Cliff 1959 Posted May 24, 2024 Share Posted May 24, 2024 Does anyone sell 4mm balsa sheet in the UK does anyone know? Quote Link to comment Share on other sites More sharing options...
Matt Carlton Posted May 24, 2024 Share Posted May 24, 2024 Cornwall Model Boats 4mm Balsa Sheet Hth Matt Quote Link to comment Share on other sites More sharing options...
Cliff 1959 Posted May 24, 2024 Author Share Posted May 24, 2024 Thanks Matt, almost on my doorstep too, cheers Quote Link to comment Share on other sites More sharing options...
Don Fry Posted May 24, 2024 Share Posted May 24, 2024 Or 3.97 mm is 5/32 inch. Close enough. I live in France, and I’m surprised, when I buy wood it’s often described as a metric size, when the cutter used an imperial machine it’s the nearest imperial equivalent.. ditto, vice versa when the cutter uses a metric machine to Imperial.. Reasion I suspect, they set the cutter to an exact size on the dial, and it stays the same, batch to batch Last time I bought a Chris Wott kit, the plans were metric, all the wood was Imperial. i have a good micrometer. Quote Link to comment Share on other sites More sharing options...
