Rocker Posted February 21, 2024 Share Posted February 21, 2024 Have a Futaba 10J Transmitter and have always used the Futaba R3008SB receivers in my models .I am about to change 3 models over from Spektrum to the Futaba 10 J .So I need 3 Futaba receivers to do this Was going to buy 3 R3008SB but I do not use telemetry so was thinking of getting 3 R2008 receivers. Anyone tell what is the difference between the 3008 and the 2008 .I do not use telemetry It is just that the 2008 are a bit cheaper I Quote Link to comment Share on other sites More sharing options...
Jon H Posted February 21, 2024 Share Posted February 21, 2024 I think the SB is for Sbus compatibility and there might be a higher voltage tolerance on the 3008. I have 2008's in plenty of models and they have worked very well for me. Quote Link to comment Share on other sites More sharing options...
GaryW Posted February 21, 2024 Share Posted February 21, 2024 (edited) The difference between the 2008 & 3008 is the Modulation Type in similar way as Spektrum DSM2 & DSMX....... the Futaba 2008 is S-FHSS and the 3008 is T-FHSS not all Futaba Tx's transmit both T-FHSS & S-FHSS some only do one or the other where as the Futaba 10J does transmit both Edited February 21, 2024 by GaryW Quote Link to comment Share on other sites More sharing options...
GaryW Posted February 21, 2024 Share Posted February 21, 2024 Also The Futaba 2008 is S-BUS only where the 3008 is S-BUS & S-BUS 2 compatable Quote Link to comment Share on other sites More sharing options...
Denis Watkins Posted February 21, 2024 Share Posted February 21, 2024 Here is the 10J compatibility list Rocker Quote Link to comment Share on other sites More sharing options...
