Diamond Geezer Posted July 15, 2024 Share Posted July 15, 2024 Hi folks im returning an old extra 300. thing is I have aurora 9 tx which I’m trying to set up with the rx I have 2 servos for the elevator normal practice for me is aileron in 1 elevator in 2 throttle in 3 rudder in 4 so where does my othe elevator servo plug into tx don’t give me the option for 2 elevator servos. Quote Link to comment Share on other sites More sharing options...
Shaun Walsh Posted July 15, 2024 Share Posted July 15, 2024 46 minutes ago, Diamond Geezer said: Hi folks im returning an old extra 300. thing is I have aurora 9 tx which I’m trying to set up with the rx I have 2 servos for the elevator normal practice for me is aileron in 1 elevator in 2 throttle in 3 rudder in 4 so where does my othe elevator servo plug into tx don’t give me the option for 2 elevator servos. Use a Y lead to plug both servos into the elevator channel? Quote Link to comment Share on other sites More sharing options...
Bucksboy Posted July 15, 2024 Share Posted July 15, 2024 Geezer, 1. select your model 2. select system (the key/spanner symbol bottom left on the screen) 3. Select channel 4. select ch 5 or ch 6. 5. Hit the ‘Sel’ button, bottom right on the screen. 6. on page one you can choose whatever function you want, ele 2 I suggest. i hope this is clear, if not I’ll add pictures. Quote Link to comment Share on other sites More sharing options...
Diamond Geezer Posted July 16, 2024 Author Share Posted July 16, 2024 Thx Bucksboy I’ll give it a go Quote Link to comment Share on other sites More sharing options...
Diamond Geezer Posted July 16, 2024 Author Share Posted July 16, 2024 Bucksboy sorted that bit now 1 elevator goes up the other down do I have to reverse the servo if so what’s the point of having 2 Quote Link to comment Share on other sites More sharing options...
Philip Lewis 3 Posted July 16, 2024 Share Posted July 16, 2024 Yes, in dual elevator servo's on separate channels one of them will always need to be reversed. Quote Link to comment Share on other sites More sharing options...
PatMc Posted July 16, 2024 Share Posted July 16, 2024 Will elevator trim work on both servos ? Quote Link to comment Share on other sites More sharing options...
Mike T Posted July 16, 2024 Share Posted July 16, 2024 (edited) 22 minutes ago, PatMc said: Will elevator trim work on both servos ? Most likely not relevant, but on my old JR set which has 8* programmable mixes, you have to set up the 2nd ele. on one of the lower (i.e. 4 to 8 ) mixes in order for the master elevator trim to control both servos. It took me several years of ownership to find that out... This may also be the case on an older tx like the Aurora. * I think... 🤨 Edited July 16, 2024 by Mike T stupid forum software turns 8 followed by ) into an emoji!!! Quote Link to comment Share on other sites More sharing options...
Bucksboy Posted July 16, 2024 Share Posted July 16, 2024 Geezer, Getting there then? If one moves the opposite way, reverse one. From the home screen with the correct model selected, touch the big plane icon in the bottom left corner. The next screen should show a load of options under the heading 'model' Top left is 'reverse', touch that. The screen then lists all your servos, touch 'Ele 2' and then 'reverse' or 'normal', confirm that you are happy and that should be it. Exit the screen by touching the little door icon in the top right hand corner of the screen. Again, if this doesn't work, come back to me, it's a really easy system to use. 1 Quote Link to comment Share on other sites More sharing options...
Bucksboy Posted July 16, 2024 Share Posted July 16, 2024 The first picture shows the 'model' sub screen. The second the 'reverse' screen. That is if the pictures come out in the order I've added them.... 1 Quote Link to comment Share on other sites More sharing options...
Diamond Geezer Posted July 16, 2024 Author Share Posted July 16, 2024 Thx mate the aurora may be old but it’s new to me Quote Link to comment Share on other sites More sharing options...
Bucksboy Posted July 16, 2024 Share Posted July 16, 2024 It's a great system, I'm always surprised that it wasn't more popular. I rarely resort to the manual as I can normally work it out. Feel free to ask again if you get stuck. Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted July 16, 2024 Share Posted July 16, 2024 5 hours ago, Philip Lewis 3 said: Yes, in dual elevator servo's on separate channels one of them will always need to be reversed. Surely that depends on the position of the servo and output arm........ @Diamond Geezeras suggested, try it, and reverse movement if necessary Quote Link to comment Share on other sites More sharing options...
Philip Lewis 3 Posted July 16, 2024 Share Posted July 16, 2024 38 minutes ago, GrumpyGnome said: Surely that depends on the position of the servo and output arm. Not if they are installed mirror imaged, if so they will always need one reversed in the same way that ailerons mirror imaged can always use a Y lead because one doesn't need to be reversed. Quote Link to comment Share on other sites More sharing options...
GrumpyGnome Posted July 17, 2024 Share Posted July 17, 2024 Yes, that is absolutely true..... in some installations one will definitely need reversing..... or use the other side of the servo arm 🙂 Like many instances, this cat can be skinned in many ways. Quote Link to comment Share on other sites More sharing options...
Diamond Geezer Posted July 17, 2024 Author Share Posted July 17, 2024 13 hours ago, Bucksboy said: It's a great system, I'm always surprised that it wasn't more popular. I rarely resort to the manual as I can normally work it out. Feel free to ask again if you get stuck. Quote Link to comment Share on other sites More sharing options...
Diamond Geezer Posted July 17, 2024 Author Share Posted July 17, 2024 Thx Quote Link to comment Share on other sites More sharing options...
