Edgeflyer Posted July 31, 2022 Share Posted July 31, 2022 I've inherited this model. It has the extreme manoeuvrability thrust deflectors installed. Does anyone have experience of how flyable this is for someone with limited reactions! Quote Link to comment Share on other sites More sharing options...
EarlyBird Posted July 31, 2022 Share Posted July 31, 2022 Looks fun Quote Link to comment Share on other sites More sharing options...
MattyB Posted July 31, 2022 Share Posted July 31, 2022 (edited) 14 hours ago, Phil B said: I've inherited this model. It has the extreme manoeuvrability thrust deflectors installed. Does anyone have experience of how flyable this is for someone with limited reactions! Just set up a few flight modes, one with the vectored thrust disabled, one with them enabled and coupled in pitch with the elevator only, and another with the full 3 axis coupling (you could even configure rates for the vectored thrust effect when enabled). Get three mistakes high, switch modes in turn and see how you like them. Job done! Ps - The above assumes the thrust vectoring uses separate servos; if it doesn’t I guess you are stuck with trying it out from flight one. I would certainly try and limit the gain to the minimum possible mechanically for first flights though. Edited July 31, 2022 by MattyB Quote Link to comment Share on other sites More sharing options...
Adrian Norris 1 Posted July 7, 2023 Share Posted July 7, 2023 (edited) I have an unused boxed 3s version and the thrust vectoring unit , I think it is linked to ailerons,rudder? Edited July 7, 2023 by Adrian Norris 1 Quote Link to comment Share on other sites More sharing options...
