Brendan Fogarty Posted June 7 Share Posted June 7 Hi all. Hope someone can help. I have acquired what I think was an ARTF low wing trainer called Freak. Unfortunately, searching for Freak tends to return results including “accident”, which is what I’m trying to avoid. I’m having trouble trimming it out, and I think maybe the thrust line is wrong. Does anyone know this model? I’d love to see the original recommendations for setup. The balance is about right, and it glides power off OK, but dives power on. Running an OS40 which is powerful enough for what I want. Thanks in advance. Brendan Quote Link to comment Share on other sites More sharing options...
John Lee Posted June 7 Share Posted June 7 I can't recall a model of that name - could it just be a random decal put on by the builder? The aircraft has the distinct air of one of the old Dave Smith Models. If you can provide a photo of the complete model with the wings on, plus its dimensions, you may have a better chance of getting its ID. Quote Link to comment Share on other sites More sharing options...
MattyB Posted June 7 Share Posted June 7 Based on your description it sounds like you can just add a washer or two under the mount to reduce the downthrust without consulting any original plan or instructions - it is not going to cause it to become suddenly unflyable, and will probably address your issue. Quote Link to comment Share on other sites More sharing options...
Keith Berriman Posted June 7 Share Posted June 7 Hi Brendan having viewed your picture a few times it has a close resemblance to a modified Acro Wot The undercarriage held on with elastic bands, the top of fuselage without a canopy, and slight mod to rudder feature Just my thoughts Quote Link to comment Share on other sites More sharing options...
Brendan Fogarty Posted June 7 Author Share Posted June 7 Thanks all. I’ll double check the balance then put a couple of degrees upthrust on the motor which will I’m sure trim it out. It would be nice to know what the thrust line should have been though. Cheers. Brendan Quote Link to comment Share on other sites More sharing options...
