Charles Hart Posted April 6, 2022 Share Posted April 6, 2022 Can anyone offer any advice regarding a Gyro/Stabilized Receiver for use in an Laser 70 powered 68" span Chipmunk – Spektrum DX9 Tx – separate aileron channels, elevator, rudder, flaps and throttle Quote Link to comment Share on other sites More sharing options...
Romeo Whisky Posted April 6, 2022 Share Posted April 6, 2022 I can recommend the Lemon 6ch stabilized DSM2/DSMX receiver with diversity aerials. You won't need the Gear channel on a Chipmunk so you can use that for the flaps. Quote Link to comment Share on other sites More sharing options...
Charles Hart Posted April 6, 2022 Author Share Posted April 6, 2022 Thanks Romeo Whisky Quote Link to comment Share on other sites More sharing options...
Shaun Walsh Posted April 6, 2022 Share Posted April 6, 2022 1 hour ago, Romeo Whisky said: I can recommend the Lemon 6ch stabilized DSM2/DSMX receiver with diversity aerials. You won't need the Gear channel on a Chipmunk so you can use that for the flaps. I will second that, have them in a couple of models. On the Stabiliser-PLUS model you can set the failsafe so that on loss of signal the stabiliser levels the model rather than just cutting the throttle. I set mine up so that on signal loss the model is level in the roll axis with a slight nose down attitude. On the one occasion it kicked in the model was half way through a loop, the motor cut, the model rolled upright, levelled out and performed a downwind landing with no damage. Quote Link to comment Share on other sites More sharing options...
Charles Hart Posted April 6, 2022 Author Share Posted April 6, 2022 Thanks Shaun Quote Link to comment Share on other sites More sharing options...
Frank Skilbeck Posted April 6, 2022 Share Posted April 6, 2022 Are the Lemon stabilised receivers OK in an IC model, I've used the cheaper stabilisers (orange etc) in electric models and they have been fine, but never in an IC model. Some of the more expensive gyro/stabilisers (Multiplex Wingstabi and Jeti assist rxs that I know of) have the option to filter out certain frequencies to make them usable in IC models, do the Lemon ones do that or is it not needed with them. Quote Link to comment Share on other sites More sharing options...
Charles Hart Posted April 6, 2022 Author Share Posted April 6, 2022 To be perfectly honest I don't know. I have searched a number of sites and not come up with an answer – I have a Lemon 7 channel rx with a satelite. Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted April 6, 2022 Share Posted April 6, 2022 12 minutes ago, Charles Hart said: To be perfectly honest I don't know. I have searched a number of sites and not come up with an answer – I have a Lemon 7 channel rx with a satelite. No worries fitting Lemon to IC Charles Follow the fitting instructions and start off with low gain Quote Link to comment Share on other sites More sharing options...
Charles Hart Posted April 7, 2022 Author Share Posted April 7, 2022 Thanks Denis – l will install the Lemon receiver as per the instructions and start with low gain and see how it works. Quote Link to comment Share on other sites More sharing options...
Simon Chaddock Posted April 7, 2022 Share Posted April 7, 2022 Charles It depends on which version of the Lemon stab rx you have and your piloting skill level but my advice is set the gyro to 'rate' control rather than full 'auto'. 'Rate' mode means the gyro only reacts to sudden changes in the planes orientation, you are still totally flying the plane but if my experience is anything to go by you will be amazed just how smoothly it flies. However do make absolutely sure the gyro is acting in the correct sense, i.e. it is moving the control surface to oppose the attitude change in all 3 axis. Remember the direction of the gyro reaction in each axis is set by the tiny dip switches on the rx. It pays to set the gain higher during set up to get a clearly visible reaction and then turn it down for the initial flight. Get it wrong and a crash is almost inevitable. Once you are at a safe height try switching the the gyro on & off to give you a direct comparison of gyro/no gyro. Have fun. 1 Quote Link to comment Share on other sites More sharing options...
Charles Hart Posted April 7, 2022 Author Share Posted April 7, 2022 Thanks Simon for your input – all points duly noted Quote Link to comment Share on other sites More sharing options...
