Belated build of RC modeller Wayfarer
Posted (edited)
Four years ago today, whilst on furlough I started a build of a wayfarer. This is a plan build from a plan released 1972, and later kitted in Europe by Svenson.
Plans are available from outerzone.
Anyway 3rd July. On very warm day I spent an hour or so marking, sawing and drilling the rib templates.
Edited by Nigel Sharp
Typo
  • Like 4
This is a 52inch biplane weight between 5 1/2 to 7lb and for 40 to 60 two stroke or 60 to 80 fourstroke. However this is a 780 watt electric conversion. 4s 4000 batteries, end up with a turning NTM propdrive 4248 650 kv motor driving a 14 x 8 1/2 prop via a 60 amp esc.
On the above setup it gives a very spritely performance. But is easy to fly and performes all the usual club aerobatics. Will vertical eight, avalanch, spin stall turn and just about prop hang.
I digress. The balsa was supplied by balsa cabin right when demand soared. I had to wait through April and May etc.
Cost was about £130.
If you print the outerzone plan at 100% it is slightly too large.
at 99.1% means the fuselage side is 36 inch and wing sheeting 48 inch. So that is the scale I used.
My master aircrew balsa stipper would not reach the spar height, for cutting the 3/16 hard balsa. So out with some mdf to make something bespoke.
  • Like 2
Wing spars, cut to length and notched for the ribs.
Wing construction is old fashioned. The later Acromaster uses two spars with shear webs.
Also made two paper tubes by wrapping A4 paper lightly spread with thined pva glue around an old tube "Marblehead yachtmast" because I also used to race vane steared model yachts in the 1980's to 1990's.
These are to take servo wires & plugs through the ribs. I updated to aileron servos instead of Bell cranks and pushrods.
Posted (edited)
Building wing(s) first. There are two being a biplane. Top wing has no dihedral and is 48 span without the tips. Convenient for 48 in balsa sheet.
First wing under way. This is a little earlier than the actual build as I'm driving all day tomorrow. But the build progressed quickly in 2020.
I ordered two sheets too few or made a slight miscalculation on wood required so had to join some offcuts to make a sheet. For the underside D box.
typo
  • Like 2
Wings continue. Top and bottom wings completed as far as beginning the top leading edge and trailing edge sheeting.
You can see the aileron riblets in place, spaced 3/32 apart yo later take 1/32 ply facings. Drill tell tail holes at each end through bottom sheet so you ca n join the dots and cut away later.
Bottom wing has dihedral so this has also been set, and both halves completed with paper tubes in place.
  • Like 2
Wings continued.
Fiddly time consuming bits the upper and lower interplane strut locations are not structural in this design. The struts just plug-in using tongues. Due to frequent fit and removed these are made from 3mm light ply. With a 1/32 ply face to the spar.
Fitting the cap strips to both upper and lower wings and boxing around the root rib and tubes ready to guide the servo wires. Took a day as I have to  wait for my preferred pva glue to dry.
Wings should be complete as far as needed at this stage by tomorrow.
Wing tip blocks roughed out and added.
Centre section sheeting also completed.
Both wings at same stage. A fine day spent with a razor plane and sandpaper turning balsa into shavings and dust. Got to be one of the most satisfying things to do in aeroplane construction. You can see the competed wings in the background of the picture starting the fuselage.
An advantage when using outerzone pdf plans is you can print as many snapshots of sections of the plan. So I printed the fuselage side, and cabane struts. The cabane strut prints were then stuck to 1/4" plywood with thinned pva glue, and later fretted out with my scroll saw. And another hour or two spent with sand paper to smooth the profile.
It's the fact the wayfarer has these ply cabanes that it was chosen. Far easier to make than bending piano wire accurately to give all the correct incidences. But more on that later...
  • Like 2
Jeff,
It's electric 4s 4000mah, 60 amp esc, ntm propdrive 4248 650kv. 780 watts on 14 x 8 1/2 apce prop.
Spritely performance and absolutely fantastic to fly. I love flying it.
