Allan Bennett Posted November 30, 2023 Share Posted November 30, 2023 I've just replaced the v4.2.2 motherboard in my Creality Ender 3 printer with v4.2.7 'Silent' board. It's impressively quieter than before, and all appears to be working well except for bed levelling and Z-axis offset. With v4.2.2 I would select 'Level Bed' and it would go around probing 16 points on the bed, and that was it. When printing I could see that it was taking account of the data the probe had gathered because the Z-axis motor would move back and forth ever so slightly during each print layer to compensate for out-of-levelness. With v4.2.7 when I select 'Level Bed' it goes around probing 9 points then, after it's finished the menu screen shows 'Bed Levelling: Off' which I then change to 'On' and then save the settings (the menu option to switch levelling on or off is not available until after the probing has finished). When I then do a print the Z-axis motor is stationary during each layer even though I can see the first layer varies in thickness. The other difference from v4.2.2 which I can't fathom is setting the Z-axis Offset: With v4.2.7 when I select that option it allows me to change the offset, but it doesn't move the nozzle up and down to let me check the clearance with a piece of paper between it and the bed, as I used to do. The firmware is "Marlin 2.0.6 June 11 2021 Ender-3". In the Creality downloads site it's labelled as "Ender-3_HW-V4.2.7_SW-V2.0.6_BLTouch" There's also another v4.2.7 firmware labelled "Ender-3_HW4.2.7_SW2.0.9.03_SpriteExt_H300", is this likely to work with my BLTouch? Any guidance would be appreciated. Quote Link to comment Share on other sites More sharing options...
Andy Meade Posted December 5, 2023 Share Posted December 5, 2023 (edited) Do you include the bed level and "store" in your Gcode in the slicer software? That's where I tend to keep it, which means I don't have to click on it manually on the printer hardware - each print is preceded by a full bed level. I just pullled this from my Cura profile for my Ender 5 Plus; M420 S1 Z2 ;Enable ABL using saved Mesh and Fade Height Edited December 5, 2023 by Andy Meade Quote Link to comment Share on other sites More sharing options...
Andy Meade Posted December 5, 2023 Share Posted December 5, 2023 One other thing with your Z height - I seem to remember that the offset goes straight in to the settings but doesn't move the axis in case of collision. Check your readout on the printer - that should change once you applied your offset. If you then need to check zero, go to move axis and jog it down - the offset should have stuck. Quote Link to comment Share on other sites More sharing options...
Allan Bennett Posted December 5, 2023 Author Share Posted December 5, 2023 Thanks for the replies. I didn't know about being able to store bed levelling etc. in the slicer. I use PrusaSlicer, but that's a good tip. But that's not the issue at the moment: With the v4.2.2 motherboard (which is back in my Ender at the moment so I can continue printing), when I do a print after doing the automatic levelling I can see the Z-axis motor moving back and forth slightly to take account of the out-of-levelness of the bed as detected by the automatic levelling routine. The v4.2.7 board did a 9-point probe of the bed levels, but simply didn't take the results into account when printing, as evidenced by no visual movement of the Z-axis motor, and visibly varying thickness of the first layer. The other issue is with the v4.2.2 motherboard after I do the bed levelling I then adjust the Probe Z Offset: The nozzle lowers towards the bed, to what it thinks the height should be for the first layer, then hands control of the Z height to me so I can adjust it up or down by turning the knob on the control panel until a piece of printer paper is not quite trapped between the nozzle and the bed. A figure of -0.3 to -0.6 usually does the job. With the v4.2.7 motherboard the nozzle stays up in the air at about +50mm (IIRC) and I then can adjust the Z height + or - using the knob -- but that's + or - from the +50mm height, which is meaningless. I've managed to get the attention of Ender in China on this one, so I hope to find out soon if it's the board, the firmware, or me that's faulty. Quote Link to comment Share on other sites More sharing options...
