Fire extinguishers
GrumpyGnome
47 minutes ago, Rich Griff said:
Lithium battery fire extinguisher ??
Please elaborate please...
Lithex fire extinguisher available from safe fire direct. Specifically designed to extinguish lithium battery fires. Having seen a lipo fire I thought it worthwhile to have one at home and to carry it in the car when transporting batteries.
Ok, lipo, liion, life and any other li battery, lithium, are new to me.
I knew I read it somewhere, yes 4nax safety sheets that come with the lipo batteries I got, in red....
Do and don't when using lithium polymers cells ( lipo )...
Never use Water to try and extinguish a lipo fire, it acts like petrol etc. etc. etc....
Read the spec sheets for the lithex extinguisher please...
Any feedback......at all ?
17 minutes ago, Rich Griff said:
...Read the spec sheets for the lithex extinguisher please...
Let's hope not, that would mean he had needed to use it.... ?
Comparison video - yes it from a seller for the extinguishers, but having taken a look at the data sheet and with my chemistry background I can see no reason these won't be effective against an oxygen generating fire source such as our lithium packs.
Edited by MattyB
Carbon dioxide unit, cooling the fire to below temperature it can burn? Not magic that’s for sure.
Water never acts like petrol. But if the fire is hot enough to, the steam generated, carries the fire with it.
The Royal Navy uses water to tackle petrol fires. They use a water screen, and shoot the dousing jet of water through the screen. It is frightening to to be behind the water screen, a ball of fire explodes a foot in front of your face, and it’s hot on the skin. As in hot, not warm. And then it cools and goes out.
All fires go out if cooled enough.
Anybody read the active ingredient list on the extinguisher.
The extinguisher contains a suspension of very finely divided vermiculite. When used, the platelets of vermiculite overlap in layers forming an air tight seal extinguishing the fire.
In some exceptional circumstances, water can act as "petrol", never try extinguishing an alkali metal fire with water the reaction produces hydrogen and a big bang! Sodium and potassium will also burn in a CO2 atmosphere.
Sorry, yes, alkali metal, put a bit of water on, whoosh. Put a ton on, it produces a weak alkali solution, too cool to whoosh. Water does not burn. Ever. It’s burnt hydrogen, bottom of the energy pile, happy, can’t descend further,
And from distant memory, Sodium will burn in CO2. But at the thick end of a 1000°C. Potassium will be hotter, less reactive.
My braising torch is not that hot.
Now I admit to being a cynic. Vermiculite, grow bag component, forming an airtight seal, in an expanding gas?, stuctural strength?. A few numbers might be welcome? How it does it?
Rather than marketing speak.
And I thought that the problem with lithium battery fires, is they produce the oxygen to keep the fire going. So why seek to form a layer from oxygen when the problem is below the layer.
Vermiculite might be good in a fire, but floating platelets, sealing together, like a balloon creating itself in the flames, needs some explaining.
put a fire out, cool it, or starve it of fuel. Bit like a IC motor.
Interesting info, but wandered a little off topic!
I'm amending our clubs safety sheet which currently advises a fire extinguisher in the pits for petrol engines.  I just wondered if this is common in other clubs, universal, or occasional..... and if it's also recommended for glow engines.
TIA.
GG
Interesting....
Anyway when I looked at the lipo fire extinguisher on the fire safe site, I emailed them for advise on an extinguisher for a lipo fire.
The reply I just got was extremely non committal and suggested nothing, for a lipo fire, other than a risk assessment.
I replied rewording the question, lipo, lithium polymer rechargable battery fire on open ground bare earth.
Perhaps they will suggest/recommend an extinguisher ...
The plot thickens...
Just had a very quick reply from the above question, a suitable fire extinguisher for a lipo fire, a lithium polymer rechargable battery fire on open ground bare earth.
The reply was they do not recommend what type of extinguisher ( for any type of fire ? ) to use, it's all down to a risk assessment ?
I will reread the text they have on Thier site for lithium ion batteries, just in case I read it wrong. Anyone else read that text ?
Is a lithium ion battery the same as a lipo, a lithium polymer rechargeable battery ?
4max say do not use water on a lipo fire...
An extinguisher would be a good idea, but the right type being important I would think.
My lipo storage methods will need reaccessing and acting on.
Feedback......anyone ?
Having witnessed a couple of LiPo fires - one accidental, one provoked - I would not dream of going near one whilst it was going off. The fire intensity & volume of toxic smoke needs to be seen to be believed.
My life is worth more than possessions, I'd stand well back & let it burn out or the professionals deal with it.
Agreed.
I have not witnessed a lipo fire but have seen a couple of videos...
It's what else they set fire to thats the worry, and the appropriate first extinguisher used for that, NOT WATER....
I am thinking hard about outside storage but need to take waterproofing and ambiant temperature into account.
I don't want the shed or house burning down, or sleepless nights worrying about lipo's.
I am only going into electric propulsion in a very limited way me thinks.
Any comments on  the fire safe text about lithium batteries, anyone ?
I store outside in a BatSafe &/or fireproof document case within a garden storage box. The storage temperature is not an issue in the UK. Charging is in a BatSafe after returning to room temperature. I've a couple of 2kg powder fire extinguishers for residual fires if I felt safe to tackle them.
And with that I sleep soundly.
https://www.bat-safe.com
Thanks John.
The bat safe website doesn't seem to work properly so I emailed asking for details and if there is a UK dealer.
All my old ammo boxes are full of fuel etc but I can rearrange stuff to free one up.
Off to town tomorrow for some plaster board and research a plastic waterproof lockable garden storage chest.
Getting the bmfa lipo saefty sheets printed A4, much easier to read than this tiny phone screen.
The bat safe vidio, the first one, was that a mobile phone on the desk ?, terrifying !!!
1 hour ago, Rich Griff said:
Thanks John.
Most decent model shops plus HobbyKing stock them.
Just put 'bat-safe' into http://www.rcferret.co.uk (a dedicated RC search engine) or your favourite search site & it will produce loads of results.
On topic - club does not allow turbines, no recommendations for IC or electric to have fire extinguishers local to the model. A couple of large water/foam extinguishers in the club house.
Off topic
As mentioned above and same as your local fire and rescue service in the event of a fire a risk assessment is appropriate at the time of the incident. If the fire puts people at risk then tackle the fire, if it involves property then only tackle it if there is no personal risk.
IMHO Foam (coverage, cooling and distance of operation), dry powder or a halon (BCF) would be most suitable lastly CO2, but as I understand its a self prorogating type fire so really you are only dealing with a secondary fire of adjacent materials.
I have BCF in the garage and workshop because its the best for a wide range of types of fire and requires very low concentrations to extinguish the fire, but its no longer available due to its ozone depleting properties.
Yep - now that I have started sometimes charging at home rather than just at the field a pair of Bat Safes does it for me. Lipo storage is in Sentry Firesafes for the rarely used packs and in the proper, original Lipo Sacks inside a steel cabinet for the packs in regular use. Wireless linked fire alarms, ABC dry powder fire extinguishers on the opposite wall and I was considering adding an automatic heat activated fore extinguisher in the steel cabinet. I think we had this discussion a few weeks ago, but just in case here's a picture.
