Chris Walby Posted October 7, 2024 Share Posted October 7, 2024 Or just don't have something that weighs loads, has high wing loading and comes in like a steam train or tip stalls aggressively. IMO why the FW 190 works so well, it has none of the above traits 1 Quote Link to comment Share on other sites More sharing options...
RICHARD WILLS Posted October 7, 2024 Share Posted October 7, 2024 36 minutes ago, Chris Walby said: Or just don't have something that weighs loads, has high wing loading and comes in like a steam train or tip stalls aggressively. IMO why the FW 190 works so well, it has none of the above traits I agree with all of the above . Fitting retracts definitely puts you on edge , which is illogical if you have been successfully landing on the belly (which when you think about it has to be more precise ) The 190 is really like landing an acrowot as it comes in with very a positive approach at a nice pace , but naturally not too slow. I do think that the 190 is one to stick with for practicing better landing technique. The retracts will absorb a lot of punishment too . The Tempest is harder to land as it will fly ridiculously slowly . That is fine if you are on your fifth Tempest landing of the day , but if you have flown something else , the Tempest seems to keep trying to fly again ! Consequently you have to set your glide path , then try to avoid pulling the nose up as it wont mush , it will actually either just hang there or even start climbing again . So much lift in that wing . Once you get use to it , it will land at a walk . So , to repeat , practice with the 190 again and again . If your runway is rough, hack out the wheel wells and put some bigger diameter wheels on . Quote Link to comment Share on other sites More sharing options...
Andy Gates Posted October 7, 2024 Share Posted October 7, 2024 Having gone through a few sets or retracts in one way or another, I have found that if I fly the plane to a wheeler type landing rather than trying the 3 pointer - the retracts definitely last longer and don't pull out so often. 3 Quote Link to comment Share on other sites More sharing options...
Paul Johnson 4 Posted October 8, 2024 Share Posted October 8, 2024 19 hours ago, Andy Gates said: I have found that if I fly the plane to a wheeler type landing rather than trying the 3 pointer Trying to achieve a 3 pointer means flying at almost a stall speed, no room for error. Try using a little throttle all the way to the ground and only cut when the wheels gently kiss the ground it will settle itself onto the tail wheel. Quote Link to comment Share on other sites More sharing options...
Nigel Dell Posted October 8, 2024 Share Posted October 8, 2024 Well after buying the 110 when in the last incarnation then due to various health issues, hip replacement and renal vasculitis I have not able to do a whole lot 😳☹️ I have tried building things but got to the finishing stage and lost interest, even when restoring a model for the i200 laser got so far and then the rush to finish was gone, so went to redraw the plans I started about 30 years ago of the Miles M13 Hobby Hawk which had been waiting all this time for the i200 to come along but that is quite a big undertaking for me at this moment so what better to do than join the Warbird Replicas winter build, I had thought of doing the 109 which I have but have mislaid the nose moulding then I saw this so 110 it is! Have everything from before, motors & speed controllers, servos, retracts, I thought I had U/C legs but can’t seem to find them! Sound system, pilots so basically everything for it, so I am going to join you all this winter and I hope to get my proper mojo back. All being well I can get the 109 done as well as I want to do Franz Steiger’s example. As soon as the dates for BOB at Buckminster are published then I will make sure I book the dates off from work to give myself something to work towards. I think I need this. 5 Quote Link to comment Share on other sites More sharing options...
Paul Johnson 4 Posted October 8, 2024 Share Posted October 8, 2024 Nice to see you back on here Nigel. I'll pm you regarding the 109 later with some "mods" I did to mine if you wish? Quote Link to comment Share on other sites More sharing options...
Paul Johnson 4 Posted October 8, 2024 Share Posted October 8, 2024 18 minutes ago, Nigel Dell said: retracts, I thought I had U/C legs but can’t seem to find them! Also hold fire with this as Richard and I have been busy with a new idea relating to the retracts. So far testing is going well. 2 Quote Link to comment Share on other sites More sharing options...
