Erfolg Posted September 11, 2022 Share Posted September 11, 2022 What is the importance of the number of turns on a motors performance? For example a 7 as to a 9 or 10 turn motor? Quote Link to comment Share on other sites More sharing options...
PatMc Posted September 11, 2022 Share Posted September 11, 2022 Torque of a motor is proportional to ampere turns - i.e. If all other dimensions are equal then when drawing the same current a 7 turn motor will have 70% of the torque of a 10 turn motor. Quote Link to comment Share on other sites More sharing options...
Simon Chaddock Posted September 11, 2022 Share Posted September 11, 2022 The problem is that most plane brushless motors are so tightly packed inside that to increase the number of turns you have to use a slightly thinner wire which reduces the maximum amps that it can handle. The result is that for a slightly lower amp figure the motor can produce at least the same torque but at lower revs. Finding the best motor for a particular plane can involve a making a choice from quite a number of variables. Quote Link to comment Share on other sites More sharing options...
Paul De Tourtoulon Posted September 12, 2022 Share Posted September 12, 2022 That used to be important on 1/10 scale electric cars with brushed motors, the less turns the faster they went and the more electric they used. Brushless motors should be selected on the wattage ( power ) and the KV, the number of rpm per volt to give the speed that you need with a given prop. Quote Link to comment Share on other sites More sharing options...
