021 Share Posted September 2, 2021 So I tried a little experiment to colour some lightweight Polycell filler and am quite pleased with the results. I used a tiny amount of raw sienna (about 1/2 a match head) water colour paint to a large dollop of the filler and got a reasonable match to the balsa. After sanding the filler was almost invisible and it sanded as easily as ever. However, after applying some sanding sealer it is a little more obvious but a lot less so than if it was white. As I've now decided to do a tissue finish I'm hoping the filler will all but disappear again. Cheers idd Quote Link to comment Share on other sites More sharing options...
Andy Stephenson Posted March 29, 2022 Share Posted March 29, 2022 Any further thoughts on ready mixed lightweight filler. I notice the Red Devil filler says no sanding required, I'm suspicious when it says this as it also says this on the Onestrike filler I bought recently which has changed formulation and is now rubbery and doesn't sand nicely. I shall go for Pollyfilla Avanced unless this has changed also. It doesn't say anything about sanding on the pack so is this a good sign? Quote Link to comment Share on other sites More sharing options...
Erfolg Posted March 30, 2022 Share Posted March 30, 2022 A positive for this season, is that it is no longer a no-brainer to simply select Mercedes and Lewis, Then put together the best low value driver and car, you could judge. In the past the real challenge was the fastest lap, pole etc. In my case I was just average. That was knowing that the front row would have Lewis somewhere there and that more often than not, Lewis would also have fastest lap, as the fuel load would go down. Now, which team and driver are already a bit of a conundrum, both immediately and later in the season. Quote Link to comment Share on other sites More sharing options...
Gary Manuel Posted March 30, 2022 Share Posted March 30, 2022 3 minutes ago, Erfolg said: A positive for this season, is that it is no longer a no-brainer to simply select Mercedes and Lewis, Then put together the best low value driver and car, you could judge. In the past the real challenge was the fastest lap, pole etc. In my case I was just average. That was knowing that the front row would have Lewis somewhere there and that more often than not, Lewis would also have fastest lap, as the fuel load would go down. Now, which team and driver are already a bit of a conundrum, both immediately and later in the season. I've never heard Lewis Hamilton being described as a Lightweight Filler before, but I suppose it's true. ?? 1 Quote Link to comment Share on other sites More sharing options...
cymaz Posted March 30, 2022 Share Posted March 30, 2022 ? Quote Link to comment Share on other sites More sharing options...
John Lee Posted March 30, 2022 Share Posted March 30, 2022 15 hours ago, Andy Stephenson said: Any further thoughts on ready mixed lightweight filler. I notice the Red Devil filler says no sanding required, I'm suspicious when it says this as it also says this on the Onestrike filler I bought recently which has changed formulation and is now rubbery and doesn't sand nicely. I shall go for Pollyfilla Avanced unless this has changed also. It doesn't say anything about sanding on the pack so is this a good sign? I think the Red Devil 'no sanding' is a sales pitch aimed at when it is used on a house wall etc, you can smooth it out with a spreader so that little or no sanding is needed. In a modelling context I just slap it on & sand it down. I found it sands fine, it is quite crisp and not rubbery. I used it a couple of weeks ago on a Tiger Moth I'm building. Quote Link to comment Share on other sites More sharing options...
Andy Stephenson Posted March 30, 2022 Share Posted March 30, 2022 5 hours ago, Gary Manuel said: I've never heard Lewis Hamilton being described as a Lightweight Filler before, but I suppose it's true. ?? I thought I'd dropped into an alternate universe! Quote Link to comment Share on other sites More sharing options...
Barryorbik Posted March 30, 2022 Share Posted March 30, 2022 Looks as though Erfolg has lol! Quote Link to comment Share on other sites More sharing options...
john stones 1 - Moderator Posted March 30, 2022 Share Posted March 30, 2022 Filler up ? Quote Link to comment Share on other sites More sharing options...