Lipo Man Posted October 8, 2024 Share Posted October 8, 2024 18 minutes ago, Nigel Dell said: Well after buying the 110 when in the last incarnation then due to various health issues, hip replacement and renal vasculitis I have not able to do a whole lot 😳☹️ I have tried building things but got to the finishing stage and lost interest, even when restoring a model for the i200 laser got so far and then the rush to finish was gone, so went to redraw the plans I started about 30 years ago of the Miles M13 Hobby Hawk which had been waiting all this time for the i200 to come along but that is quite a big undertaking for me at this moment so what better to do than join the Warbird Replicas winter build, I had thought of doing the 109 which I have but have mislaid the nose moulding then I saw this so 110 it is! Have everything from before, motors & speed controllers, servos, retracts, I thought I had U/C legs but can’t seem to find them! Sound system, pilots so basically everything for it, so I am going to join you all this winter and I hope to get my proper mojo back. All being well I can get the 109 done as well as I want to do Franz Steiger’s example. As soon as the dates for BOB at Buckminster are published then I will make sure I book the dates off from work to give myself something to work towards. I think I need this. I built the FW190 last winter and found the process of building whilst following other people’s builds really enjoyable! I think it genuinely helped me stay focused, and I learned a lot from other people’s builds whilst getting lots of motivation. Flying in a group with some of those other models at Buckminster recently was the icing on the cake! Good luck with your project - I hope you enjoy it as much as I did! 5 Quote Link to comment Share on other sites More sharing options...
Nigel Dell Posted October 8, 2024 Share Posted October 8, 2024 7 minutes ago, Paul Johnson 4 said: Nice to see you back on here Nigel. I'll pm you regarding the 109 later with some "mods" I did to mine if you wish? That’s great thanks Paul. 1 Quote Link to comment Share on other sites More sharing options...
Graham R Posted October 8, 2024 Share Posted October 8, 2024 Good to see you back on here Nigel. 1 Quote Link to comment Share on other sites More sharing options...
Nigel Dell Posted October 8, 2024 Share Posted October 8, 2024 1 minute ago, Lipo Man said: I built the FW190 last winter and found the process of building whilst following other people’s builds really enjoyable! I think it genuinely helped me stay focused, and I learned a lot from other people’s builds whilst getting lots of motivation. Flying in a group with some of those other models at Buckminster recently was the icing on the cake! Good luck with your project - I hope you enjoy it as much as I did! That is what I was hopeful of LM I need the motivation and focus most of all. 2 Quote Link to comment Share on other sites More sharing options...
Nigel Dell Posted October 8, 2024 Share Posted October 8, 2024 1 minute ago, Graham R said: Good to see you back on here Nigel. Thanks Graham, it’s almost like I have abducted by aliens and dropped back here! 😂 Quote Link to comment Share on other sites More sharing options...
RICHARD WILLS Posted October 8, 2024 Share Posted October 8, 2024 It will do you good to have something positive to focus on Nigel . Always good to have you on board old chum . 😉 Richard 1 Quote Link to comment Share on other sites More sharing options...
Paul Johnson 4 Posted October 8, 2024 Share Posted October 8, 2024 1 minute ago, Nigel Dell said: abducted by aliens Did they use probes???? I've heard about where they stick 'em. I hope your recovery is fast, and you're not walking funny.... 1 Quote Link to comment Share on other sites More sharing options...
RICHARD WILLS Posted October 8, 2024 Share Posted October 8, 2024 He always walked funny , that was the least of his problems 😬 1 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted October 8, 2024 Share Posted October 8, 2024 All this talk of building and lack of motivation gets me thinking about my build videos (which have been on hold due to flying and now me re-arranging my workshop which includes heating!!!). Now here's a thought, is there an appetite for a 'live' build-a-long, whereby I will be building a WR model and you will be able to see me doing that live and you would all be able to participate in that build through chat? Quote Link to comment Share on other sites More sharing options...
Nigel Dell Posted October 8, 2024 Share Posted October 8, 2024 I had also at the time started drawing up the ordinance for the 110 and drop tank for the 109 as I intended for them to be able to drop things! The plugs were started but put away, I will get them out and finish them off probably going to be epoxy glass rather than abs. also making moulds from the two kinds of spinners I have here just in case they are no longer available, the 109 spinner I have has three separate blades that bolt on so will take a mould from those as well not sure about the 3 blade props for the 110 as yet but must be doable just never done it although I have made fans for edf so not that much of a stretch. Quote Link to comment Share on other sites More sharing options...
