Removing Prop Adaptor From Motor Shaft
Nigel Heather
1 hour ago, Andy Stephenson said:
Nigel, I depends on which type it is. Is it the collet type or the grub screw type?
A photo would help.
That's the problem you can't see it because it is inside the foam fuselage and you can't see it.  Took a chance that it was a collet and just pulled with pliers - it popped off easily - was expecting to have to use some form of puller.
