Cloud Walker Build
Murat Kece 1
A Cloud Walker kit (65inch, vintage plane with 3 channel controls, from Valueplanes) was brought by Santa in Dec21..  I was longing to have vintage plane for some time and I did not waste time to start the build.
  • Wingspan  :  1650 mm  (65 inches)
  • Length       :  1240 mm  (49 inches)
  • CG              :  110mm from the leading edge
  • AU Weight :  1185 g  (approx. 2.6 pounds)
  • Covering   :  Lightweight Iron-on HK film (Transparent Red and Solid White)
  • Radio         :  Three Channel
  • Servos       :  17 Gram metal geared
  • ESC            :  Volantex 30 Amp ESC
  • Motor         :  Overlander 3530 motor 340 Watts
  • Battery      :  3S 3200 mAh LiPo
  • Prop           :  10x 6 giving 225 watts (11 x 3.8 gives 280 watts)
I started the build with the fuselage. First I checked that the motor fits and aligns with the cowling. Started with a 2836motor initially which was mounted at the front of the firewall.
     20220101_190611.thumb.jpg.df07df08a823784861e03cadb51607d2.jpg   20220101_190401.thumb.jpg.3dbfd541886b702018cdd40c59eddfc6.jpg   20220101_190327.thumb.jpg.c343f9b93e483dd0b73c98ca8f070351.jpg
Connected the motor t the firewall and tested its fitting into the nose section together with the under carriage.
Later this was changed motor to Overalander 3530.This was connected to the back of the firewall. This gave a much neater placement with a shorter cowling and clean propeller connection.
20220104_154337.thumb.jpg.c62473c093963f2b9550feaf219aa1a5.jpg20220104_154314.thumb.jpg.bc96a53d5798f30e8f835f11c2f71c9c.jpg20220104_154306.thumb.jpg.a6ae6539410c0d85e2065b1469d199a4.jpg
Te motor box and the nose section was assembled ad the cowling was initially build with an extra section 3 layers rather than 2 but this was then reduced back to 2 layers to allow fitting of the propeller easier without a shaft extension.
The sides of the fuselage were built together and then connected to the nose box.
20220102_230623.thumb.jpg.f30e11d0bf1009c66e3378d6aa8ebd9d.jpg     20220103_120632.thumb.jpg.d87377b07a5ee8fda1bf7fd08d2c7e89.jpg 20220103_202607.thumb.jpg.43bbd6dc1b893663893a546799138c16.jpg
Then the bottom deck formers and the snake guides were glued in place.
The motorbox/nose section cheeks were glued and shaped before the turtledeck formers and stiners are glued.
To be continued.................
Edited by Murat Kece 1
Corrections
  • Like 4
  • 3 weeks later...
Here's the continuation with the hatch and cabin build.
20220107_190948.thumb.jpg.65ba92202a9b5da8f14f87b22decee36.jpg  20220107_190945.thumb.jpg.198e00980df9184e55f457afb5f6702e.jpg
Followed by te tail appendages:
20220119_010611.thumb.jpg.5623a768f0cdb588b3140cf301f662ff.jpg 20220119_010631.thumb.jpg.35ae33bb2bb8c4196c26e698838184be.jpg
20220126_140551.thumb.jpg.2429afe9f2981e3b4390ca43b1e59611.jpg   20220108_150841.thumb.jpg.ab712e597b25813a488a28f472cd69d6.jpg
Here's the fuselage with the appendages and the motor added:
20220108_150717.thumb.jpg.ae91c7ef02cdfa0fe1bae0d0b164fd9b.jpg   20220108_150751.thumb.jpg.b172ed6f16efe6585bf9baf9c24c3dcb.jpg
Wings then followed. The spars needed shaping and adjusting to fit properly.
Commenced the covering of the plane wit Hobby King transparent red and solid white films.
The acrylic windows were screwed in:
The wings were covered. Thanks to Brain Cullen, the decals were cut from white vynil and applied:
The covered plane parts were then assembled:
Here's the finished article.
CG / Motor tests:
Tornado3530 Motor
PROP VOLTS AMPS WATTS
10x5E 12.40 16.10    200
10x6 11.90 18.94    225
11x3.8 11.99 23.22    278
CG 110 mm
The short nose required installation of some 60gr lead next to the motor. A 3S 3200MAH battery has been employed. Opted for the 11 x 3.8 propeller.
In the field:
The maiden was straight forward with some trimming. Here's the flight video (not very professional). The plane does not like much wind as it is very light (1.2kg). It floats well and glides well. It is a sedate flier. The build was relatively straight forward requiring intermediate build experience as the  instructions are inadequate and incomplete. Overall I think it is a good vintage looking plane that I will cherish.  I may go for a 4 S battery for a more responsive flight once I gain ore experience with it. Cheers.
  • Like 5
  • 1 year later...
  • 9 months later...