Allan Bennett Posted December 9, 2023 Author Share Posted December 9, 2023 I seem to be going round in circles with Ender China office: In their latest email they say that the firmware 'Ender3Marlin2.0.6HW4.2.7BLTouch' which I'm using is for the version 4.2.2 motherboard, and have directed me to their web site for download "Ender-3_HW-V4.2.7_SW-V2.0.6_BLTouch". But that's a zipped file which, when downloaded and unzipped gives me a folder 'Ender-3 Marlin2.0.6 CR Touch or BLTouch firmware' which contains only one file; 'Ender3Marlin2.0.6HW4.2.7BLTouch' 😖 Is there anyone out there with an Ender 3 'Silent' motherboard v4.2.7 and BL or CRTouch who can tell me exactly what firmware they're using please? Quote Link to comment Share on other sites More sharing options...
PDB Posted December 9, 2023 Share Posted December 9, 2023 Which bed levelling sensor are you using? Quote Link to comment Share on other sites More sharing options...
Allan Bennett Posted December 10, 2023 Author Share Posted December 10, 2023 CR Touch. Quote Link to comment Share on other sites More sharing options...
FlyinFlynn Posted December 10, 2023 Share Posted December 10, 2023 Not sure if you already know this but Teaching Tech has a video on Creality board upgrades and firmware flashing problem.. https://www.youtube.com/watch?v=neS7lB7fCww 1 Quote Link to comment Share on other sites More sharing options...
PDB Posted December 10, 2023 Share Posted December 10, 2023 (edited) The silent board also known as the V4.2.7 board uses TMC2225 stepper motor drivers to reduce noise, it also supports both the CR Touch and BL Touch bed levelling sensors hence both drivers being available. The BL Touch driver won't work in your printer. I'd be trying one of the following 4 drivers depending on the version of Ender 3 you have available from here https://www.creality.com/products/cr-touch-auto-leveling-kit, on opening the downloaded zip file you'll see a 4.2.7 folder containing the firmware. Edited December 10, 2023 by PDB Quote Link to comment Share on other sites More sharing options...
Allan Bennett Posted December 10, 2023 Author Share Posted December 10, 2023 Thanks for those two replies. Interesting that the file location that I've used, and Creality keep referring me to, says that the 4.2.7 file is for BLTouch and CRTouch. The location you've given me, PDB, looks much more promising, with a specific CRTouch file and a higher version number than I'm using. I'll swap the board back and give it a go as soon as I can. I've watched that video, FlyinFlynn, and it fills me with dread! Anyway, if I still don't get a result with PDB's link I'll see if I can sort things out by going to the Marlin site as per the video. 1 Quote Link to comment Share on other sites More sharing options...
Allan Bennett Posted December 11, 2023 Author Share Posted December 11, 2023 On 10/12/2023 at 10:37, PDB said: The silent board also known as the V4.2.7 board uses TMC2225 stepper motor drivers to reduce noise, it also supports both the CR Touch and BL Touch bed levelling sensors hence both drivers being available. The BL Touch driver won't work in your printer. I'd be trying one of the following 4 drivers depending on the version of Ender 3 you have available from here https://www.creality.com/products/cr-touch-auto-leveling-kit, on opening the downloaded zip file you'll see a 4.2.7 folder containing the firmware. Thank you PDB. File 'Ender-3_HW4.2.7_SW2.0.8.28_CRTOUCH_standard' from the 'Ender-3 CR Touch Firmware' folder in your screenshot is doing the job for me. Apart from it being different from the file I previously downloaded from the Ender-3 downloads section, it's confusing that the .bin file names and folder names are different from the headings on the Creality web site. Anyway, we got there in the end! 1 Quote Link to comment Share on other sites More sharing options...
Paul Johnson 4 Posted December 13, 2023 Share Posted December 13, 2023 Hi Allan The ender 3 sites firmware is usually way out of date try this site and for a few dollars donation you can use the custom build page. Easy to use and ALWAYS up to date on the latest Marlin builds for firmware. Best firmware site Quote Link to comment Share on other sites More sharing options...
Allan Bennett Posted December 13, 2023 Author Share Posted December 13, 2023 Thanks Paul Johnson, but it's working well now so I'm not going to change it! Just before I got PDB's suggestion I had emailed Creality again saying that the file they were recommending didn't work. Incredibly I got a response today which once again simply repeated the link to the file that doesn't work. Quote Link to comment Share on other sites More sharing options...
