Top flight P-47-D
An enya 155 would tear it to bits. A friend has that engine in the H9 20cc version and its still got monster power.
Topflite always recommend massive engines for the american market. They tend to build them really heavy and fly them at 500mph scale speed. If you build it to 10lbs, which should be easy enough, a 90 or 100 would be fine exactly as Don suggests.
Also, TF wood tends to be a bit like oak floor boards at times. You might want to get some decent balsa in for sheeting the tail and fuselage to help keep the weight down
