Stick change on Futaba FX-20
Stick switches should include a switch, a mechanised stick top to accept the switch and a drilled stick bar for passing the cables. Most Futaba radios need changing the stick bar for installing switch sticks, although I know some models already mount drilled bar. I do not know about the FX-20, sorry.
You do not need taking the stick mechanism to pieces, although it is the best way to go.
Regarding reclaibrating, if I remember correctly the FX-20 has the same software as the old 8FG, which includes a calibrating menu and it is not needed any special service software to recalibrate the main controls.
