Well this is a horrifying incident waiting to happen...
https://www.facebook.com/marketplace/item/997957991550239/?ref=search&referral_code=null&referral_story_type=post&tracking=browse_serp%3A7faddfa2-c794-41fb-8538-eebf6f28dfda
I am fairly sure that this...whatever the hell it is will get sold on ( if it sells) to someone else who will again poke at it a bit, then give up and sell it on in a pointless cycle of deluded commerce, but I have seen worse being urged into the sky ( not very often, admittedly )  and always to at best hilarious and at worst potentially lethal effect.
I hope it stays dangling from SOMEONE's ceiling.  Or that it gets destroyed in a suspiciously "Omen" type "accident".
Seeing how the engine bearers don't reach the main bulkhead and the rest of the front is held on to it by presumably, four wood screws, I guess the concern is that after a bit of vibration and oil in the joints, the engine could go off on its own leaving the rest of the airframe behind.
  • Haha 1
It's not uncommon that engine bearings don't reach the "front bulkhead". That "bulkhead" is often just part no load bearing of a cowl, as this appears to be.
The model looks ugly, unattractive & possibly not particularly well built but no worse than many others being sold second hand.
PatMc, I should have just said bulkhead.  I mean the pice of transverse piece of wood at the bottom of the windscreen with the throttle pushrod wire passing through it.
