J D 8 Posted July 7, 2022 Share Posted July 7, 2022 (edited) After much service the Wasp 2200kv 250w in runner motor in my Ripmax Coyote has given up while ripping around the sky this evening. [ something has come loose inside and motor is binding ] Can someone say where I can get a similar replacement. Thanks. Edited July 7, 2022 by J D 8 extra info Quote Link to comment Share on other sites More sharing options...
Chris Walby Posted July 8, 2022 Share Posted July 8, 2022 Try 4Max? They do in runners and if its not on the website then give George a call. Quote Link to comment Share on other sites More sharing options...
Shaun Walsh Posted July 8, 2022 Share Posted July 8, 2022 (edited) 55 minutes ago, Chris Walby said: Try 4Max? They do in runners and if its not on the website then give George a call. 2180 inrunner Unfortunately out of stock at the moment Edited July 8, 2022 by Shaun Walsh Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted July 8, 2022 Share Posted July 8, 2022 ElectricWingman, Robotbirds, fleabay..... you know the kV and can measure the required dimensions for an equivalent (diameter, length, weight). Quote Link to comment Share on other sites More sharing options...
Romeo Whisky Posted July 8, 2022 Share Posted July 8, 2022 Overlander also do inrunners. Quote Link to comment Share on other sites More sharing options...
J D 8 Posted July 8, 2022 Author Share Posted July 8, 2022 Thanks for the response all. I had been around the houses but most did not have or out of stock. But have now found what needed at Overlander. Ta RW I had not thought of them. Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted July 8, 2022 Share Posted July 8, 2022 Result! Quote Link to comment Share on other sites More sharing options...
J D 8 Posted July 26, 2022 Author Share Posted July 26, 2022 Tested with new Overlander motor tonight, goes like a rat up a drain pipe doing vertical rolls. All for just over £20. 1 1 Quote Link to comment Share on other sites More sharing options...