Paul Johnson 4 Posted December 13, 2023 Share Posted December 13, 2023 Using the files from that site are easy to use and do work, they also have a lot more functionality. Quote Link to comment Share on other sites More sharing options...
Allan Bennett Posted December 14, 2023 Author Share Posted December 14, 2023 11 hours ago, Paul Johnson 4 said: Using the files from that site are easy to use and do work, they also have a lot more functionality. But I don't see a file for Ender 3 v4.2.7 with CRTouch, just BLTouch. I'm guessing CR and BL are interchangeable, though someone has said that Creality BLTouch files won't work with CRTouch. Quote Link to comment Share on other sites More sharing options...
Paul Johnson 4 Posted December 14, 2023 Share Posted December 14, 2023 (edited) They are the same I have the CR touch and it works fine Edited December 14, 2023 by Paul Johnson 4 Quote Link to comment Share on other sites More sharing options...
PDB Posted December 14, 2023 Share Posted December 14, 2023 52 minutes ago, Allan Bennett said: someone has said that Creality BLTouch files won't work with CRTouch. For clarity I was referring to the "Creality" provided firmware, not the Marlin FW Paul has linked too. I have tried other firmware, including Marlin and https://github.com/mriscoc, and for my basic needs the Creality firmware works fine. Quote Link to comment Share on other sites More sharing options...
Allan Bennett Posted December 14, 2023 Author Share Posted December 14, 2023 4 hours ago, PDB said: For clarity I was referring to the "Creality" provided firmware, not the Marlin FW Paul has linked too. I have tried other firmware, including Marlin and https://github.com/mriscoc, and for my basic needs the Creality firmware works fine. OK. It's still working fine for me, so it will stay as it is. Thanks DB. Quote Link to comment Share on other sites More sharing options...
Rashad Collie Posted April 24, 2024 Share Posted April 24, 2024 On 13/12/2023 at 02:06, Paul Johnson 4 said: Hi Allan The ender 3 sites firmware is usually way out of date try this site and for a few dollars donation you can use the custom build page. Easy to use and ALWAYS up to date on the latest Marlin builds for firmware. Best firmware site Hello Paul, I was wondering if you'd be able to help with an issue I've been having. I recently upgraded my ender 3 pro to a 4.2.7 board to use with my BLTouch. No matter what firmware I find online when I auto home my printer goes to X 162 Y 124 and Z 10. When I try to level the bed the printer tries to level off of the bed in thin air. The latest firmware I flashed was from that link you recommended (see highlighted screenshot below). Any help would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
Paul Johnson 4 Posted April 24, 2024 Share Posted April 24, 2024 Try using the custom build page and make sure you have all the correct printer info entered. Also have you disconnected the z stop microswitch and from within the firmware builder selected to use the bltouch in its place. There is a lot of settings available from within the custom build page that are not available from the free download link, for a few dollars donation I find its worth it. Also check you have connected the bltouch correctly. I have the CR touch which is connected differently. It's usually something missed in either connecting up or firmware that causes issues. 1 Quote Link to comment Share on other sites More sharing options...
Paul Johnson 4 Posted April 24, 2024 Share Posted April 24, 2024 Also when updating the firmware the printer needs all its E steps, probe off sets etc resetting 1 Quote Link to comment Share on other sites More sharing options...
Paul Johnson 4 Posted April 24, 2024 Share Posted April 24, 2024 Quick example of settings available Quote Link to comment Share on other sites More sharing options...
Gunnar Borseth Posted April 24, 2024 Share Posted April 24, 2024 Try adjusting z-probe offset in printer menu. You need to tell it the distance to the print bed. Takes a bit of trial and error. Take it slow so you don't ram the into the bed. Quote Link to comment Share on other sites More sharing options...
Rashad Collie Posted April 26, 2024 Share Posted April 26, 2024 Thank you both so much! This custom build page is definitely worth it. Quote Link to comment Share on other sites More sharing options...