Nigel Dell Posted October 8, 2024 Share Posted October 8, 2024 Thanks matey I miss our chats, I should come up fly with you soon, another thing I have done very little of, I have a good feeling in my water, at least 5 times a night!😂 11 minutes ago, RICHARD WILLS said: It will do you good to have something positive to focus on Nigel . Always good to have you on board old chum . 😉 Richard 1 Quote Link to comment Share on other sites More sharing options...
Nigel Dell Posted October 8, 2024 Share Posted October 8, 2024 10 minutes ago, Paul Johnson 4 said: Did they use probes???? I've heard about where they stick 'em. I hope your recovery is fast, and you're not walking funny.... Memory is a bit hazy but think cross between Gladiator and Baberella you may have the idea and as Richard says I have always walked funny ever since the horse riding incident 😳😂 1 1 Quote Link to comment Share on other sites More sharing options...
Chris Walby Posted October 8, 2024 Share Posted October 8, 2024 12 minutes ago, Ron Gray said: All this talk of building and lack of motivation gets me thinking about my build videos (which have been on hold due to flying and now me re-arranging my workshop which includes heating!!!). Now here's a thought, is there an appetite for a 'live' build-a-long, whereby I will be building a WR model and you will be able to see me doing that live and you would all be able to participate in that build through chat? "See me doing that live" and with all due respect I don't think I could keep up with the build speed especially if Eric gets on board it would be finished in a week! I am back on the Tempest build and only a couple of minor comments regarding the VLOG for that. The build of the fuselage and wing simultaneously makes it quite time consuming going backward and forwards trying to find the VLOG that covers a part of the build I am currently stuck on! Bits of the build that are missing. E.G. with the fuselage one minute you were pinning the rear deck and the next its all finished back to the tail feathers section (I'll raise my Q on that thread). Perhaps a Q and A with Ron in the shed would be a bit of fun, but might be tricky it does not head off at a tangent or rabbit hole discussion. 1 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted October 8, 2024 Share Posted October 8, 2024 11 minutes ago, Chris Walby said: with the fuselage one minute you were pinning the rear deck and the next its all finished back to the tail feathers section The Tempest build VLOG was a bit different to that of the FW in that I didn't break it down into as many (30) vids and I do tend to build more than 1 bit at a time! Yes, I did miss out the actual pinning of the turtle deck onto the fuselage sides and the subsequent carving, maybe I need to ensure that steps like that aren't missed out in future builds! Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted October 8, 2024 Share Posted October 8, 2024 15 minutes ago, Chris Walby said: Perhaps a Q and A with Ron in the shed would be a bit of fun, but might be tricky it does not head off at a tangent or rabbit hole discussion. I know that others have done that (Chris Harvey) but I don't know if that sort of theme is what viewers want. Quote Link to comment Share on other sites More sharing options...
RICHARD WILLS Posted October 8, 2024 Share Posted October 8, 2024 Ron , can you do it like Jack Hargreaves or better still Bob Flemming . https://www.bing.com/videos/riverview/relatedvideo?q=bob+fleming+youtube&mid=CEB9DE58BAA3DC331F38CEB9DE58BAA3DC331F38&FORM=VIRE 1 Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted October 8, 2024 Share Posted October 8, 2024 Ah, Bob (cough) Fleming now there’s a presenter to aspire to. Seemingly he freely and frequently gave away gold sovereigns. Quote Link to comment Share on other sites More sharing options...
Eric Robson Posted October 12, 2024 Share Posted October 12, 2024 Not another Spitfire! Started this at the back end of September, no blow by blow description as it has been well documented elsewhere. My other Warbirds Replicas Spitfire is IC, and a Mk9, this one will be decorated as an early one but I won't be shortening the nose, the wheels and exhausts are 3D printed by Paul Johnson, should have asked him to print a Merlin engine as the whole top will come off to replace the battery. I hope to have it finished before the Bf110 kit arrives. I have another Tempest to build so busy times ahead. 5 Quote Link to comment Share on other sites More sharing options...
