2.4 GHz Power-up
Doug Ireland
Hi guys a quick question if I may...
After setting up my last model with my new 2.4G equipment (DSX9) I'm a bit confused by what happens every time I power up. Regardless of wether I switch on the rx first or the tx, the result is the same. The ailerons deflect to full left then return to neutral once the link is established . If I turn off the tx the throttle returns to "Low" setting as it should then returns to whatever the throttle stick position was originally once the tx is back up.
I've tried to re-bind the system a few times but the result are the same. Any ideas on what I may be doing wrong?
 Doug.
Doug,
           The same thing happens when I power up  my DSX9, I been using the TX for about 6  months now and apart from the odd start-up it's operated without a problem.
I have a DX6i and the control surfaces on one model deflect when Rx is switched on and then go back to neutral, apparently the cause is that the Rx puts power to the servo's before it sends the position signal, some servo's don't move when you do this, others go to one end of their travel. Which is probably why some people see it on different channels.