How ever it has had to have maintenance due to pilot error and some handling damage. Was at Pontefract few weeks ago the wind lifted it and threw it on the deck upside down... currently recovering the top wing from repairing the spar damage Caused by it.
It's been finished 4 years because it was a covid build. But I'm posting the build progress day by 4 years later.
Fuselage sides cut from 3/32 sheet, plus 1/16 ply doubler.
Sides an doublers bonded and weighted down and leaving till fully dried before further progress can be made. The kitchen cupboard was emptied of the tin cans. Plus of course my weighty tool box.
Spent most of the rest of day fretting out the 1/8 liteply formers.
I'm building the fuselage from a datum board. So the former bottoms have been extended to a line drawn parallel to the top stringer. A partial cut has been made at the former bottom to assis when cutting the sacrifical extension away.
All will become clearer tomorrow.
But it's like building and planking a boat hull. To ensure a true straight build.
Posted (edited)
Sides marked for former positions to aid assembly.
Longerons, and ply wing trebler added and weighted down. Ensuring right and left sides are produced.
Then later cabane struts epoxied and set through the top longeron.
typo/auto incorrection!
I have one too - this was a bit of a nostalgia build for me as my dad built one from the Svenson kit in the late 70's (I think!) his was powered by an OS 40, mine is powered by a Saito FG11, I pushed the firewall back slightly to accommodate the slightly longer engine.
It is a beautiful Sunday flyer, perfect amount of power from the Saito and looks just great putt putting along on a low pass
  • Like 3
I'm slightly miffed... because I'm recovering the 4 year old top wing tonight, using the lower wing as the template to repeat the colour scheme... and in the process I've discoverd the lower wing has also a damaged spar which I hadn't spotted.
There is a hidden tear right on the edge of the sunburst just outboard of the centre section sheeting... and applying a load to the tip causes a small crease to become evident across the top of the spar. Drat. Drat Drat.
The good news is I've spotted it before risking flying it. Will have to do another few evenings repairs. But bang goes flying it this weekend.
So to continue the belated build... on this day 4 years ago.
Take some seasoned wood, straight and not twisted.
Draw a centreline, and former locations perpendicular to it at the correct positions.
Cut short blocks to increase glue area and bond formers to them and the straight board, taking care to align the centers and check perpendicular (vertical).
Leave to set overnight.
Means I should get a firm jig to bond the sides, plus something to keep the fuselage safe while construction continues.
That picture shows what can be done with a colour scheme.
The wayfarer has some cousins...
Acrostar, and Acrofury both later than the wayfarer but essentially the same plane.
https://outerzone.co.uk/plan_details.asp?ID=6256
https://outerzone.co.uk/plan_details.asp?ID=6242
Anyway sides have been positioned and glued to the formers, making use of the strechability of electrical insulation tape to hold everything together. Something to note! Our modern 1/4 ply tends to be 6mm being a metric nation so if you cut the cabane struts front 6mm then the F3 former sits a little low so allow for a bit more material on the lower corners of F3 to compensate.
Posted (edited)
There is plenty of room where the IC tank should be for a 4s 4000, the battery pokes through the aperture in F3 which originally was for the old 4.8/6v receiver pack.
I chose to install the 60 amp esc under the battery on the floor. Later you'll see the firewall modification to allow airflow through.
I've commenced building a battery hatch between F1 and F2 to be held in place by magnets. And since this is all fiddly stuff several other jobs are being done concurrently while waiting for pva to reach firm handling strength.
Although the plan shows a strip built tail. The Designer recommended in a kit review of the Svenson kit in 1973 the it be swapped for a solid 1/4 sheet version. So that what I have done, as two review comments on the outerzone page also referred to tail failure. It's a simpler build too so bonus.
Quite a few hours work there around 12 if memory serves 9am to 9pm!
typo correction
  • Like 3
From the original magazine article.
Using a great planes balance tool. Mine balances upside down on a mark drawn vertically down to the upper surface of the lower wing.
Without having to add any weight too which was pleasing.
The build blog will continue tomorrow. I had a few days off in 2020.
