Geoff's Warbirds Replicas P51 Mustang
Geoff Gardiner
Well done Geoff . I'm really liking the look you are going for .
I really miss my P51B even though I still fly the blue nose D version .
They are almost different aircraft to look at because of all of the subtle differences .
When you've finished I will no doubt be inspired to make another one !
Thanks chaps.
So, I glued the canopy last night and must have been a bit tired because when I took the tape off today I noticed that it was slightly off centre.
Once I had noticed it my eye was drawn to it. So it was out with the knife and the canopy was removed ( I did'nt take a picture because the air had gone blue! )
I am blaming Leccy for this decision as he pointed out that I had forgotton the gunsight 😉 (thanks for the link)
Out with the 3d printer and a gunsight was duly fitted.
More later...
  • Like 4
  • Haha 1
  • 3 weeks later...
  • 1 month later...
Very nice Geoff . I didnt expect less to be honest, having seen your mossie build .
I note , like me , you are using a plastic kit as reference on your PC screen .
It baffles me why some of our static modelling cousins have never considered building a really detailed, non flying version of our kits .
Just think how far you could go , if it didnt need to be a practical flyer ?
I remember visiting Universal Studios , soon after Memphis Belle had been released . They showed us one of the 16ft B17 models on a perspex post , that had working props , rotating guns and flashing muzzles . It was being used on green screen but made a spectacular display model .
Conversely, I have been to a large static model event at the Bovington Tank Museum and everyone there was getting all excited about a £500 24" span Lancaster that Hong Kong models had made . No contest!
A little bit more tweaking done and I think she is finished.
I fitted the ESC and a voltage sensor.
I also had to file the flats off the bottom of the prop adapter so that the prop would fit properly.
Weigh-in Time
According to Richard, he was coming in at 6.5lbs.  Now I am not sure if this includes the battery and if it had the alloy spinner fitted?
I have two batches of batteries that I aim to use - one heavier than the other.
With the lighter batteries I have an AUW of....... 3344g or 7.4lbs
With the heavier ones I have an AUW of........... 3392g or 7.5lbs
The only extras that I added were some 3d printed detail in the office and exhausts, and I extended the battery tray to aid fitting the CofG without having to add any chunks of lead. Also, I am using 4000mah lipos and I believe Richard uses 3300's.
I am hoping that 7.5lbs is not too porky!
I suppose I had better go fly it.............
Oh and Richard uses a plastic spinner the aluminium one is a lot heavier. Plus he uses a 3200mAh whereas I use a 4000mAh.  You might also find the aluminium spinner backplate is prone to distortion even from a gentle nose over if you find a bump or hole. I eventually replaced it with a thicker one, more weight,  but much better.
Just make sure if you do nose over you check it.
You definitely have done yourself proud with this  one.
