Ron Gray Posted April 10, 2022 Share Posted April 10, 2022 Video says it all! (As before, this video is a raw, uncut / undoctored version) 1 Quote Link to comment Share on other sites More sharing options...
MattyB Posted April 10, 2022 Share Posted April 10, 2022 Was it damaged? Difficult to tell from the ending, but looked a fairly innocuous nose over? Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted April 10, 2022 Author Share Posted April 10, 2022 No damage Matty, with no prop wash the up elevator was no enough to stop it but it was on the grass! 1 Quote Link to comment Share on other sites More sharing options...
J D 8 Posted April 10, 2022 Share Posted April 10, 2022 Having too much fun and running out of fuel, been there done that. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted April 10, 2022 Author Share Posted April 10, 2022 It was that 'oh, just one more fly-by' moment! (and ignoring the timer!!!). But boy did I have fun with it. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted April 10, 2022 Author Share Posted April 10, 2022 Just watched the video again but this time with headphones on - cor! Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted April 10, 2022 Author Share Posted April 10, 2022 (edited) Crash team's video evidence. (Looks like the pilot legged it) Edited April 10, 2022 by Ron Gray Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted April 11, 2022 Share Posted April 11, 2022 So will you eventually finish it with one of these ?. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted April 11, 2022 Author Share Posted April 11, 2022 Now that I'm happy with it the plan is to do a cockpit fit-out, gun ports and finish off the exhaust ports. The only problem I foresee is that I like flying it so can I bear for it to be grounded? Oh well there are are several others to chose from!!! Quote Link to comment Share on other sites More sharing options...
Jon H Posted April 11, 2022 Share Posted April 11, 2022 The engine sounds awesome, where can i get one? ? And i nearly ran out of fuel flying my trusty La7 yesterday. A clubmate had his 240v powered spitfire up there so we went for some twin twin action as the La7 currently has a 240v as well. We were having loads of fun but i forgot i swapped out the dual 14oz tanks for dual 11oz when i changed the engine so ignored my timer beep as i 'knew' i had plenty of extra fuel. Alas, the change in tanks meant i did not have as large a reserve as i thought and barely 90 seconds after the timer went off i started getting coughs and splutters with one pot dropping out a minute or so later just at touchdown. After this i went in for a slow run retune (changed fuels to the new laser 5 low oil so had to reset the needles) and this made the engine not only run much better but use less fuel so the following flights had a little more insurance time. Sadly no video of our flights, but it did sound great ? Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted April 11, 2022 Author Share Posted April 11, 2022 5 minutes ago, Jon - Laser Engines said: The engine sounds awesome, where can i get one? Not bad is it? Will be even better when I lean it out a bit more as 1 pot seems to be running richer than the other. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted April 14, 2022 Author Share Posted April 14, 2022 I spent a little bit of time yesterday fitting a 17x8 APC prop and slightly leaning out the fuel supply. I am planning on trying it out again tomorrow so will of course report back - still no pilot though! Quote Link to comment Share on other sites More sharing options...
Dwain Dibley. Posted April 14, 2022 Share Posted April 14, 2022 Seems like there was a lack of sympathy for running dry Ron, judging by the laughter at the end of the first vid. I would ban that individual. LOL or fit a bigger tank. ? D.D. Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted April 14, 2022 Author Share Posted April 14, 2022 Yes D.D. you are quite correct, unfortunately I think that it was all onlookers who laughed, not just the one. Hopefully with the larger prop I will be using less throttle (=less fuel) but then it's a warbird so 'pedal to the metal'. I've just got to force myself to land after 6 minutes and check the tank contents so that I can recalibrate. But it may mean fitting a larger tank, this one is only 15oz, but that may mean re-forming the cut out in the wing..................... Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted April 15, 2022 Author Share Posted April 15, 2022 Well as luck would have it Capt Every C Loud was available to take the controls for today's flights Quote Link to comment Share on other sites More sharing options...
Ron Gray Posted April 15, 2022 Author Share Posted April 15, 2022 The .............., the bad and the just plain ugly: All flights today were with a 17x8 APC prop = more grunt, less noise. First flight of the day saw a loss of air pressure which mean that the air down retracts didn't so a belly landing was called for - no damage done! The bad Having found the cause of the air loss, 3 more flights took place without mishap (boring videos!) then there was this one, I misjudged the touch down and wasn't quick enough to react! The just plain ugly Quote Link to comment Share on other sites More sharing options...
