Banned IP addresses?
steve too
Summary
It's not the IP address, it's something in the site software that happens when I change device that I am using to access this site. I can work around it.
Detail
The way that I access the Internet means that sites can see a different IP address from request to request. I know this because it causes problems with some sites (e.g. Santander) that log you out if they see an address change.
Sometimes I see a Banned message when accessing this site.
Some sites block addresses if they are seeing attacks from them.
Testing since I started this topic leads me to the conclude that the Banned business happens after I change from accessing this site on one device (A) to using another (B). Interestingly, it doesn't seem to happen on first request from B, but a subsequent one and doesn't seem to happen if I am not logged on on A.
I assume by proxy farm you are reffering to a proxy server better known as a VPN?
If you are then I would think it has more to do with cookie settings, I use a VPN all the time and have no such problems even with logging into Santander Barclays etc, the only website that can be a challenge is I Player which does actively ban VPN's when it can to attemot to prevent access from abroad aince they don't know who is really at the end.
Two years ago I tried to sign into the Lottery site while in Jersey but it told me I was outside tjhe UK and wouldn't let me sign in. Ever since, every so often I get the same message without  doing anything different. I have to completely shut down the computer and then when I retry it is OK. Camelot says it is a BT internet problem not theirs. Not a problem as the lottery company is changing next month according to Tesco.
John
On 26/12/2023 at 10:30, steve too said:
Summary
Detail
This may not be what you are referring to, but it seems banning via IP addresses is a bit of a lottery. Because someone using my IP address was banned on Reddit a while back, I get random bans on certain sub-Reddits. It isn't onerous enough to make me change my IP address, but it is annoying when an innocuous post is followed by a "Banned" banner blocking everything!
I know that IP blocks/bans happen which is why I asked the question. In this case I am pretty sure that it is something in the site software that happens when I have recently been logged on on another device.
