Clive Jones 4 Posted September 30, 2021 Share Posted September 30, 2021 Hi Guys, I have a CC Lee Me 262 EDF. It uses Speed 320 size brushed motors. Can anyone recommend a UK supplier for these motors? An Internet search has left me baffled as, back in the day, Speed 320, Speed 400 and Speed 600 motors were plentiful - I guess the move to brushless has influenced supply. The motors have a can length of 32mm with a 2mm shaft and are variously described as: Graupner Speed 320 Mabuchi 320 Can motor TIA Clive. Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted September 30, 2021 Share Posted September 30, 2021 Why not just replace with a suitable brushless inrunner ? Any of the rc electric motor specialist will be able to help. Quote Link to comment Share on other sites More sharing options...
John Lee Posted September 30, 2021 Share Posted September 30, 2021 https://www.ebay.co.uk/itm/154461805561?hash=item23f6a41bf9:g:Xk8AAOSwOTdgp9IF Quote Link to comment Share on other sites More sharing options...
Outrunner Posted September 30, 2021 Share Posted September 30, 2021 Clive, I buy geared motor from these people Technobots they also do can motors in a variety of sizes and winds. Quote Link to comment Share on other sites More sharing options...
Rich Griff Posted September 30, 2021 Share Posted September 30, 2021 Technobots, thanks for the heads up... Quote Link to comment Share on other sites More sharing options...
Piers Bowlan Posted September 30, 2021 Share Posted September 30, 2021 (edited) 4 hours ago, Clive Jones 4 said: Hi Guys, I have a CC Lee Me 262 EDF. It uses Speed 320 size brushed motors. Can anyone recommend a UK supplier for these motors? An Internet search has left me baffled as, back in the day, Speed 320, Speed 400 and Speed 600 motors were plentiful - I guess the move to brushless has influenced supply. The motors have a can length of 32mm with a 2mm shaft and are variously described as: Graupner Speed 320 Mabuchi 320 Can motor TIA Clive. Hi Clive, this is a very old model which, back in the day, I believe was pretty hopeless on these brushed motors as the model was very over-weight and under powered. If someone knows different, please correct me on this as I am just going on comments made on 'RC Groups'. I think a modern brushless setup and fan could transform the model however, so I suggest you give George Worley of 4-Max a ring and ask him what he recommends. Probably a couple of the 50mm fans and BL motors with a suitable LiPo will provide the required urge. Good luck. Edited September 30, 2021 by Piers Bowlan Quote Link to comment Share on other sites More sharing options...
Clive Jones 4 Posted September 30, 2021 Author Share Posted September 30, 2021 Hi Piers, I actually flew mine on the stock motors and fans but using 11.1V LiPo and a 40A ESC. It flew in a scale like manner on 3/4 throttle but one motor lost power in flight and I powered off to an OK landing. You are right that brushless would be the way to go but as I was given this model secondhand, I do not really want to invest much cash into it initially hence the call for the brushed Speed 320. I hope that the Sp 320s will be adequate for a scale flight (I have other models for aerobatics). Clive. Quote Link to comment Share on other sites More sharing options...
Sparks Posted September 30, 2021 Share Posted September 30, 2021 Try Model Maniacs https://www.modelmaniacs.co.uk/product/280-300-class-brushed-electric-motor/ Quote Link to comment Share on other sites More sharing options...
Engine Doctor Posted October 1, 2021 Share Posted October 1, 2021 I had a Kyosho T33 bought new when they first came out . A useless pile of foam that was underpowered , only climbed to about the height of a normal house before the heavy nicad went flat ! Then lipos and brushless came on the scene. I found a unstarted T33 kit at the Old Warden boot fair about 12 years ago. Fitted it with a brushless EDF unit and a 3000 4s lipo it literally powered away any was a great flyer. Sadly lost just before lockdown due to a unexpected elevator servo failing! Try uprating it you eiļ be amazed at the difference. Quote Link to comment Share on other sites More sharing options...
